Homesteading Chicken Coop Build, Chickens, Pond, Garden & Projects
Discussion in 'Hobbies and Interests' started by Well Seasoned, Mar 25, 2018.
  1. Well Seasoned
    These work REALLY good! We've got them for the driveway, behind the house & coop.
    Swann driveway alarm at lowes Amazon ect.
    My link won't work
    savemoney, Chaz, bogieb and 2 others like this.
  2. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    If the birds are laying on the ground up against the fence, do you have roosts for them or a slanted ladder? At night they should prefer through instinct to get up to roost. If it is a blur, do you have a ditch or pond nearby that you would have an otter, mink or weasel?
    Man I hope you get it caught, it is so discouraging to lose laying hens after you have raised them and finally are getting eggs from them.
  3. FatBoy85
    FatBoy85
    Washington State
    I don’t think our weasel problem is big here. Raccoons can be but depends on their population.
  4. Chvymn99
    Mine are meat birds... directly behind my house not even 50 feet... I move my motion lights around from human intruders to animal movement... Plus bought a LED spot light for my garage door motion light that I normally dont turn on... But I figure it would throw some more light out...
    Here’s the slash mark.... looks pretty good to me. The fence is 1” square opening....
  5. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    Meat birds still will roost. It is instinct. Hope they had a safe night.
    savemoney, Chaz, bogieb and 3 others like this.
  6. Sugarbug87
    Sugarbug87
    Buckley WA
    Agreed we have more of a raccoon issue if they are attracted for some other reason.
    savemoney, Chaz, FatBoy85 and 4 others like this.
  7. Sugarbug87
    Sugarbug87
    Buckley WA
    Awe :D I think I'll keep you too. I mean Dex loves you.
    Dexter is my 12 yr old bulldog that HATES people outside of his immediate family.
  8. DaveGunter
    DaveGunter
    Are those just "worm screw clamps" you used to secure the wire mesh to the frame?
    We've retired a greenhouse because the tarp is shot, but the frame is still good, my plan is to take off the lower vertical part and turn the top half circle into a chicken tractor by attaching wire mesh on the ends and covering it with metal roofing, sorry thats the best picture I've got. I think the worm screw idea for attaching the wire mesh to the frame is brilliant, any ideas on how to attach the metal roof?...maybe drill a hole through the frame and use a machine screw with a nut a washer? Obviously that will leak but I don't really care if the tractor roof is completely water proof, its mainly for protection.
  9. Chvymn99
    Yes, just worm screw clamps.... Simplicity... and not having to get pocked by wires...
    I attached my metal roof to the conduit with roofing self tapping screws. I found drilling a smaller hole helped keep things in aligned. the rubber neoprene should keep it water tight. The biggest thing would be to bend the angle for the roof...
  10. DaveGunter
    DaveGunter
    Cedar slab raised bed veggie garden.
    Harvested a bunch of logs, was a challenge as cedars are rarely straight and usually hollow, with a huge taper.
    My buddy picked up the logs and brought them to his place to mill. The milling was odd for him as an experienced sawyer as I was most interested in the slab wood and wanted it to be as evenly thick from end to end as possible. This is not the normal way to mill. We leveled the log to the mill, took a 2.5 inch slab, then flipped the log and did the same. The "leftover" plank in the middle ends up with a big taper. I kept the planks too for trail planks over wet spots.
    The outside dimensions are 16x16 and the beds are 3 feet wide and 2ish feet tall, the bed in the middle is 6x6, leaves a 2 foot path. The bottom foot of dirt is fill from when the state dug out the ditches along our road, the top foot of dirt is a mix of a tri axle load of loam and some bagged raised bed mix I bought at feed and seed.
  11. Chaz
    Chaz
    Southwestern NY
    Looks great, and dog approved.
    :yes:
  12. Well Seasoned
    Looks great! Your place is really coming around!
  13. Warner
    Warner
    Nice job on the firewood stack as well!
  14. DaveGunter
    DaveGunter
    Thanks! Now I just need a barn, and a pond, and some goats, and a bigger tractor and a...
    You notice my PA Dutch hex on the coop? You can take the boy out of PA but you can't take the PA out of the boy.
  15. Well Seasoned
    Well look at that.... hey I want one now! Order online?
  16. cnice_37
    cnice_37
    Looks good as always DaveGunter
    The homestead is coming together nicely
  17. bogieb
    I like the "log cabin" look of those raised beds :thumbs:
  18. Chvymn99
    Thats pretty darn cool set up DaveGunter .... Lookin' good....
  19. DaveGunter
    DaveGunter
    Mrs DG is more of a gardner than me, its getting to be not so easy to get back up from being on the ground, so the raised beds were her request and I'm not a big fan of treated lumber for veggie beds.
  20. Chvymn99
    Breakfast....Black Ants..:D
