Chainsaw Pics...
Discussion in 'Chainsaws and Power Equipment' started by the GOAT, Oct 5, 2013.
  1. T.Jeff Veal
    :rofl: :lol::rofl: :lol:
  2. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    6AD932D0-27B9-45D2-A612-97AB250231C5.jpeg 49320F75-8F47-4E87-8BD0-43E061076E9D.jpeg C715CFA6-01CC-4DA4-8EC2-2B135C11507B.jpeg
    Any body ever mess around with one of these? Scored this at an auction last night for practically nothing, so I can stand to put a little money into it. What is the little adjustment thing in the bar?
  3. Nixon
    Nixon
    West Sunbury,Pa .
    Bar tensioner . Simple saw to work on . What caused the scoring is Likethe impulse tube . PN 530053435 .It’s a little green piece of silicone tubing . tends to crack right next to the intake boot . Cost about $3 .If I get a saw in here with that inlet /impulse set up , I change that tube even if it is not yet cracked .
  4. M2theB
    M2theB
    Central Massachusetts
    You think CAD is tough,,,
    You’re about to get WOYB if you’re not careful!
  5. Sandhillbilly
    Sandhillbilly
    WOYB ???
  6. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    im in the dark too
  7. M2theB
    M2theB
    What’s on your Bench!
  8. M2theB
    M2theB
    That’s how I get most of my saws and fund the next purchase.
    It’s a break even venture for me.
  9. Nixon
    Nixon
    West Sunbury,Pa .
    You definitely gots Some of that WOYB . But it’s not to bad yet .... There’s only one saw on the bench all torn down . :D
  10. M2theB
    M2theB
    True. I try to keep it to one at a time. I had an 064 there when I can across this 075AV. Boxed the 064 for now and started in on the 075.
    Cleans up pretty good.
  11. Sandhillbilly
    Sandhillbilly
    So I checked out my auction 137 this evening. It looks like it can be put Back in service without to much major. Spur sprocket is plum wore out as are most of the drive lugs on the chain & probably put a new bar on while I’m at it. Piston looks pretty fair. Needs a couple AV mounts & a choke pull rod.
    But talk about an over engineered muffler!!!!:picard: Not sure I really figured where the exhaust is supposed to exit!
    It looks like there’s an aftermarket p/c kit with a larger displacement..... any body know anything about that.
    I know these aren’t much for saws, but this will be my first project saw and I figured it is a good place to start learning to make em better
  12. Nixon
    Nixon
    West Sunbury,Pa .
    The exhaust exits onto the cylinder heat shield right where it wraps around the muffler on the clutch side . The hole is very tiny ,and it’s hard to believe the saw can run . As to AM cylinders , try hlsproparts.com , or sawsalvage.com . I’ve had good luck ,and great service from both .
  13. Sandhillbilly
    Sandhillbilly
    Thanks, I seen the one at HLSupply, probably the way I’ll go. Could you tell a difference between it and stock?
  14. Nixon
    Nixon
    West Sunbury,Pa .
    The ones I have used were from Stihl saws . And , they were saws that I never ran before. So, I could not give you a comparison . The saws did ,however run well . The owners have been running the for a good while without complaint . I will say this , use OEM ,or meteor piston wrist pin circlips . And oem impulse boot .
  15. T.Jeff Veal
    Buzz Benton Finally got some big oak logs out so I could run the 32" bar amd tune the saw to the DP muffler.
    Did better on the next log
  16. Brandon Scott
    Brandon Scott
    Formerly Rabbit Hash
    “He’s too sexy for his shorts...
  17. T.Jeff Veal
    :rofl: :lol::rofl: :lol::thumbs:
    Brandon Scott likes this.
  18. Stephiedoll
    Stephiedoll
    Omaha, NE.
    Threw up some shelves after work today.
    Ronaldo, Nixon, Sandhillbilly and 6 others like this.
  19. Nixon
    Nixon
    West Sunbury,Pa .
    Just a guess ,and prediction ..... But, if you are like most of the rest of us here , You will need a bigger set of shelves in a surprisingly small amount of time . :rofl: :lol:
  20. Sandhillbilly
    Sandhillbilly
    There’s already one more on the way, from what I understand
