Chainsaw Pics...
Discussion in 'Chainsaws and Power Equipment' started by the GOAT, Oct 5, 2013.
  1. buZZsaw BRAD
    rebuilding them not my thing. Sentimental value.
    M2theB, Brandon Scott and J. Dirt like this.
  2. J. Dirt
    J. Dirt
    :yes:
    M2theB and Brandon Scott like this.
  3. buZZsaw BRAD
    if and when you rebuild it, will you make it like factory fresh or make a ported saw/muffler mod etc?
  4. J. Dirt
    J. Dirt
    Probably stock for the most part.
    M2theB, Brandon Scott and eatonpcat like this.
  5. M2theB
    M2theB
    Central Massachusetts
    I decided to go into this 026. 70 psi but otherwise a pretty clean saw.
    P/C toasted.
    One of the first thing I found was that the intake clamp was backed off/loose. I’m hanging my hat on that one.
    All the rubber is good.
    Waiting on the Meteor delivery man now.
    This pic shows that for this carb the H and L only have one adjustment, but the case allows for a fully adjustable. Carb on it is a WT430B
  6. Czed
    Czed
    Wv
    Building a 266se into a 268xp i don't have a 266 cylinder.
    Using the complete cylinder intake carb etc.
    And a hyway 268 pop-up with a caber.
    New fuel line seals carb kit etc. 20190630_121931.jpg 20190630_122137.jpg 20190630_185516.jpg 20190630_190514.jpg
    Hoggwood, Monster80, tamarack and 8 others like this.
  7. Czed
    Czed
    Wv
    That's one of the best saws ever made
    Stock or even better ported imho
  8. Czed
    Czed
    Wv
    Cutting dead ash for a neighbor 20190626_182531.jpg 1986 266se all original still 190 comp
    Fuel line and carb kit was all it needed.
  9. Czed
    Czed
    Wv
    2000 288xp lite my brother bought new
    I rebuilt it with a meteor a caber
    New seals line's etc. 20190625_181934_HDR.jpg 20190625_184718.jpg ported 2165
    Put new tsumuras and archer chain on both
    After a handfile the archer cut's great.
    ChipsFlyin, Dancan, Hoggwood and 8 others like this.
  10. M2theB
    M2theB
    CCF5B82F-A2F4-4A48-80A3-B44ACB3A89ED.jpeg 86E9F411-7258-47D3-8144-30B5F79737B7.jpeg Good numbers on this 026
    Has 021 squish with the .5mm gasket and layer of motoseal
    Passes pressure and vacuum test.
    ChipsFlyin, Dancan, eatonpcat and 4 others like this.
  11. bigfrank
    bigfrank
    NorCal
    Picked up a Husqvarna 268 at an online auction a week or two ago. Looked rough, and I couldn't pull the handle before buying. I took a chance and it seems to be good. Needed a few things and lots of cleaning up. Here are a few before and after pics. It seems a bit touchy when adjusting the carb, so I may throw a kit in it, but for now, I'm going to run it awhile and make that decision later.
  12. Erik B
    Erik B
    Western Wisconsin
    That cleaned up great. Good job.
  13. M2theB
    M2theB
    A60A5C83-9DA2-4FE8-9A49-777CD25FE9C0.jpeg 026 in the field, clearing some trail this morning.
  14. farmer steve
    farmer steve
    top of the hill york co. PA.
    ya took the best saw on your list today. :thumbs: :rofl: :lol:
  15. dall
    dall
    West Virginia
    lol he wanted to make sure it lasted the whole time cutting lol
  16. The Wood Wolverine
    You must have picked up the wrong stuff at market.
  17. M2theB
    M2theB
    It was the best one I had in the woods!
    I actually did enjoy it. Went back out this afternoon on some 15” maple and it was impressive.
  18. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    You should try one ported
  19. M2theB
    M2theB
    1647A8FB-DE49-4CF5-9C06-23D386B5E90B.jpeg 9B9767C6-36E4-4F97-AB61-4A1DB2DA0DED.jpeg
    I bet.
    This one is pretty tight.
    I did give it a little breathing room.
    ChipsFlyin, Dancan, Ronaldo and 3 others like this.
  20. Hoggwood
    Hoggwood
    Southern BC
    Ran a couple yesterday with one of my daughters along for the ride. Gave the cs-500vl a full workout. Pulled like a champ. Even got to hang out with the bighorns for a while.
    Just ripe for the picking.
    Smelling fine.
    I run into these fine creatures regularly. A couple of nice big herds on the way up to where I cut.
    More candy for the 2021 pile.
    Cheers folks.
