Chainsaw Rebuild
Discussion in 'Chainsaws and Power Equipment' started by jfhrtn, Jan 16, 2017.
  1. The Wood Wolverine
    Yes there are. I'll find you a link. Till then, we like this style.
    (Pick is DexterDay's). It can get your wood hot (lol), but it allows the hot gas a direct escape route.
  2. concretegrazer
    concretegrazer
    Southwest MO
  3. The Wood Wolverine
  4. jfhrtn
    jfhrtn
    Wilson, NC
    I appreciate the link. Not sure if I could do the gills without the exhaust being put on the plastic. I like the idea though. The front cutout would be a good idea even though it can roast your wood while cutting haha. I don't have a welder to weld a pipe exhaust on but I'm sure I could find a local exhaust shop to weld it on. I'll post a pic of the front view of the muffler below. What would be your opinion on a preferred type of muffler mod? I can see where power gains might be achieved by getting the exhaust out quicker and letting everything run cooler.
    T2 Tappin'
  5. concretegrazer
    concretegrazer
    Southwest MO
    I'd open it up on the right side. There's some examples on page 3 of my link.
    clemsonfor likes this.
  6. The Wood Wolverine
    Similar saw, same muffler, this is what my son did to his Jonsered 2150. He does have the bracket on it now too.
    clemsonfor and Kyle Mulligan like this.
  7. jfhrtn
    jfhrtn
    Wilson, NC
    Would y'all take a cut off disc on an air tool and cut the slots then use flat head to bend them out? What would be the proper way?
    @TheWoodWolverine thanks for the pics
    T2 Tappin'
  8. jfhrtn
    jfhrtn
    Wilson, NC
    Also would you leave the top exhaust hole on the muffler?
    T2 Tappin'
  9. The Wood Wolverine
    I always leave the original opening as is.
    Use something to pry against so you don't push the other side down.
    Cut off wheel in the dremel works good.
  10. jfhrtn
    jfhrtn
    Wilson, NC
    Thanks for those pics The Wood Wolverine
    What kind of gains do you normally see from the muffler mod? Kind of like what you see from going stock manifold to headers on a v8?
    T2 Tappin'
  11. MasterMech
    Just like the headers, it all depends on how bad the stock exhaust was. Something like a Stihl MS290/390, is going to be a night and day difference. The newer saws from Stihl tend to have less restrictive mufflers so not such obvious gains there.
    I would imagine yours would respond nicely.
  12. clemsonfor
    Dex must be into orange saws these days
    jfhrtn likes this.
  13. jfhrtn
    jfhrtn
    Wilson, NC
    I think I may try to get the mod done today. Would y'all open it up on top or would you open it up on both sides of the muffler?
    T2 Tappin'
  14. jfhrtn
    jfhrtn
    Wilson, NC
    Maybe open it up on the bar & chain side of the muffler?
    T2 Tappin'
  15. jfhrtn
    jfhrtn
    Wilson, NC
    Open it up where the circle is with maybe a 1-1 1/2" slot?
    T2 Tappin'
    Kyle Mulligan and clemsonfor like this.
  16. clemsonfor
    I'd widen the top to the whole size of the deflector or close to it and then open up the B and C side with gills or another deflector and drill a like 3/8 or half inch hole there at least.
    What I have heard is your trying to get close to 80% of the exhaust port area in muffler outlet area. Or basically east holes equal 80% of cylinder ex port size. Some say up to 100% but I think that is for a bit more higher performance saw than you have. Haha
    There is rumors of a video somwe here of Drad Snelling running DexterDay house with the front cover off his muffler!!:eek:
    I know it happened I just haven't seen the video!!:D
    jfhrtn and concretegrazer like this.
  17. concretegrazer
    concretegrazer
    Southwest MO
    I'd start there. Be sure to clean the muffler out when your done. & retune.
    clemsonfor, Kyle Mulligan and jfhrtn like this.
  18. concretegrazer
    concretegrazer
    Southwest MO
    Fixed. ;)
    DexterDay, clemsonfor and jfhrtn like this.
  19. jfhrtn
    jfhrtn
    Wilson, NC
    I appreciate that info. Does the deflector come off pretty easy? I don't have a Dremel just a cut off tool for the air compressor. I could maybe drill 4 small holes and the use the cut off disc to connect them. I can open a 1-1 1/2" slot on the b&c chain side no problem I believe to achieve the 80% size of the exhaust port
    T2 Tappin'
  20. jfhrtn
    jfhrtn
    Wilson, NC
    So start with a 1 1/2" gill on the B&C side and then retune after the mod. By cleaning out you mean with compressed air or with some carb cleaner/gas?
    T2 Tappin'
