Chainsaw Pics...
Discussion in 'Chainsaws and Power Equipment' started by the GOAT, Oct 5, 2013.
  1. Eggshooterist
    Eggshooterist
    Erff
  2. Czed
    Czed
    Wv
  3. Nixon
    Nixon
    West Sunbury,Pa .
    This is a 350/346 thar I had Stump Shot do porting and some machine work on . Should be a great light saw gonna run 20” .325 nk bar and chain on it . 9748BC67-8F8A-4B35-BD0C-4E8D0E389CDC.jpeg 34EF3198-2083-4311-92E1-E11705B78C46.jpeg
    Screwloose, KSPlainsman, RCBS and 6 others like this.
  4. Nixon
    Nixon
    West Sunbury,Pa .
    And , this is a torn dow 10mm 044 that eated it’s bearing retainer . All the parts to reassemble it are on order .OEM except the piston ,which will be a Meteor . When all the parts show , it’ll be making a trip tp Stump Shot Saws .
    Still debating on just leaving it well worn looking , or not .
    Screwloose, KSPlainsman, RCBS and 4 others like this.
  5. Eggshooterist
    Eggshooterist
    Erff
  6. Eggshooterist
    Eggshooterist
    Erff
  7. JimBear
    JimBear
  8. JimBear
    JimBear
  9. Sawdust Man
    Sawdust Man
  10. Eggshooterist
    Eggshooterist
    Erff
    Yep. Electrolux fan boys....
    Screwloose and JimBear like this.
  11. Eggshooterist
    Eggshooterist
    Erff
    Thanks mang. It was supposed to be going to saw fest as a poulan wild thing to maybe trigger some peeps but I couldn't get the dye the right color. So STEERE it is.
    And no, I'm not right. have my own drummer that I march to for sure. :loco: :crazy:
  12. Eggshooterist
    Eggshooterist
    Erff
    That's a fact. Lol
  13. Eggshooterist
    Eggshooterist
    Erff
    It didn't show up in the pics but it has several coats of this on the entire saw. A couple more since these pictures.
    IMG_20230408_130128106~2.jpg IMG_20230408_161118127~2.jpg IMG_20230408_161133766~2.jpg
    Vagazzled.....
  14. Czed
    Czed
    Wv
    Steve does great work
    my stumpshot 266 is still my favorite saw
    It has like 230# compression and has cut hundreds of tree's
    I own or have access to just about every Husqvarna professional saw you can think of
    And I always go back to this 1984 266se on it's original bearings.
  15. Stephiedoll
    Stephiedoll
    Omaha, NE.
    X2!
    Screwloose likes this.
  16. Nixon
    Nixon
    West Sunbury,Pa .
    Steve is definitely one of the good ones ,Must be a Wisconsin thing … I’ve told him not to go real crazy on the 044’s compression . I figure that between it not having a Texas button , and me being 75 , 200-210 should be sporty enough .
    I have a MS461 he did ,and even with the button pushed , you best pull it like you mean it . Sweet saw to run .
  17. huskihl
    huskihl
  18. RCBS
    RCBS
    Over here
    Having recently started using one of these it's hard for me to think it needs moar power. lol Maybe he's running a 36 on it? I like that muffler. Is it a 6410 muff or did you remove the 'crack pipe'? I put a 6410 muffler on mine before I ever gassed it. I have another one of these hidden away (PRZ2). Maybe I'll get a wild hair one day and send it out.
  19. huskihl
    huskihl
    It is the standard muffler that comes on the newer Makita 7900. The back half is normal stainless. The front half is something goofy that I can’t make heads or tails of. Looks like aluminum, it’s magnetic, can’t silver solder it without rubbing bronze brazing rod on it to scratch the surface a little bit. Yet I can’t braze it with standard bronze rod either.
    Tucker already had split the muffler and removed the crack pipe. All I did was open up the OEM location and added the second deflector on the recoil side with large weave screen in both.
    Screwloose, RCBS, Buttermilk and 3 others like this.
  20. Czed
    Czed
    Wv
    I've shattered 2 recoils so far
    I'm trying to stock up on them.
    Screwloose, Nixon and eatonpcat like this.
