Homesteading Chicken Coop Build, Chickens, Pond, Garden & Projects
Discussion in 'Hobbies and Interests' started by Well Seasoned, Mar 25, 2018.
  1. ReelFaster
    ReelFaster
    S.Jersey
    Not sure about temps, but I think the real concern is wind. I wouldn't be too concerned with the bigger ventilation, just as long as they are out of the wind, no big drafts where they roost. They do very well in cold weather it just that wind can give them frostbite.
    My coop is a convertible, hardware cloth for a roof with some plastic lose roofing laying on top. In the summer I remove the panels completely, in the winter I cover it partially. It's under a pole barn so rain never gets in.
  2. Marvin
    Marvin
    Huntingdon, Pa
    What are you using for litter? I tried the deep litter once but had an issue with mites. I was using wood shavings from TSC though so maybe that was the problem.
    wildwest, Biddleman and ReelFaster like this.
  3. LCBug
    LCBug
    WI
    Oh, around -20 to -25 depending on wind. I have a totally different setup and roughly 35 birds in the coop. Body warmth does a good job of keeping the chooks warm enough and they get plenty to eat besides their grain ration. What variety or varieties of girls do you keep?
    bogieb, Biddleman and wildwest like this.
  4. NewYorkNewJack
    NewYorkNewJack
    10547 - Mohegan Lake NY
    Nice work
    Well Seasoned and wildwest like this.
  5. Biddleman
    Biddleman
    River Hills of Pennsylvania
    Im using pine shavings from I get from a local feed store. Knock on wood, so fsr no issues with mites.
    I have 2 golden wyndottes, 5 Jersey giants and 3 plymouth blue rock.
    I did wind up putting a wooden covering over the ventilation opening above the roosting bars. I figure it wouldn't hurt.
    Well Seasoned, Marvin and wildwest like this.
  6. woody5506
    woody5506
    Upstate NY
    Seems like people never have much issue keeping birds during the winter, and more chickens end up dying from the summer heat. I'm under the impression that my coop could use more ventilation, but so far there really has been no issues with it being overly humid or frostbite or anything else to get me worried so I'm going to leave it alone for now. I've seen figures call for 1 sq ft of coop ventilation per bird. I have a 6x8 coop that 12 birds sleep in....I certainly don't see cutting 12 sq ft of ventilation in my coop.
  7. Well Seasoned
    Sounds like you're doing good. We get pretty cold up here, but over the years there has been very minimal frostbite. I do keep the 2 windows cracked and have 2 4x8 inch ventilation covers. I close in the run with plastic in the wall to keep the wind out.
    Chvymn99, wildwest, woody5506 and 2 others like this.
  8. wildwest
    Crud, another raccoon at the coop tonight. WWW is headed out w a shotgun. This will be the 4th in ~ a year if he gets it.
  9. wildwest
    Nope, boat and coop in the way, by the time he got in position and turned his gun light they were eye to eye and he scadoodled.
  10. wildwest
    1 of 2 coons down!
    LCBug, ReelFaster, woody5506 and 4 others like this.
  11. Biddleman
    Biddleman
    Hung up Christmas present this morning. And my wife says she doesn't like chickens. :rofl: :lol:
  12. wildwest
  13. Biddleman
    Biddleman
    How does everyone keep the water from freezing in their runs/ coops? I have a bucket system with the little cups that will automatically refill. Its inside the coop and froze a couple times this year. I just take a gallon or 2 of hot water and pour in bucket and chip out the cups. Kind of a pain in the arse, but it works.
    bogieb, Chvymn99 and MikeInMa like this.
  14. DaveGunter
    DaveGunter
    We use these. Drill a hole in the side of a 5 gallon bucket near the bottom and hang the bucket then use a submersible heater.
  15. LCBug
    LCBug
    WI
    Chvymn99 likes this.
  16. DaveGunter
    DaveGunter
    I have 4 in the bucket and I’ve had to replace 1 in 5 years, and that was probably because I hit it on something when I was refilling the bucket, and it started leaking around where it threads into the plastic of the bucket. There is some spillage during use. Our coop is elevated with an attached run, the water bucket is hung under the coop, so any spillage/leakage isn’t inside the coop and the chickens have access to it 24/7. I’d be a little reluctant to use it inside a coop for fear of increasing moisture/humidity inside the coop.
    Homesteading - Chicken Coop Build, Chickens, Pond, Garden & Projects
    LCBug, Chvymn99, Biddleman and 3 others like this.
  17. Chvymn99
    I just have a Galvanized pail with a heater pan under it…. I just recently replaced the pail… but the pan kicks on at like 32F … It’s sits in my coop…. And always has… never had a issue… but I also have some air flow
  18. LCBug
    LCBug
    WI
    I have plastic waterers that are usually replaced with buckets when the cold temps hit. It'll take two buckets morning and night this year since I upped the count on laying hens. It's tempting to get another heater like that (had one years and years ago).
    A nipple waterer probably wouldn't work for me since this time of year and with the snow forecasted the birds probably won't get out until it melts. A pit run gravel for the floor but heavy clay underneath it would make a mess if it leaked at all. Dang!
    Biddleman and Chvymn99 like this.
  19. Well Seasoned
    I Built an insulated box with a flip up front door to bring the water in and out. When it's closed and the waterer is in there, there's a little cut out the girls can reach in and drink. At the top of the box, there's a hole and I have a cord dropping down in with a 40 way light bulb that keeps most of it from freezing.
  20. Biddleman
    Biddleman
    Thanks for the input. Gives me some ideas for the setup I have.
    wildwest, Well Seasoned and Chvymn99 like this.
