Chain cleaning
Discussion in 'Chainsaws and Power Equipment' started by Dougr6, Sep 4, 2014.
  1. clemsonfor
    Ok that makes way more sense. Since I have a cheapo HF unit I am not that worried about the gunk.
    I understand that reason more than what I had in mind...just shiny or spotless chains.??
  2. Grizzly Adam
    Grizzly Adam Guest
    Cheap grinder or not, I would still think you'd want to keep the wheel clean.
  3. MasterMech
    Right, the oil gets on the wheel and then the wheel clogs up with dust.
  4. clemsonfor
    Maybe my chains are not as oily or dirty? I dont see any accumulation on the wheels. I actually need to reshape my wheels.
    They still sharpen in a split second??
  5. Dougr6
    Dougr6
    Caney Ks.
    Cut down a red cedar tree. It gummed the heck out of one chain. Gunk got it disolved okay! Thanks again for advise.
    Shawn Curry and Grizzly Adam like this.
  6. jetjr
    jetjr
    Pa/Md line
    Might open a can of worms but we use brake cleaner on ours at work. They get creosote and who knows what else all over them.
  7. clemsonfor
    I bet a vat of carb cleaner would do wonders!
  8. chris
    chris
    SE WI
    As I do a lot of chains, I clean them in the media blaster with corn cob grit gets the crud off and allows me to see how far back I need to grind to get a sharp edge. Also keeps from pulling crud through the bar rail on the grinder as well as not loading the wheel up. As far a the wheel loading there are some compounds for applying to wheel to minimize loading or you could use some bar soap. If you are seeing a black line on your wheel it is loading up and will cause burning much more quickly. Really bad chains that have been used for cutting in really poor conditions get an additional step of going through the parts washer.
