Chain sharpening tutorial.
Discussion in 'Chainsaws and Power Equipment' started by Pallet Pete, Jun 11, 2014.
  1. Machria
    Machria
    Long Island, NY
    Well, yes, I got a new Stihl (362C) with a 20" bar/chain and a 25" bar with a few 25" full skip chains to go with it as you know. I have the cutters I need, and a file I need, so I am all good.
    But when ordering them, it got me thinking why don't they list this as a spec somehow? It was not on a paper in the chain box, actually only the chain was in the box, with a sticker of the model and specs of the chain. But those specs do not list a file size, or tooth size... So this is more of a "learning excersise/discussion" for me, and I'd bet a lot of other folks like me. ;)
    LongShot likes this.
  2. HDRock
    That's just something I copied and pasted ,I don't know why the question marks are there, they don't mean anything
  3. SquareFile
    SquareFile
    somewhere
    Actually Machria this symbol " is inches when speaking measurements.
    Oliver1655 and DexterDay like this.
  4. Machria
    Machria
    Long Island, NY
    Yes, but the post above has ? where " would normally be. ;)
  5. golf66
    golf66
    Even after watching a quadrillion videos on sharpening chains, I remain Sir Jack Wagon. A Granberg sharpener proved wholly ineffective. A buddy of mine has a cheap @$$ Harbor Freight sharpener and it put wicked edges on my chains.
  6. MasterMech
    Every manufacturer of chain that I have seen prints a file size spec somewhere. Usually on the box.
    DexterDay likes this.
  7. DexterDay
    DexterDay Administrator
    Northeast Oh
    Stihl inserts a piece of paper with this info.
  8. Machria
    Machria
    Long Island, NY
    Sure they do. But instead of "hiding" it and making us search for it in a 4 page document printed with micro print, they aught to just print it on the box, in big bold letters along with the other 4 specs on there.
    Yea, found that. But again, same response as above.
  9. Chvymn99
    So when sharpening a chain. You come across that odd tooth that skips the next tooth at the end of the loop. How do you sharpen that tooth in the same manner as the rest. I've just been eyeballing it so far. This is on the northern tool chain grinder...
  10. MasterMech
    Should be able to grind it just as you did the others? Unless I'm not understanding the question. Just do all of the left cutters and then go around again doing the right cutters.
    Chvymn99 likes this.
  11. Machria
    Machria
    Long Island, NY
    I think he means the chain has an odd ball empty link (skipped link with no cutter). So for that cutter, there is nothing to stop and hold the chain on (normally the next cutter).
  12. Chvymn99
    Correct Machria thats what I was sayin'. But your picture was better than mine....
  13. Moparmyway
    Moparmyway
    New York
    On the 511a, the stop holds the tooth you are grinding. The NT sharpener is different ?
  14. Chvymn99
    Yes, it hold on the next tooth back, which is on the opposite side of the chain.
  15. Moparmyway
    Moparmyway
    New York
    .......... sorry to hear that.
  16. Oliver1655
    Oliver1655
    Central Missouri
    My little HF grinder is the same way. I just eye ball it.
    Rarely use it any more now that I have gotten the hang of hand filing & minimal cutting of wood on the ground.
    Chvymn99 and Moparmyway like this.
  17. MasterMech
    Have another look at it the next time you get the chance. Is it possible to readjust the pawl so that it holds the cutter you are grinding on?
    Moparmyway and Hedgerow like this.
  18. Chvymn99
    I'll check tonight, but I really don't think so.
  19. Machria
    Machria
    Long Island, NY
    And, I guess on a full skip chain, you can adjust the stop back far enough to hit the next cutter which is a few links back... right? OR would that also be a problem?
  20. Hedgerow
    Hedgerow
    SW Missouri
    No.. You must have the pawl index the back of the cutter you are grinding... Or your cutters will rock on you..
    I have an NT grinder...
    mdavlee likes this.
