Chain Sharpener
Discussion in 'Chainsaws and Power Equipment' started by Skier76, Aug 6, 2023.
  1. isaaccarlson
    isaaccarlson
    Colfax, WI
    I have neen looking at cbn wheels. Still on the fence.
  2. buzz-saw
    buzz-saw
    Ct.
    Go for it , Like night and day.
    I debated myself and now ask why did I wait so long.
    Yes a little pricy but the finish is great and no more dressing wheels and a shop full of wheel grit.
  3. RCBS
    RCBS
    Over here
    This was my hypothesis. That they heated the teeth.
    Skier76, jmb6420, Chaz and 2 others like this.
  4. buzz-saw
    buzz-saw
    Ct.
    Exactly , if you grind the worst tooth first then when you have a tooth that is not all banged up it takes an aggressive cut.
    You really need to start with the best tooth and then work your way to the worst being careful not to grind too heavy generating heat. CBN wheel also does not heat as bad as a standard wheel.
    Skier76, jmb6420, Chaz and 1 other person like this.
  5. The Wood Wolverine
    Chud Jim, some Oregon chains call for that angle when sharpening. I don’t believe any Stihl does. It’s usually on the box or on the paper that comes in the box.
  6. Chaz
    Chaz
    Southwestern NY
    I'm running 33RS 66 and the book does call for 10° down.
    Just got curious enough to look.
    Skier76, jmb6420, Chud and 1 other person like this.
  7. Chaz
    Chaz
    Southwestern NY
    Hmm.. no wheel grit eh..
    :sherlock:
    Skier76 and jmb6420 like this.
  8. The Wood Wolverine
  9. Chaz
    Chaz
    Southwestern NY
  10. Chaz
    Chaz
    Southwestern NY
    Let's see if this works right..
    Hopefully you can read it.. 23 lines down on each page.
    eatonpcat, Skier76 and jmb6420 like this.
  11. Chaz
    Chaz
    Southwestern NY
    Hmm.. Paperwork in chain box does state 90°
    Guess I'll reconfigure the grinder.
    EDIT.. done
    Glad you mentioned this.
    :yes:
  12. The Wood Wolverine
    If it's cuttin' good for you, I'd not touch it.
    eatonpcat, Chaz, Skier76 and 2 others like this.
  13. isaaccarlson
    isaaccarlson
    Colfax, WI
    I use 10° down and it works great.
