cast iron fry pan myths
Discussion in 'The Smokehouse' started by savemoney, Nov 8, 2014.
  1. WeldrDave
    Well yes I did see that, and you can do that on a welding table also, with enough oil…. The process of seasoning is to not only create a non stick barrier but a protection layer to the pan as well. When you build up enough patina on the bottom you need "VERY" little grease, butter, oil, etc to have a slippery surface such as teflon. Being smooth is not all of it! enough said… you'll learn, "don't be in a hurry"! As most people are…
    jeff_t likes this.
  2. jeff_t
    jeff_t
    SE MI
    I'd like a #9 or 10 Griswold, or thereabouts. Wagners seem to run a little smaller, number-wise. I have a #8 BSR that is quite a bit bigger than my #8 Wagners.
    I gave a #10 Griswold to my sister, and it's a monster.
    WeldrDave likes this.
  3. WeldrDave
    I got a #9 BSR floating around here and your right, they are bigger! I use my # 7 for nearly all my cooking for myself, I love that pan… It's a tank!
  4. sherwood
    sherwood
    Can anyone identify this nice old frying pan? We've had it in the family a long time. P1050907.JPG P1050906.JPG
  5. milleo
    milleo
    Maine
    I can't identify but it looks like a goody to me and ready to cook with....:)
  6. WeldrDave
    Yes, it's a Lodge, around the 1930's . They were the only one that I've seen with the heat ring open at the top, but the number and molders mark are a pretty good indication. It's a very nice pan! :cool:.
    sherwood and savemoney like this.
  7. Well Seasoned
    I dont know if my wife washed it or what, but this morning I made 3 pans (12") of bacon and then onto cooking scrapple in the bacon fat and they got destroyed! This is a newer Lodge CI pan
    Any advice now that it has a film of scrapple on it? Normally I would boil alittle water in it to loosen things up.
  8. WeldrDave
    Yup, or just let it soak with an inch of water in the pan, sprinkle black pepper liberally on it, "in water" let it sit a day, it'll come out.
    Well Seasoned and savemoney like this.
  9. jetjr
    jetjr
    Pa/Md line
    Scrapple is a all or nothing thing for me. One time it turns out great nice crust on the outside and all. Next time I might as well make a batch of mush.:headbang:getting better at it though.
    WeldrDave and Well Seasoned like this.
  10. WeldrDave
    When I do scrapple, I put a small amout of vegetable oil in the bottom of the pan, it helps a lot!
  11. Well Seasoned
    Same here man........ sometimes dredging it in flour and then into a smoking hot pan works well, but this time i figured, hey bacon grease, im golden..........Nah......
  12. papadave
    Uh, scrapple?
    Please enlighten, because it sounds like I'm missing out on something good.
  13. WeldrDave
    Boy are you ever!!! :drool:
    tuneighty likes this.
  14. WeldrDave
  15. Well Seasoned
    Ooohhh, poor Dave....... scrapple is where the word gooder originated. :D
    papadave and WeldrDave like this.
  16. Well Seasoned
  17. jetjr
    jetjr
    Pa/Md line
    Man its good stuff if done correctly. I've had some I would not give you 5 cents for though.
  18. papadave
    I consider myself enlightened.
    Thanks.
    Just did the monthly shopping trip yesterday, so trying to find some will have to wait.
  19. jetjr
    jetjr
    Pa/Md line
    If you buy it at the regular store I would recommend Rapa brand.
    Well Seasoned and papadave like this.
  20. sherwood
    sherwood
    savemoney, jeff_t, milleo and 2 others like this.
