Chainsaw Pics...
Discussion in 'Chainsaws and Power Equipment' started by the GOAT, Oct 5, 2013.
  1. Hedgerow
    Hedgerow
    SW Missouri
    028 buildoff saw is almost done... Time to experiment with different carbs...
    It just has the crappy .325 bar and chain it came with right now... I'll break it in, then outfit it with a 16" 3/8, like it was meant to have... :yes:
    At least the oiler works decent on this one...
  2. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    How about some Poulan Pro 655's? The rear saw is actually a Pioneer P-65.
  3. thistle
    thistle
    Polk/Guthrie Counties,IA
    Taking a break yesterday afternoon. Cleaned it up a bit.Trusty mid '70s 10-10 Automatic.Snarky little 12.5lb beast with loads of torque.Will outcut a newer Stihl 290 Farm Boss or Husqvarna 455 Rancher of similar displacement & weight. :saw: Need to get a spike for this & its 7-10 big brother someday soon.
      File size:
      140.3 KB
      7
  4. GrJfer
    GrJfer
    The Woods of Arkansas
  5. MasterMech
    One day, when this red saw itch is scratched, I'm gonna have to try me a couple of dem yaller saws...
    thistle likes this.
  6. thistle
    thistle
    I got a couple big Homie's on the want list,may not still be strong enough to run them once they finally are in my possession,but I'll cross that bridge once I get to it. :cool:
  7. MasterMech
    Yellow ones are hard to find out here as this is Homelite country. (They were built here in NY)
    I got time. :smoke:
  8. thistle
    thistle
    Yellow & red ones both are scarce in my area (except for the occasional late model plastic junk) & especially anything bigger than 60cc.Nice older Poulan's pop up from time to time,not the 70cc+ ones that I'd be interested in unfortunately.
  9. Unicorn1
    Unicorn1
    Amarillo, TX
    I'm looking for another 1050 Auto if anyone finds one.
  10. thistle
    thistle
    The screamer back to life...... :saw:
    Back when Poulan made only farm/ranch & pro duty saws & not the light duty plastic homeowner crap you see today....1981 56cc screamer,after 100+ cords,7 bars,2 spark plugs,2 clutch sprockets,3 air filters & 30+ full chisel 20" chains hand-filed to nothing,it was basically ''retired'' in 2002ish.Would get it out for kicks once in a while.Now has new fuel lines/filter,retuned carb.You wont find a newer Husqvarna 455 Rancher or Stihl 290/291 Farm Boss of similar displacement that will out cut this thing.
    Only 12.5 lbs,all magnesium case,automatic oiler w/ manual override,full anti-vibration rubber mounts,chrome plated cylinder/dual thin piston rings for more RPMs,after all those years of abuse the compression is still 150+ PSI.
    The saw I cut my teeth on,so to speak,all those years ago.Nice to have it back again.
  11. Cut4fun
    Cut4fun
    OHIO Redneck
    Even PHO with no mix or oil that weight is way off. Have weights with plastic or mag cover and weights with chain brake or without. Which do you have? They are all over 14lbs to 15lb range.
    p61 western and Motorhead like this.
  12. thistle
    thistle
    Mine has no chain brake,never had one.Only plastic hand guard.Mag starter,plastic top covers,mag clutch cover.13 pounds on accurate bathroom scale,I don't have a digital one.
    I see that's a 3700 in the photo,that's 3.7 cid,right? Unless its a 3700 starter housing on a 3400.....
  13. Cut4fun
    Cut4fun
    OHIO Redneck
    3700 3.7 bigger bore.
  14. Cut4fun
    Cut4fun
    OHIO Redneck
    Even paper specs show 13lb 8oz for 3400 3700 4000. None are that actual.
    4000 3400 I owned.
  15. Cut4fun
    Cut4fun
    OHIO Redneck
    My stock 4000 I sold for $200. Running square work chain. Also had 2 sets of new thin rings for the 4000.
  16. Jon1270
    Jon1270
    Pittsburgh, PA
    Half an hour west of me:
    Posted: 3 days ago
    VINTAGE HOMELITE 750 CHAINSAW/CHAIN SAW
    1 of 6
    42 INCH? BAR AND CHAIN
    NO TREE TOO BIG FOR THIS SAW
    RUNS GOOD
    $450.00 CASH
    thistle and Oliver1655 like this.
  17. DexterDay
    DexterDay Administrator
    Northeast Oh
    Proof that my saws get dirty ;)
    My 460 is filthy. .
  18. Cut4fun
    Cut4fun
    OHIO Redneck
  19. Jon1270
    Jon1270
    Pittsburgh, PA
    OMG Dex, that's awful. Don't post that here. There are ladies present!
  20. Chvymn99
    Lookin' Good there Dex...:thumbs:
    DexterDay likes this.
