Chimney and Stove selection, Englander Madison?
Discussion in 'Modern EPA Stoves and Fireplaces' started by CoreyB, Aug 25, 2017.
  1. wildwest
    I had the 13 insert, bought it new from Ace, cute lil stove--tiny firebox was a deal breaker for us, it's now in storage in our pole barn. You can always build a small fire in the madison, but you cannot build a big fire in the tiny 13. Canadian border VT has run both (similar too).
    fox9988, Eric VW, OhioStihl and 3 others like this.
  2. Canadian border VT
    CoreyB before I joined fhc and I didn't know anything I did have a nc13. type that I ran for 2 years while saving money in that exact clay liner with concrete blocks around and brick faced chimney in my house ... it drafted chimney is 30 ft and draft was not a problem. My local fire department checked the chimney and determined it was safe
    But if it was me in that size house I would definitely choose the larger model and nc30 type the 2.2 cubic foot fire box of the 13 type could not hold a fire for 4 hours in my house.. when I upgraded to the Woodstock ideal Steel that stove easily had 12 hour burn times I built a new chimney for it because we wanted it on a lower level in the house if you have any questions let me know
  3. CoreyB
    CoreyB
    South east iowa
    Ya the down side would be that would eliminate our garage heat. Which is pretty important to me. I basicly live out there in the winter. Keep in mind I have 6 YES ! SIX females! living in our 1,100 sq ft house. I eventually want to make the garage stove a wood furnace I can plumb into the current duct work. Which may be the best way to go I just don't think I can swing the extra cost of the furnace and insert. Vs a madison at $700 and chimney at ruffly $600. It is always a challenge to try and use my pennies wisely when they are so limited.
    Eric VW, Horkn, brenndatomu and 4 others like this.
  4. CoreyB
    CoreyB
    South east iowa
    Ok serious question here guys. When you sweep out your chimney on a straight through the roof INSTALL, do you have to remove the chimney from the stove. Or does it all just drop on the firebox?
    Also can you run single wall inside (before ceiling) and double the rest?
    My thought is it would keep a bit more heat in the house.
    Eric VW, HDRock, Horkn and 1 other person like this.
  5. Ronaldo
    Ronaldo
    I use single wall from the stove to ceiling to capture more heat and it works fine. Your cleanings certainly can drop right down into the stove......wont hurt a thing as long as there is no baffle or anything in the way.
    Sent from my SM-S320VL using Tapatalk
    Eric VW, HDRock, Horkn and 2 others like this.
  6. wildwest
    In an EPA, remove the baffle, then it will fall in the firebox.
  7. CoreyB
    CoreyB
    South east iowa
    I will have to keep that in mind when purchasing. How easy or hard can make a difference of wether it gets done or put off.
    Eric VW, HDRock, wildwest and 2 others like this.
  8. Ronaldo
    Ronaldo
    So true! I have a Pacific Energy with a large stainless steel box baffle ( not tubes) and i need to remove it in order for the cleanings to drop in the box. It is a hassle so I usually just lift my pipe of the top of the stove and shop vac whatever has dropped. Fortunately I dont need to do it often as the stove burns very clean.
  9. brenndatomu
    Another option would be to use double wall pipe inside, then you could install a telescoping section for easy removal if you ended up with a stove that didn't lend itself to easy baffle removal. As I mentioned before, modern stoves don't waste that much heat up the stack so not having single wall isn't going to make much difference on how well it heats your house...especially since it sounds like you are leaning toward getting a stove that is plenty big enough to do the job. Double wall will help keep the chimney a little cleaner too, drop the stack temp too much and you will start to get buildup at the top.
    When you mentioned the Englander furnace before I was curious about the model number you listed. Turns out that is the brand new updated version of the old 28-3500 that was so admired by many. The new EPA certified 28-4000 is more or less a NC30 made into a furnace if I heard correct information. I see HD has 'em for $1250 or so. That's pretty cheap for a clean burn wood furnace, but I'm not sure it has thermostatic control like most furnaces. They do talk about a Tstat, but I'm not sure it controls the burn rate...maybe just kicks the blower on/off? IDK, not having Tstat isn't the end of the world, I put a temp controller on my Drolet Tundra furnace to keep the intake damper shut for most of the burn cycle anyways...that is the most efficient way to run a tube type firebox. Some things to consider...
  10. HDRock
    Both of my stoves I've had single wall stove pipe on, I think it does add a little heat to the house, in your case it's going to cut the cost of your install some..
    I've never had double wall pipe so I can't speak about that.
    My stove uses 4 standard fire brick in the top for the baffle, I clean from top down once a year, I take those out (takes less than 5 minutes) , there is always some ash up on top of their that that you need to clean out anyway, with the baffle bricks out everything falls right into the stove.
    I have a telescoping single-wall stove pipe but I never take that off when I clean the chimney, pipe and stove, .
    With your single story installation I don't think you will have any problem with the pipe cooling too much and creating creosote, I don't
    Eric VW, CoreyB, Ronaldo and 2 others like this.
  11. Canadian border VT
    Do not go straight through on a tube stove BE careful. . frIends have hearthstone soapstone straight up install.. professional paid cleaner put pipe through tubes at top on 9 month old stove :headbang: :picard:
    papadave, Eric VW, CoreyB and 2 others like this.
  12. wildwest
    If I'm thinking correctly the Madison is the same as the NC30 marketed under another name, is that right? papadave coached me on removing a secondary burn tube or two from my 13 based on how he does it on the NC30 (Madison), it was the same and not a big deal. Tilt the tube to lift out then take the baffle out (careful, they can break). Just another small step when you sweep your pipe. No use letting sweepings sit there and possibly restrict air flow, or taking a risk of any creosote that might come off ignite and start a chimney fire imho. Yes, the 13 was a PITA only because the opening is so small and mine was ground level, ya ya, I prefer a bigger firebox hee hee.
  13. brenndatomu
    Huh?
  14. brenndatomu
    I dunno what you are talkin about, but it sounds :rofl: :lol:
    Eric VW, HDRock and wildwest like this.
  15. HDRock
    Eric VW, brenndatomu and wildwest like this.
  16. wildwest
    pee your pants funny!!
    Eric VW, HDRock and brenndatomu like this.
  17. brenndatomu
    Alright, I am interested...any idea where that can be found?
    Eric VW and wildwest like this.
  18. wildwest
    Sorry, I just poked around on the forum and didn't come up with chit. Started 4-20-6016 but ended a few days later, too many posts to wade through.
    Eric VW likes this.
  19. Canadian border VT
    a hearthstone soapstone uses tubes at the top of the Firebox instead of a catalytic converter they are some kind of ceramic tubes.. why I chose the Woodstock instead of hearthstone.. if you over fill your stove the tubes break..
    so if a EPA tube stove on a vertical installation the brush coming down chimney can break the tubes.. probably much like Wild west the had to take her tubes out of insert to clean chimney
    Eric VW and HDRock like this.
  20. wildwest
    Yep, they are actually steel but the baffle above them is ceramic, fragile.
    Edit, not ceramic, but still fragile.
