Chain sharpening tutorial.
Discussion in 'Chainsaws and Power Equipment' started by Pallet Pete, Jun 11, 2014.
  1. concretegrazer
    concretegrazer
    Southwest MO
    You don't like semi or you don't like tilt on semi?
    The best thing about a grinder or a grandburg jig is the ability to experiment with different angles and find what works best for you.
    Moparmyway and 94BULLITT like this.
  2. clemsonfor
    Semi chisel.
  3. Hedgerow
    Hedgerow
    SW Missouri
    Tested with a stop watch? Or just feels more agressive?
  4. HDRock
    Okay, so, on the tilt or no tilt issue there is no right or wrong answer ?
    I have a stihl 23rm3, I have been sharpening at 10 degrees
    I have just been going by the chart that I posted in this thread on page 1
    I can't even find a chart direct from stihl on the angles
  5. clemsonfor
    I have a chart that came with the grinder I was thinking listed brands of chain and I thought it said stihl chain at 0?? I will have to look again
  6. HDRock
    Yeah, that's where I got the chart that I posted on page one was from my manual.
  7. concretegrazer
    concretegrazer
    Southwest MO
  8. Moparmyway
    Moparmyway
    New York
    I definately notice:
    - A more aggressive, durable cutter that self feeds well when using the tilt in the proper direction ..........
    - No tilt produces a cutter that will get the job done, but it doesnt self feed as well
    - Opposite direction tilt yields a very aggressive self feeding cutter that doesnt hold its edge as well as the other two options
    As far as testing with a stopwatch, my then 92 year old neighbor timed me on his wrist-clock then, but opposite direction tilt wins there if the saw has the power to pull through it.
    To me, RM is more durability than speed .......... so I grind or file accordingly
  9. Hedgerow
    Hedgerow
    SW Missouri
    Yes.. It's odd that Stihl suggests a level grind on it.
    But then again, Oregon suggests 30-60-10
    Moparmyway, HDRock and mdavlee like this.
  10. mdavlee
    mdavlee
    Semi chisel I put a little up tilt with the file. Chisel usually gets a double bevel on it.
  11. Hedgerow
    Hedgerow
    SW Missouri
    Hmmmm.... This is interesting.. I'll do a little testing..
    HDRock and Moparmyway like this.
  12. clemsonfor
    I figured it was from the manual. Mine is a knockoff oregon I have the rough neck which is northern tool.
  13. HDRock
    Yeah, mine is is northern tool, but red
  14. 94BULLITT
    94BULLITT
    Frederick County, VA
    What angles do you guys use for Stihl RS?
  15. clemsonfor
    I sharpen everything the same. Is rs a semi chisel? I sharpen it the same also. Hedge says no tilt on semi molar say tilt it ??
    Moparmyway likes this.
  16. concretegrazer
    concretegrazer
    Southwest MO
    Rs is chisel, RM is semi.
  17. Moparmyway
    Moparmyway
    New York
    Same angles for all chain, but I dont grind my own full chisel, they allways get hand filed and turned to square
    Try it out for yourself and do some experimenting
    concretegrazer and mdavlee like this.
  18. clemsonfor
    Haha autocorrect got me.
    I dont have enough semi chisel. The only I have is in 3/8 lopro.
    The question mark behind it was not that your crazy just that I have two guys that I respect and know chain sharpening and one says one thing and the other says another...so truly confused.
    When I do it I probably will do it just like my full chisel and tilt it now.
  19. Moparmyway
    Moparmyway
    New York
    There is allways more than 1 way to skin the cat Clem.
    We may each be right, and we could also each be wrong.
    For example, if the saw does not have enough power for the more aggressive "tilted" semi-chisel, then the no tilt might be the better way to grind them.
    Thats why its best to try different things on your own and see what works for your application
    Hedgerow and concretegrazer like this.
  20. clemsonfor
    Yea your right. Just like you can grind at 30° or 35° whatever you like. The saws I have semi on are usually 45cc or under. So not very power full.
