Catalytic or Non-catalytic?
Discussion in 'Modern EPA Stoves and Fireplaces' started by Andyshine77, Sep 13, 2024.
  1. Andyshine77
    Andyshine77
    Cincinnati, OH
    Inside joke?
    brenndatomu and wildwest like this.
  2. Andyshine77
    Andyshine77
    Cincinnati, OH
    I'll definitely give an update!
  3. wildwest
    Can't say I understand either. Maybe stove owners that don't like cat stoves?
    brenndatomu likes this.
  4. brenndatomu
    Nope, not a cat stove joke...well, not on purpose anyways! :rofl: :lol:
    The Wood Wolverine and wildwest like this.
  5. Highbeam
    Highbeam
    I always thought that this entire forum was created because of the woodstock brand. The other forum had other advertisers or something like that. I don't know, but if not for forums I would have never heard of the brand either.
    brenndatomu and MikeInMa like this.
  6. Ohio
    Not Ohio
    I have two friends with the Buck 81. The one really likes it, they had a hot blast before. The hot blast would decimate their firewood supply in no time. So they are very happy with its heat output and efficiency. Their wood supply goes much further and their home is much warmer.
    The other friend was not so happy with theirs. They had a pre EPA stove that was getting thin in some spots and begrudgingly bought a new stove. (Buck 81) The metal lip at the front of the firebox leading to the flue was not right from the factory. The door would not close all of the way. A chimney sweep came out and had to grind and remove material from it so the door would close/seal. She calls it a Monday morning stove. It’s still not quite right I think it’s going to have to be tweaked again. Me personally I would have returned it. QC issues can happen with just about any manufacturer.
    Also I think she would have been unimpressed with most anything new she bought. I know a catalytic stove would have been too complicated for her though. They are truly simple but I just don’t think it would compute.
    I think the 81 is the first stove I’ve seen in person that has “bay windows.”
    wildwest and brenndatomu like this.
  7. brenndatomu
    Once you've lived with a woodblast, er, I mean a Hotblast, everything else is :thumbs:
    wildwest and Ohio like this.
  8. Ohio
    Not Ohio
    Everyone I know who has owned one has bemoaned its wood consumption. It’s like commuting an hour each way with a big block with 4.10 gears.
  9. Wildbill
    Wildbill
    SW Va
    I bought a Buck 81 last year. It's a great stove, decent on wood, longer burn times, it's pretty decent! The only thing I don't like about mine is that it doesn't put out a lot of heat on low. The wife fills it when she leaves to go to work at 7am and when I get home at 4:30, I have a decent coal bed to build off of but its pretty cool in the house. My old non epa stove would throw out tons more heat for longer times, but did burn more wood. Shoulda got a cat stove...
  10. stoveliker
    stoveliker
    Eastern Long Island
    A cat stove might not have thrown out more heat on low. In the end it's a firebox volume issue; pile of BTUs goes in and is released over a set time. The longer that time the lower the output.
    Cat stoves don't magically make BTUs appear out of thin air. Efficiencies of most modern stoves are basically the same, cat or not
    Some cat stoves allow to stretch the release time to longer, but given the fixed amount of BTUs that went in, this means the longer burn is at an even lower output - and your home might have been colder (assuming the same firebox size)
  11. Backwoods Savage
    Correction. Most do not understand cat stoves.
    Wildbill, brenndatomu and wildwest like this.
  12. Canadian border VT
    Correction cat stove don’t make smoke out of thin air; Cat stoves do make heat out of Smoke/air
    I agree wood has X BTUs per pound
    My experience NC-13 2 cubic feet roughly; 12 cord
    IS cat stove 5 cord and I am warmer than before
    golf66, wildwest, brenndatomu and 2 others like this.
  13. stoveliker
    stoveliker
    Eastern Long Island
    Rereading my post I'm not sure I said something different...?
    Wildbill said his home was cool after a day out and "shoulda got a cat stove". My point was that a cat stove would not create more BTUs as compared to a modern tube stove (efficiencies are the same for all intents and purposes).
    A cat stove may be able to spread the release of those BTUs out longer, but that doesn't solve a problem of a cool house after a day out... No more BTUs to be had ("out of thin air")...
    That was all I was saying
  14. billb3
    To me it comes down to a cat requiring a little bit of extra mechanical maintenance.
    Just about everyone that has gone that route are more than willing to do the maintenance to gain all the benefits of cat burning.
    Most will justify cat expense as well.
  15. brenndatomu
    But didn't that NC13 have a burnt out baffle?
  16. Backwoods Savage
    Maintenance? It takes about 2 minutes at most to change out the cat or to brush the fly ash off. Not a problem.
  17. theburtman
    theburtman
    How often does that need to be done?
    Backwoods Savage and brenndatomu like this.
  18. billb3
    2 minutes for all and every stove ?
    All stoves are created equal ? It doesn't matter which one you buy ?
  19. Old Nate
    Old Nate
    Western PA
    I’ll second this question. I’m hoping to get my CAT stove installed this year and would like to know how often the cat needs TLC maintenance.
    Wildbill and Backwoods Savage like this.
  20. Canadian border VT
    I bought it new.. so not in the beginning; the hole plate above firebox had been damaged by over filling (definitely guilty) that and new firebrick went with it!
    Learned later my chimney has exceptional draft..
    Same chimney, drier wood, better quality stove
