Chainsaw Rebuild
Discussion in 'Chainsaws and Power Equipment' started by jfhrtn, Jan 16, 2017.
  1. concretegrazer
    concretegrazer
    Southwest MO
    Two questions.
    How well does that chain cut? Looks like some goofy angles going on there.
    And did you swap the intake clamp? I can't tell in the pics.
    dougand3, jfhrtn, clemsonfor and 2 others like this.
  2. 94BULLITT
    94BULLITT
    Frederick County, VA
    Atleast it is an easy saw to work on.
    Sent from my SPH-L710 using Tapatalk
    jfhrtn and clemsonfor like this.
  3. clemsonfor
    Yea you would be really mad if it was an 1127 series Stihl and you buttoned it all up and had to go back into it like this.:rofl: :lol:
  4. jfhrtn
    jfhrtn
    Wilson, NC
    I will grab a pic of the sealant when I take the head off today. This chain has also got to be replaced. The teeth are no where near a uniform angle. Looks like the when. The guys had it before me they just did some rushed file jobs to get back cutting in a hurry. I may be able to fix the teeth but not sure. I haven't gotten the intake clamp yet but that is on my to do list. I'm glad it is fairly easy to work on also. It is not a bad job tearing down and building back up
    T2 Tappin'
  5. jfhrtn
    jfhrtn
    Wilson, NC
    So when I spin the piston around the ring ends will be facing toward the intake port. That's correct right?
    T2 Tappin'
  6. clemsonfor
    Ring ENDS should not be facing ANY port!!! The arrow points foward or toward the muffler/exhaust side.
    There should be a locating down or pin in each ring Grove that the ring ends should end at. If there is no pin there turn the rings toward the side so that there not near any port.
    jfhrtn likes this.
  7. concretegrazer
    concretegrazer
    Southwest MO
    Right.
    They can face a port. Just not cross it.
    dougand3, jfhrtn, MasterMech and 2 others like this.
  8. 94BULLITT
    94BULLITT
    Take the chain to a saw shop and get them to grind it.
    jfhrtn likes this.
  9. clemsonfor
    So I stand corrected
    jfhrtn likes this.
  10. jfhrtn
    jfhrtn
    Wilson, NC
    T2 Tappin'
  11. jfhrtn
    jfhrtn
    Wilson, NC
    Does the worm gear go under or above this plate? I'm second guessing myself now and just want to make sure
    T2 Tappin'
    clemsonfor likes this.
  12. jfhrtn
    jfhrtn
    Wilson, NC
    Thank you guys for the info. Just got it spin around and there is a pin that the ring ends sit in. I may have been buying another to end if it wasn't for y'all.
    T2 Tappin'
    94BULLITT and clemsonfor like this.
  13. jfhrtn
    jfhrtn
    Wilson, NC
    There is indeed a pin that ring end sit in. He is a pic of the pin on the piston
    T2 Tappin'
    concretegrazer and clemsonfor like this.
  14. jfhrtn
    jfhrtn
    Wilson, NC
    The muffler gasket goes against the cylinder head right? It doesn't go in front of the heat shield I don't believe just wanted to double check. Second guessing a lot and just want to make sure everything in the assembly goes right
    T2 Tappin'
  15. clemsonfor
    Yep so when rings against that pin arrow pointed foward or to exhaust they will be loacated in the correct location.
    jfhrtn likes this.
  16. jfhrtn
    jfhrtn
    Wilson, NC
    The pin is on the opposite side that the arrow is on. What are your thoughts on the worm gear and the muffler gasket?
    T2 Tappin'
  17. clemsonfor
    Gasket goes against the head i am pretty sure. Only makes sense as the shield would not seal well.worm gear i am not sure. All id do is grab the IPL and look
    jfhrtn likes this.
  18. 94BULLITT
    94BULLITT
    Worm gear on the outside.
    Heatsheild then gasket then muffler
  19. clemsonfor
    That makes more sense, I was second guessing. Heat shield on first to protect the body and everything from heat. Thanks bullit
    jfhrtn and 94BULLITT like this.
  20. jfhrtn
    jfhrtn
    Wilson, NC
    Thank you guys/gals. I got her back together and right this time thanks to the help from y'all Kinda stupid question here probably but what if you ran an exhaust gasket on either side of the heat shield? Just to ensure proper seal for the gases to exit the muffler?
    T2 Tappin'
