Chain Sharpening - How often?
Discussion in 'The Wood Pile' started by red oak, Jul 30, 2016.
  1. Babaganoosh
    Babaganoosh
    Jersey Shore
    Try cutting dead black locust. Depending on your mpg you could easily be finding yourself sharpening every tankful.
  2. red oak
    red oak
    Thanks everyone for advice. I cut a load today and then sharpened the chain when I got home - just 2 passes with the file on each tooth. My goal is to keep that chain really sharp. I carry a couple of spare ones in case I hit the ground or a rock - it's been known to happen:) - Had to adjust the idle screw but other than that everything went perfect today even though it was pretty muggy. Not the best wood cutting weather but I have time now and you gotta make hay (or cut wood) while the sun shines!
  3. Blackop555
    Blackop555
    U.P mi
    When I'm using the 562 with 18 bar it's every tank the 576 with a 28 bar that's less frequent takes a long time those extra teeth. The stihl has a diff size chain so I don't have a quick touch up tool for it yet so I do it once I can't bog it down pushing hard on the saw.
    Get one of those stihl files automatically sharpens and cuts rakers at same time. easiest and quickest I've found
    Backwoods Savage and CoreyB like this.
