Chainsaw Pics...
Discussion in 'Chainsaws and Power Equipment' started by the GOAT, Oct 5, 2013.
  1. M2theB
    M2theB
    Central Massachusetts
    02F5D6D3-7CB4-418C-B571-87CC3C596EFB.jpeg 71AB4A49-7BD8-4DA8-9F04-841BE33EB276.jpeg FB86F99A-7EF5-4EBC-8EA4-718D12984FB5.jpeg 8277E75D-C231-4C18-A5BA-2D0F5AAD057A.jpeg I got this one today in You Suck deal.
    Guy bought it to mill, got it started, shut it off and couldn’t start again.
    Said the shop told him the seals are gone and couldn’t be replaced. In essence he was selling the new bar and chain and I could have the saw too if I wanted it. Haven’t poked at all. It does feel like a lot of compression.
  2. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    pull the muffler dood!!!:banana::banana:
    Brandon Scott and M2theB like this.
  3. M2theB
    M2theB
    Did it. Had to cook the kids steak first.
    It’s not pretty. I’ve seen way worse.
    And smell bad gas and see an ultra shiny exhaust.
    tamarack, Dancan and Brandon Scott like this.
  4. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  5. M2theB
    M2theB
    Yeah, but it’ll be ok someday.
    Still hold decent compression.
    Cool to see a metal intake!
    Dancan, Czed, eatonpcat and 1 other person like this.
  6. James Miller
    James Miller
    Hanover PA
    20190607_090344.jpg Can't remember if I posted picks of this yet so here it is. Runs on a shot down the carb.
    tamarack, Dancan, Czed and 6 others like this.
  7. Czed
    Czed
    Wv
    266xp 20190710_184715.jpg i just got from a member on ope all new rebuild bearings,seals,meteor,caber
    Fuel line,carb kit etc.
    190# comp excellent runner he opened up the exhaust and worked on the transfers
    Strong saw
    Pulls a 24" in hardwood great.
  8. M2theB
    M2theB
    67E5CB48-D062-4784-BCAB-0E2562F2F25C.jpeg Got this one on the bench. Cylinder looks toasty and has 120psi.
    Pressure and vac are tight. Hoping bad gas failure and cylinder can be cleaned.
  9. dall
    dall
    West Virginia
    pictures of the piston
    bad gas or straaight gas it will be scored all the way around and also some detonation
    M2theB, PA Dan and Brandon Scott like this.
  10. PA Dan
    PA Dan
    White Oak Pennsylvania
    Welcome to the forum buddy I'm Dan you may or may not like it here. Depends on the day!
    Brandon Scott likes this.
  11. Redfin
    Redfin
    central Pa
    Piston looks serviceable. No good new oem options. Pull the jug.
  12. M2theB
    M2theB
    On the list to do. Can’t build any pressure right now on pressure test. Not seeing any leaks on clutch side seal. Waiting on ups and a flywheel puller to check that side and deal with the seals. I think I can use 288xp seals on this engine.
  13. M2theB
    M2theB
    0FACFE08-6CEC-4E08-940C-D15F3EB4C4D2.jpeg 28C00A33-13F5-4BE2-99A3-86479A90EEDB.jpeg
    Not all the way around but heading that way. I’m going with bad or strait gas.
    What do you mean detonation?
    What’s different to me is that bronze colored coating of fuel mix on the crank. Wipes right off.
    Cylinder looks worse than it feels. I’ll see how it cleans up.
    Stihl saws are a rubic’s cube to work on.
  14. dall
    dall
    West Virginia
    detonation is little pits on top of the piston and in the squish area
    what is in the crank pan ? looks kinda milky like oil and water mix
    M2theB and Brandon Scott like this.
  15. M2theB
    M2theB
    Negative.
    Dry
  16. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Clean 361 I ported,dual spikes,dual port muffler with spark screens 20190721_125149.jpg
  17. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  18. M2theB
    M2theB
    Broke a chip off this barrier.
    Don’t ask how.
    Is this a death blow for this saw?
    ChipsFlyin and Brandon Scott like this.
  19. kas
    kas
    Shelton Ct.
    60 millimeter Dolmar project.
  20. dall
    dall
    West Virginia
    i think it will be fine
    huskihl and Brandon Scott like this.
