Cat burn problem with new AS.
Discussion in 'Modern EPA Stoves and Fireplaces' started by Marshel54, Oct 27, 2018.
  1. Backwoods Savage
    Or they can also be very easy to operate and no trouble at all.
    I saw lots of folks putting down cat stoves before we purchased on and they did have me a bit gun shy. Long story short, we bought our first cat stove anyway and have loved ever since. Never had a problem with it.
    Maina, BigPapi, brenndatomu and 4 others like this.
  2. mat60
    mat60
    ME
    May I ask why some people don't like cat stoves? There must be some advantage to having one over a stove with the tubes up top?
  3. Canadian border VT
    In some stoves cats are hard to clean. But the biggest reason is cats require a hot fire to lite. Wet wood will not get hot enough.. Most people don't have good dry wood!!
    Notice Dennis has no problems!;)
  4. mat60
    mat60
    ME
    Thanks for the info on the cat stoves and Dennis.:)
  5. Canadian border VT
    I have a cat stove also.. It worked better when I got on Dennis 3 year plan.. In short dry wood burns see western fires every summer.. You ever here about 10,000 acre fires in the east..
    I am totally:emb: that I needed somebody to teach me this:picard:.
    Oh and I burn less wood, get more heat and no visible smoke out of chimney!!
  6. BigPapi
    BigPapi
    The hills of Western MA
    My concern (that I got over, obviously) was being future proof. what if Woodstock goes out of business? What if it's a SHTF scene and nobody is making cats anymore? Knowing the stove can still make heat - though far less efficient/effectively - along with the low likelihood of reverting to caveman times and remaining in our house sort of sealed the deal. If Woodstock went belly up (highly unlikely with their dedicated following and excellent business practices) the aftermarket would step up with as many stoves as they have in the field.. And if it didn't, a competent welder could certainly fan up a replacement without too much heartache.
  7. Oldhippie
    Oldhippie
    Ashby Ma
    On burn tube stoves the burn tubes are frequently damaged easily while loading wood, or just deteriorate from wear and need to be replaced. See the secondary burn technology Woodstock uses in the hybrid stoves are these large metal plates. Much more solid and very hard to damage.
  8. papadave
    Oldhippie Steve.....in what tube stoves does this happen? The tubes in mine are stainless steel and very durable. No damage yet. Baffles are a different story, as those do deteriorate and get damaged if an errant split hits them.
    I did however, just replace 2 firebricks in the back of the stovebox.
    Chaz, Maina, Chvymn99 and 3 others like this.
  9. brenndatomu
    I had the same question...I have only ever heard of 1 or 2 people that had to replace tubes...and they had over fired the crap outta the stove, for extended periods!
    Chaz, Maina, Chvymn99 and 4 others like this.
  10. Backwoods Savage
    Most have no experience with them; just what they've read or heard. It is rare to find someone who actually uses a cat stove that does not like them. However, we've also ran into people who have perhaps bought a house with a cat stove in it already and burned but they simply did not know how to use them. Many have not even known there was a cat in there!
    The advantage is you can burn lower and usually get more heat. Tubes are nice but they are mostly for when the fire is going really well then they just stop working, while the cats still keep on firing and giving more heat. But simply put, there are plusses and minuses to each one. Hybrids are coming on strong now too and they are even better.
    Chaz, Maina, BigPapi and 3 others like this.
  11. Backwoods Savage
    I have heard of folks damaging the tubes and sometimes tubes having to be replaced simply because they were falling apart. However, I don't think it is a huge problem.
    Chaz, Maina, BigPapi and 2 others like this.
  12. Oldhippie
    Oldhippie
    Ashby Ma
    My neighbors Hearthstone stove has tubes that were begging for replacement. No protection from wood being loaded in and age deterioration.. caused by maybe over firing or moisture in the wood I'm not sure, but they were barely holding on, and the stove was less than 1o years old. Point being they aren't maintenance free, I've seen damage in others too, although I can't really say what models they were. I think the plates were seeing now in the Woodstock's, maybe others? Look much more sturdy and less apt to take a hit and be damaged from a large split.
    Chaz, Backwoods Savage, Maina and 4 others like this.
  13. Oldhippie
    Oldhippie
    Ashby Ma
    What I love most of about the Fv, is looking at the wood and just seeing it all black, no flame and maybe a little bit of red glow on the edges of the spits, then looking up into the cat and seeing bright orange then looking at the temp gauge on top and seeing 600'F+ temps. I'll take that all day or night long. :)
  14. papadave
    Absolutely. None are.
    Chaz, Backwoods Savage, Maina and 3 others like this.
  15. Woody Stover
    Woody Stover
    Southern IN
    I don't know if you've run the Fv and the AS on the same stack, but it sounds like the Fv works better on a shorter stack. I sold mine to my BIL, and he's got not even 14' of stack. He can still run if it's kind of warm out, like in the upper 40s.
    I was thinking of getting my SIL to buy an AS High Style, one reason being that I'd then have another stove technology to play with. :cool: She only has about 14' of stack now, less with the High Style. Do you all think that would work OK, top-venting the stove, with temps in the 40s at night?
  16. Oldhippie
    Oldhippie
    Ashby Ma
    Woody, I run both stoves on the same stack, but it's a 26 foot stack from the upper Fv and another 10 feet or so to the downstairs AS. Everyone says today you're not supposed to do that, but in 1979 when I built the house it was common practice here in Mass as long as it used the ame fuel. Both stoves run fine. The AS in the basement seems to need a bit more draft on startup than the Fv does, but once it takes off and the cat ignites it's basically a cat stove. In the super cold, below -15'F give it some air and it puts on a light show with the secondaries.
    I think the AS might need a bit more stack than 14 ft.. maybe not if it's a nice straight exit out the top. A friend of mine has a Progress with a short stack but it's a simple T out the back and then a straight shot to the exit and his works great!
  17. Canadian border VT
    My friends hearth stone tubes got broken by chimney sweep.:eek:
    Chaz, Backwoods Savage, Maina and 5 others like this.
  18. Oldhippie
    Oldhippie
    Ashby Ma
    Exactly. I'm on year 5 of my Fv and I'm realizing I might be needing some new gaskets soon. Sheesh! All this maintenance! :hair:
  19. Oldhippie
    Oldhippie
    Ashby Ma
    Those things are just sitting there saying "hit me"! :bug:
  20. papadave
    I've never hit mine. :rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol::rofl: :lol: Ok, maybe just a couple times, or a thousand. But really, who's counting?:whistle::D
