Chainsaw Pics...
Discussion in 'Chainsaws and Power Equipment' started by the GOAT, Oct 5, 2013.
  1. Sawdust Man
    Sawdust Man
  2. Eggshooterist
    Eggshooterist
    Erff
    Not a saw but I thought some might like to see how bad ethanol laced fuel is for an engine if left unused for too long. No idea how long or what mix oil was used.
    IMG_20220526_121455623~2.jpg IMG_20220526_121440161~2.jpg IMG_20220526_121436915~2.jpg
  3. LordOfTheFlies
    LordOfTheFlies
    NY
    How do you like that Holtzforma 372xp pro? 20" bar on there? What gauge chain are you using? .050" or .058" or .063"? Not sure why they recommend the .058". Also I noticed it's quite a bit heavier than a 372xp (14.6lbs vs 19.8). That's a huge difference. 35% increase in weight.
    metalcuttr, eatonpcat and Screwloose like this.
  4. M2theB
    M2theB
    Central Massachusetts
  5. Sawdust Man
    Sawdust Man
    So far so good, I've only got 1 tank of fuel thru it at this point.
    I'm using a 24" bar w/ 3/8" .050 full chisel chain.
    It's the same weight as a real one... I have no clue as to why they advertise the weight at 19.8lbs...... metric pounds maybe?
    My impression at this point is, that it starts easy (usually 3 pulls cold), it runs very smooth, and has the power you'd expect from a 70cc saw.
    The gas cap was poop right outta the box, so I replaced it with a Hyway cap which seems to be working fine.
    Overall I like it pretty fine, I've owned a real 372 since 2007, so I do have some point of reference to judge this saw against.
    Other than the "country of origin" I don't have any real complaints......
  6. Chud
    Chud
    NC
  7. M2theB
    M2theB
  8. LordOfTheFlies
    LordOfTheFlies
    NY
    You weighed them side by side? If so that is super weird.
    Also is it a "real" Walbro carb included in there? Did you happen to tear it down when you received it or just let it be and started using it?
  9. acknative25
    acknative25
    Martha's Vineyard
    Letting the 026 eat some dead standing oak from the neighbor, with help from my ground crew.
    7A8E3226-E576-4053-9D86-576A16FF87B9.jpeg 7D26CC28-B2AB-46D3-965E-234877A01D9D.jpeg 245FD9EB-BEDF-40C0-A222-D26CEF6074E2.jpeg
  10. eatonpcat
  11. Sawdust Man
    Sawdust Man
    I weighed it right out of the box before adding fuel/oil. 14lbs 9oz.
    Here's a few pics of the carb, I'm not an expert on walbro, so idk. IMG_20220529_122839.jpg
  12. Sawdust Man
    Sawdust Man
  13. LordOfTheFlies
    LordOfTheFlies
    NY
    I'm not an expert either but it looks ok to me.
    Thanks for the pics! Appreciate it.
    Screwloose and Sawdust Man like this.
  14. lukem
    New bar for the 362.
  15. Czed
    Czed
    Wv
    I bought some of those chusky 365/372s
    About 5 year's ago
    I have too many saws setting around so I loaned the bat country one's out my nephew had this one
    He must've run drip gas and walmart super tech mix in it
    As bad as it smells.
    Still runs good 180# comp with a hyway popup
    They weigh the same as my oem 375/371/372s
    Only issues I had was crap fuel and impulse line's.
  16. Rickyblazin
    Rickyblazin
    Pottstown PA
    Got my new born daughter her first saw! Once she gets old enough will have a real saw for her image.jpg
  17. Chud
    Chud
    NC
    Used these two today on the dirt wood pile
  18. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  19. M2theB
    M2theB
    Dakota Hoarder and Screwloose like this.
  20. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Just came in...bunch of ms250,045,030,026,couple husky 51,echo 440,mostly not interesting junk
