Central Ohio Charity Wood Cutting
Discussion in 'Bulletin Board' started by walt, Aug 8, 2023.
  1. Eggshooterist
    Eggshooterist
    Erff
    I can bring the whole block....No time to make it smaller.
  2. Eggshooterist
    Eggshooterist
    Erff
    This stuff?
  3. Chvymn99
  4. Eggshooterist
    Eggshooterist
    Erff
    The magnesium is in the car. I have another here thats full size so I'll share the wealth. It needs to be thin pieces. It clogs of saws all blades.
  5. huskihl
    huskihl
    Tree Monkey 661 Check
    XS 500i Check
    XS 2153 Check
    Long enough bars/chains Check
    Ported saws to deliver Check
    Lots of gas/erl Check
    Gotta swing by Fresno/New Bedford first. Should be there about 6 Thursday evening
  6. brenndatomu
    Well, at least Thursday and Friday look nice...
  7. T.Jeff Veal
    Hope the forecast is off, rain says gone and plenty of wood gets :saw::axe::stack:...
    We won't make it, we will be in Nashville visiting my cousin and going here... Screenshot_20231010_154450_Google Play services.jpg
  8. walt
    walt
    north central ohio
    Should have good weather Friday, hope we can run saws for awhile. If we get rained out Saturday we can still sharpen chains , BS and eat. I think we have four easy-ups , plus the cabin and the shop. May just leave the splitters and elevators covered and concentrate on getting some of the big stuff cut. The good fellowship with all my woodcuttin friends is the best part of a GTG.
  9. brenndatomu
    Weather forecast still showing very likely rain Saturday, but only 1/4" total, so might not be a total washout...they were calling for rain all day last Saturday and we ended up with one passing shower.
  10. MAF143
    MAF143
    North Central OH
    So is your poncho half on... or is your poncho half off???
    If Gene Kelly can dance in the rain, I'm thinking I can cut wood in the rain... OK, maybe light rain!!!
  11. dirtdevil
    dirtdevil
    Northern central Indiana
    There will be a couple of chainsaws there..... Lol:hair:
  12. eatonpcat
    Might have to cancel my trip, the big hemi is leaking something...I am thinking it is the water pump and from the looks of the video you pretty much have to take half the engine apart to change it.
    First picture are the cheezy potatoes that you most likely won't get to eat. 20231012_171604.jpg 20231012_171227.jpg 20231012_171225.jpg 20231012_171129.jpg 20231012_171121.jpg 20231012_171111.jpg 20231012_171111.jpg 20231012_171035.jpg
  13. brenndatomu
    Aw comeon...just fill er up and leave the cap a lil loose so it can't build pressure, it'll be fine for this lil trip! :thumbs:
  14. eatonpcat
    You sure?
  15. brenndatomu
    Well, can't be sure without seeing the leak rate in person, but unless it's just pouring out, yep I've used this trick a number of times over the years to get home, or even just to get by a lil longer...heck I even put a low pressure cap on my old work beater so it would stop having new leaks in the ole crusty radiator so often!
    How often and how much do you have to fill it?
  16. eatonpcat
    Have not filled it, just started this week ( that I noticed). When I stopped to get the mail today, I noticed the trail of drips as I turned into the driveway.
  17. Eggshooterist
    Eggshooterist
    Erff
    We drove to Duane's in PA with a leaking main seal and fuel dilution problems tonthe tune of 1.1% per 2500 miles. We made it.
  18. eatonpcat
    I know, I am a Puss!!
  19. brenndatomu
    FIFY :D
  20. eatonpcat
    Yeah, can't argue that Brotha...but I used to drive a Furd! 20180421_082636.jpg
