Chain sharpening tutorial.
Discussion in 'Chainsaws and Power Equipment' started by Pallet Pete, Jun 11, 2014.
  1. mdavlee
    mdavlee
    I'll see if I can get one done for it.
  2. trx250r180
    trx250r180
    Looks nice to me ,i do not know much about the round though ,i run similar chain to that on my mill
    clemsonfor likes this.
  3. Hedgerow
    Hedgerow
    SW Missouri
    You can deliver it personally on the 1st of November...
    Save on shipping....
    And stuff...
    mdavlee likes this.
  4. Moparmyway
    Moparmyway
    New York
    7/32
  5. Hedgerow
    Hedgerow
    SW Missouri
    On a semi-chisel, give the 13/64 a try and see if that don't allow you to keep the guides at ~.025.
    The trade off of course, is durability of the cutting edge, but semi chisel is pretty darn tough...
    Admittedly, I use whatever file is handy and sharp... They both work for work chains...
    mdavlee likes this.
  6. Moparmyway
    Moparmyway
    New York
    A few years ago I tried the 13/64 file first, didnt like the result as much as when the 7/32 came out.
    Then I set rakers to .030 and never looked back.
    Before doing the rakers, I noticed neithor file would allow it to self feed nicely,
    The 13/64 worked, but the 7/32 works better with or without rakers being touched IMHO.
    When I run a new semi chain, I have found it best to just set rakers to .030 before putting it on the saw ........... Maybe running RM is different than Oregon ?
    Bullet and mdavlee like this.
  7. Hedgerow
    Hedgerow
    SW Missouri
    RM has thicker chrome layer...
    Not sure if that would make much difference on Semi chisel or not...
    Anyone here run the Oregon VXL or DPX a lot?
    In semi, all I use is RM..
    mdavlee likes this.
  8. mdavlee
    mdavlee
    Put more hook and 30 degree top plate angle. You won't need low rakers.
    WKEND LUMBERJAK and Hedgerow like this.
  9. Moparmyway
    Moparmyway
    New York
    I have done more hook with the 13/64 file and had to sharpen RM too often ...............
    If I wanted speed, I was runnin RS.
    My 100' of RSL is in my grubby hands now, so I am just awaiting my double bevel files, then my RS will be loosing some weight and getting squared.
    Now if I want speed in the cut I will run the RSL, or the RS square filed
    I like the way RM stays sharp with rakers @ .030 and a 7/32 file..........its a self feeding frenzy for the whole tank - every tank !!!
    When I have to grind RM on my reversable 511a they get put @ 30/60, so the files follow the lead from Stihl and my grinder reminds the cutters of their proper attitude when they get squirrely
  10. mdavlee
    mdavlee
    I file lower with a 7/32" file. It still lasts good but will self feed and cut right with a new rs chain.
  11. Hedgerow
    Hedgerow
    SW Missouri
    I just grind Stihl chain....
    RM anyway....
    The stuff kills files...
    tamarack, MasterMech and mdavlee like this.
  12. mdavlee
    mdavlee
    Yes it does. I need to order a few dozen files.
  13. Moparmyway
    Moparmyway
    New York
    RS rakers come @ .030 on any that I measured so far ............ maybe slightly under .030 but definately more than .025
    My RS cuts great, hand filed or ground on the 511a ............ shame I have to take one of my best RS chains and dull a few of these new double bevel files that were here when I got home from work last night
  14. mdavlee
    mdavlee
    I've took a brand new chain and ground half the cutter off before I ever put it on a bar. I prefer to go from round to square for a play chain.
    Drvn4wood and Moparmyway like this.
  15. Moparmyway
    Moparmyway
    New York
    Not me ......... I will use that new chain untill it's better than 1/2 way filed away, then I will turn it to square. It took a while for me to get the one tooth I posted to square, and on an 84dl, there are 41 more to do
    New for me with the roll of RSL is starting right away with square. I can see gullet work being necessary on the new stuff before use, but I cant afford to loose 1/2 of the tooth that I could be cutting with just for a play chain.
  16. mdavlee
    mdavlee
    I've done at least 5 new ones to back to the rivet. It's easier to work with new ones a lot of times so you can make the cutters as long as you want and then clip the heels. Depending on what you do with the cutters you can still cut firewood with them. I just wouldn't take it and cut a muddy shagbark hickory.
  17. Certified106
    Certified106
    In The Hills
    Got a question, I started playing with the Chain Sharpener I won at the FHC GTG (Thanks Dex!! @DexterDay ) and after some trial and error I had it what I thought was setup good and going well. Anyhow got about 3/4 of the way around and found about 6 teeth in a row that were WAY shorter than the rest and I am talking like the grinder wheel didn't even come close to hitting them. Being a rookie at this I ended going back and slowly adjusting all the cutter to the same length and then sharpening the chain. Now I am wondering if that was the right thing to do? I will say for my first go around on that grinder it worked like a dream and after filing the rakers was pulling great!
    HDRock, Chvymn99 and Pallet Pete like this.
  18. Moparmyway
    Moparmyway
    New York
    Its the right thing to do ............ you wont need 2 different raker heights for different length cutters ........... faster sharpening the next time also as you set the grinder one time for each side of cutters
    Certified106 likes this.
  19. Certified106
    Certified106
    In The Hills
    Thanks, I'm pretty new to the chain sharpening game but now that I am doing it I am enjoying it!
    $ooline, Moparmyway, HDRock and 2 others like this.
  20. $ooline
    $ooline
    WI
    Question about hand files - Will any brand of 3/16" work for RS .325 chain or do you want a "premium" file when sharpening the harder stihl chain? Great info here. I have a long way to go when I hand file.:rofl: :lol:
