Chainsaw Rebuild
Discussion in 'Chainsaws and Power Equipment' started by jfhrtn, Jan 16, 2017.
  1. The Wood Wolverine
    clemsonfor likes this.
  2. 94BULLITT
    94BULLITT
    Frederick County, VA
  3. clemsonfor
    For just the little bit more the ebay kit seems like it makes sense. Cause baileys will hit you up on shipping unless there still on $99 free ship
  4. jfhrtn
    jfhrtn
    Wilson, NC
    Thank you for the links guys. I may not order from Bailey's if they have had breaches in the past. Unless they upped their security after the breach. $160-170 from Simonians Saw isn't a bad price at all considering he includes everything
    T2 Tappin'
  5. clemsonfor
    Honestly anywhere can be breached. Our higjest government agancues are hacked sometimes so it happens to everyone. A good CC company us on too of it and your not liable for it
  6. 94BULLITT
    94BULLITT
    Why does everyone use the cylinder with the compression release hole then most of the time it gets plugged?
    Kyle Mulligan and clemsonfor like this.
  7. dougand3
    dougand3
    North Alabama
    This shows how Poulan does the bottom end.
    concretegrazer and 94BULLITT like this.
  8. 94BULLITT
    94BULLITT
    That is how stihl does them.
    Sent from my SPH-L710 using Tapatalk
  9. jfhrtn
    jfhrtn
    Wilson, NC
    clemsonfor the eBay kit is really like the way to go. So true on breaches though. Anywhere can be breached given the right fingers are on the keyboard.
    94BULLITT the compression release is just for easier cranking right? I haven't ever had a problem starting a saw without one. My new huskie has one but I don't see me using it unless I hurt my shoulder maybe.
    dougand3 with that setup couldn't you assemble the power plant then just bolt it down or is like building a huskie?
    T2 Tappin'
  10. clemsonfor
    You don't really need a compression release till your in 80+cc territory. Well that also depends on your age and strength I guess.
  11. clemsonfor
    I was going to say the exact same thing
  12. dougand3
    dougand3
    North Alabama
    Re: building a 345 on a Poulan Strato chassis...
    Yes, possibly. The bottom end config of metal clamshell pan vs chassis formed clamshell doesn't matter if bolt holes line up. But other factors to consider...are crankshaft and con rod the same? And intake parts and muffler will be different. And if flywheel fits, will timing work? Will clutch and sprocket fit? If you have to change many of these parts, it's financial folly. I'll just have to leave 5x Poulan chassis in the parts bin. Maybe the Chinese will make a strato Poulan topend for cheap at some point. Even tho the Poulan is a competent 42cc saw, it has a bad rep and only fetches $65 in great running condition. You need the name Husqvarna or Stihl when selling used.
  13. clemsonfor
    Antivibe is bad on old ones, not sure of new ones?
    The Wood Wolverine and dougand3 like this.
  14. dougand3
    dougand3
    North Alabama
    Some of the newer ones do have spring AV from top cyl to handlebar and bottom of handlebar to chassis but it isn't great. Now, most of the 1990-2005 Poulans have no AV. You'd be a jiggling if trying to buck 16" logs all day. I think of these saws as limbers - WOT for 10", idle, WOT 10", idle, etc. No biggie in that use.
  15. clemsonfor
    That's about what I use my cheap china saws (earthquake ) for, but their Antivibe is amazing compared to poulan. First time I really used a Poulan after having better saws I could even feel vibrations when cutting small branches! Haha
    dougand3 likes this.
  16. jfhrtn
    jfhrtn
    Wilson, NC
    Hey y'all sorry about the long delay in posts. I've been slammed at work. Good news on the rebuild though. The mechanic checked out the saw and said everything was in working order for another top end. While I was at the shop I checked prices and for an OEM 345 C&P I got got a quote for $89 plus tax. It's not the 346xp top end but I couldn't pass up the $89 deal. It is on its way and they will be calling me as soon as it comes in. I'm looking forward to this build.
    -Rick
    T2 Tappin'
    94BULLITT and clemsonfor like this.
  17. clemsonfor
    So all this conversion talk was for naught! Ha. At least it's here and someone searching on it will see all that info in one place
  18. The Wood Wolverine
    Yep, at least he'll have one good Husky.
    jfhrtn, clemsonfor and dougand3 like this.
  19. 94BULLITT
    94BULLITT
    Thanks, for updating. At $89 for the cylinder you will have a cheap good running saw. I think if you hang around this forum much you will regret going with the 345 cylinder. You can get that kit on ebay for $150 that basically turns it into a 346 which whill perform way better. It is really worth the extra money. The will probably also have a better resale value with a 346 cylinder on it, at least to someone like me. I would see if you can cancel the order and get a 346 cylinder on the way, tell the dealer you changed your mind.
  20. dougand3
    dougand3
    North Alabama
    I agree with others....get the 346xp topend. For a 345, I'd just get the $20 topend on ebay.
