Chain sharpening tutorial.
Discussion in 'Chainsaws and Power Equipment' started by Pallet Pete, Jun 11, 2014.
  1. Chvymn99
    Ok, will check.... I may have it set up all wrong then....:emb:
  2. Hedgerow
    Hedgerow
    SW Missouri
    The pawl looks like it won't advance far enough to the right to reach the back of the correct tooth, but if you just keep moving it, it'll get there.
    The support arm of the pawl moves exponentially farther as the threads are turned to the right.
    Chvymn99 likes this.
  3. Chvymn99
    Yes, MM and Hedgerow you guys are correct. I learned something new. Thanks :yes:
    Hedgerow and MasterMech like this.
  4. prell 73
    prell 73
    ia
    Very nice thread
    LongShot and Pallet Pete like this.
  5. Steven Humes
    Steven Humes
    Holt, Michigan
    Just got this today already love it... Great tool help you get the right angle and shaves rakers at the sametime.
    Oliver1655 and raybonz like this.
  6. prell 73
    prell 73
    ia
    Let me now how it works I was thinking about getting one.
  7. Steven Humes
    Steven Humes
    Holt, Michigan
    It is awsome files rakes at same time. And took saw out after words, best sharpen chain i have had in a long time... :)~
  8. prell 73
    prell 73
    ia
    Thanks I'll have to pick one up.
  9. Steven Humes
    Steven Humes
    Holt, Michigan
    When you sharpen one side roll it over then it will be set up for the other side.
  10. prell 73
    prell 73
    ia
  11. Oliver1655
    Oliver1655
    Central Missouri
    I have a Stihl 2n1/ Pferd CS-X file as well. Note they are specific to the size of chain you will be sharpening: .404, 3/8", and 3/8" lo-pro/picco. (I cheat & use a 3/8" file system on both my .404 & 3/8" lo-pro & it works well enough for me.) You will have to clean the gullet out on the .404 chain every 2-3 sharpenings.
    I use mine all the time. Quick & easy to use. Rarely need to use the grinder as I have mostly clean wood to cut.
  12. Hedgerow
    Hedgerow
    SW Missouri
    Go ahead and sharpen this one fellas...
    dgeesaman likes this.
  13. cnice_37
    cnice_37
    How does the Pferd CS-X / Stihl version compare to something like the Granberg FnJ? I have been a free hand sharpener since forever, and there are chains I can't get to cut properly.
    I realize the CS-X isn't one size fits all, but the rakers are an added bonus. The Granberg looks much more universal, just more time consuming. Filing time is usually beer drinking time, so I'm not in a hurry.
  14. MasterMech
    Almost looks like a chaps hit? What did you find?
  15. Oliver1655
    Oliver1655
    Central Missouri
    There is no setup time needed with the Stihl 2n1 or Pfred cs-x file systems. Mark a starting tooth then sharpen away. The angle on the handles are 30 degrees & you just parallel them to the bar. There are also guide marks on the guide bars parallel to the handles. It is so simple to use, even I can do it.
  16. Hedgerow
    Hedgerow
    SW Missouri
    Neighbor dropped it off that way to be sharpened..
    That's deer hair...
    Didn't ask why...
    But you should have seen under the clutch cover..
  17. MasterMech
    That was my next guess. :zip:
    Hedgerow likes this.
  18. cnice_37
    cnice_37
    Hope you get extra "doe" for that one!
  19. angelo c
    angelo c
    People's Republic of North Jersey
    Here's one of my favorite sharpening tools. Helps to see what your doing if you CAN see what your doing....
    yea the 511a and CBN wheel help some but the headlight help lots when hand filing on the vice and on the 511a.
    sorry about the crappy huge pic but posting pics ain't a strength
    Chvymn99 and cnice_37 like this.
  20. prell 73
    prell 73
    ia
