Chainsaw recommendations
Discussion in 'Chainsaws and Power Equipment' started by Dpopps, Jan 9, 2022.
  1. Horkn
    Yep. 56.5 cc. They had better power than the ms290 though.
    MasterMech I wasn't meaning the power to weight of my 029 super. I was talking about newer saws, as well as anything I go on to research and possibly buy. The echo 4910 is the lightest 50 cc saw out there at 10.4 lbs is intriguing. It's pretty much the same saw as the 501p but $100 less. If you want the aluminum handle of the 501p, it adds .2 lbs. Now the power of the 4910 and 501p, I haven't found it listed anywhere except that they have 22% moar powr than the old 490. The 261 is 4 hp.
    Dakota Hoarder and Eggshooterist like this.
  2. buZZsaw BRAD
    Great info there MM! I cant say a bad thing about my 290. Always started cold or hot. I cut a lot of wood with just a 16" bar. I later bought a 20"bar and was disappointed. The only issue i had was the needle bearing went, but an easy fix. Bought in 2010. Sold it in 2020 for $200. Kinda miss it in a way.
    Stephiedoll and Horkn like this.
  3. The Wood Wolverine
    Echo is down on power compared to the other 2.
    Eggshooterist likes this.
  4. Horkn
    Interesting, but inconclusive. I have a hard time believing that a healthy 501p is down that much. I have a feeling that particular saw is an outlier.
    Edit, other sites show it as about a half hp less than the Stihl 261 or 550 MK2. Apparently the mufflers on the echo are pretty restricting. 1 full HP less is definitely an outlier.
    Dakota Hoarder likes this.
  5. Andyshine77
    Andyshine77
    Cincinnati, OH
    I had the same results when I did a 50cc saw comparison about six or so years ago, timing cuts in hardwood. Echo's are fantastic saws, but they're very restricted stock, I have found this across the board with Echo saws. Sure it's always possible to get an outlier in either direction, but generally not to this extent.
    I've been through this over the past 18 years now, and some will never be happy with the the results, especially if the brand they like or own, doesn't come out on top. The results are what the are. I always reiterate speed isn't everything.
  6. buzz-saw
    buzz-saw
    Ct.
    I had a 029 super that got flattened by a falling tree ; long story but the short version is do not lend your saws out.
    Bought a new 290 to replace it and it is a turd compared to the 029. I have used it a lot and cut a ton of wood with it but there is no comparison. Still one of my go-to saws and don't know why but it is even though I have other saws that are a better choice.
    Chud likes this.
  7. Eggshooterist
    Eggshooterist
    Erff
    Very cool! I bet that tickles ya.
    Dpopps and MAF143 like this.
  8. MasterMech
    The main thing holding an MS290 back vs the 029S is the muffler. Swap or mod, and it's neck and neck. That was the case with a lot of MS vs 0xx series machines unfortunately.
    Coincidentally, it was the same story for the old CS490, a fantastic value if you were willing to modify the muffler. They were built well, but lacked power out of the box. I had one briefly, but circumstances led me to move it along since I already own a modified 261. A muffler mod was all it took to wake the 490 up. Barcroftb had one that was pretty snotty for a "stock" saw. Of course, you could take it a few steps further.....
    If that power has been found in the 4910 and 501, great. That makes competing with the 261 (a saw design that is over a decade old, with the current spec being introduced in 2016) realistic. I'd have to dissect one (let's see if I can get tossed out of Home Depot..... :dremel::rofl: :lol:) to objectively compare build quality and certainly run one (so THAT'S why the chainsaws are on the opposite side of the store from Lumber..... :picard:) to see about power differences. Echo has not made a habit of advertising power output but that's never really been their main selling point. ;)
    Horkn and Barcroftb like this.
  9. Barcroftb
    Barcroftb
    The Mitten
    I sold the cs490 and missed that saw so much I bought the cs501 to replace it. Cs490, cs501, and cs4910 the muffler mod is the same and super easy! I outline the muffler mod here in this thread:
    Echo 490
    rock solid outstanding saws!
    Horkn and Eggshooterist like this.
  10. Horkn
    Muffler mods are easy on the echos it seems, also sounds like they are set really lean on the carbs from stock. Gotta be some power in there with those 2 things fixed.
    Barcroftb likes this.
  11. Horkn
    I heard/ read that the porting on the 029super was better that the ms290. In addition to the muffler being restrictive on both. Also early 029s's were better than the later ones, power wise. Probably those early ones had the better porting?
  12. MasterMech
    Well , you'd think Stihl kept things simple in a volume-sell, farm/homeowner saw model. But early 029s were 2cc shy of the Super, and in my experience, the Super always ran better than a plain 029. Maybe some of the later 029's got the "two pill" mufflers like the MS290? That was always fixed on non-warranty saws I worked on. The early mufflers had 4 pill-shaped vents vs the two on later units. ALL of them want a 3/8" hole drilled in the dimple for a small but direct vent and the deflector edges trimmed back to create a larger final opening. Along with a re-tune.
    I wasn't taking port timing numbers on regular repairs, so I don't have any personal numbers. And most of the serious porters stay away from clamshell saws just because of how difficult they are vs a split-case design. I'm pretty sure Mastermind did one (an 029S) many moons ago. Who knows if he still has his notes though.
    Horkn likes this.
