Chainsaw Pics...
Discussion in 'Chainsaws and Power Equipment' started by the GOAT, Oct 5, 2013.
  1. Chvymn99
  2. buZZsaw BRAD
    Ah hah! Its the Christmas gift for your secret Santa victim! :santa: :saw:
  3. Sawdust Man
    Sawdust Man
  4. The Wood Wolverine
    Starts with a 5 and ends with a 2?
    M2theB, Screwloose and Chvymn99 like this.
  5. Chvymn99
    No just for me... for all the hours I've been putting in... I've got two jobs that will probably require it...
  6. JimBear
    JimBear
    Well, as a matter of fact I do have a cigar so :p
  7. buZZsaw BRAD
    So you pulled your own name out of the hat? It could happen. :D
  8. Chvymn99
    Here’s one more hint…
    M2theB, huskihl, T.Jeff Veal and 3 others like this.
  9. The Wood Wolverine
  10. JimBear
    JimBear
    Is that a 3120 ? The only hooskie I have ever seen in person is a 357 or 359.
  11. Sawdust Man
    Sawdust Man
  12. buZZsaw BRAD
    Dang, talk about a let down! :picard: I was hoping Stihl!
    M2theB, T.Jeff Veal, Haftacut and 4 others like this.
  13. Chvymn99
  14. The Wood Wolverine
    She's a beaut Kevin!!! Congrats.
    M2theB, T.Jeff Veal, Haftacut and 2 others like this.
  15. buZZsaw BRAD
  16. Chvymn99
    I’ve had a 660… it was alright… but from research this had what I wanted…. The only downside will be learning the outboard clutch… which is why I got rid of my 562 husky…. But time will tell.
  17. The Wood Wolverine
    The 394 came out in 91, had a 10 year run (I believe) and in 01, they put a quad port cylinder on the same crankcase, along with a rubber intake boot instead of the resin block and called it a 395. It's been a good run for one of Husky's all time greats.
  18. Sawdust Man
    Sawdust Man
    Outboard clutches are way outdated imo.
    But 395's are great saws just the same.
    T.Jeff Veal, Screwloose and Chvymn99 like this.
  19. buZZsaw BRAD
    am i thinking of a 592. that and a 585 the most recent???
  20. The Wood Wolverine
    I can tell you one scenario that can be very frustrating with the outboard. IF you try to run Stihl mount bars, normal drive link chains will only work if you pull the clutch to slide the chain on. You'll have to add a driver to make it seamless. I borrowed 50" Stihl mount Cannon and chain to mill a big maple. That's the only way I could get the chain on the saw.
    Overall I'd like inboard better as my 365 has one, EXCEPT milling. It's better to have clutch heat out of the case and away from the seals. :yes: The other negative is that tensioner location. I wish someone would come up with an adjuster on a clutch cover.
