cast iron fry pan myths
Discussion in 'The Smokehouse' started by savemoney, Nov 8, 2014.
  1. WeldrDave
    After deep digging, this pan is the 6th series of the ERIE series, circa (1905-1907) the only years these were produced with no "quote" marks! Not a bad trash find! :cool:
    bogieb, fishingpol, BHags and 4 others like this.
  2. woody5506
    woody5506
    Upstate NY
    Looks great Dave, I'm really amazed at that find!!! I always forget what series my Erie is, either 3rd or 4th. Mine looks brand new, and the iron they used back then was so smooth and perfect. Definitely a different feel even from the Griswold pans.
    fishingpol and WeldrDave like this.
  3. WeldrDave
  4. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    That pan has to be one of the nicest grabs I've seen. A pan like that would be the centerpiece of my collection.
    JackHammer and WeldrDave like this.
  5. WeldrDave
    I gotta get it 100% clean. It sat in the tank all night. Going to pull it out here shortly and rinse it.
    eatonpcat likes this.
  6. JackHammer
    JackHammer
    eatonpcat and WeldrDave like this.
  7. WeldrDave
    Your (Red) lead+positive goes to the Anode in the tank and the (Black)- Negative goes to the pan or what ever it is you want to clean. Current runs from negative to positive.
  8. WeldrDave
    A battery Charger.
  9. Eckie
    Eckie
    So is that just a jumper wire from one side to the other?
    WeldrDave and eatonpcat like this.
  10. Eckie
    Eckie
    I just looked back through the thread and see that it is a jumper/connection wire. Not sure if my small charger is sufficient, I'll have to see what the selection options are..
  11. WeldrDave
    Yes, I have an anode at each end, they are +. and used the - on the pan. It's not necessary but seems to be more efficient.
    Eckie likes this.
  12. WeldrDave
    I only use a 10 amp. Don't need any more.
    JackHammer and Eckie like this.
  13. WeldrDave
    Make sure your charger has (Manual) setting or is a manual charger. An automatic charger will just shut down thinking the battery is fully charged.
  14. Eckie
    Eckie
    WeldrDave, in the pic of your last pan clean, I noticed the handle isn't completely submerged. Is there a specific reason for this, or is it just due your setup? I realize the end of the handle may not need the treatment like the "meat" of the pan.... Can whatever you have the CI pan hooked to (the "S" hook in your pic) touch/be submerged in the solution as long as the charger lead isn't touching the liquid?
  15. WeldrDave
    I used to Wrap a couple turns on the handle in a heavy copper wire, like a grounding wire, 8 or 10 gauge but the Stainless (S) hook works just as well. There is no rhyme or reason and you can have the handle fully submerged, my plastic container just wasn't deep enough to let it hang in the water. When I first put it in, the handle was under water. It cleaned up quick, (lack of crud there).
  16. WeldrDave
    Eckie , there's a hundred different ways to design your set up, here's just one and youtube has got many. I did mine several years back and been using just some junk iron I had laying around. I clean/wire it bare before I start.
    Eckie likes this.
  17. WeldrDave
    Here's another...,
    Eckie likes this.
  18. WeldrDave
    Well fishingpol, here it is! Right out of the tub again. I had to put it in for another day but it helped and I had some real hard crud I had to scrape inside. It is absolutely beautiful and flat! It's a one in a million find! :cool::) The last pic, I just oiled it and it's going on the grill for seasoning.
    metalcuttr, woody5506, bogieb and 4 others like this.
  19. fishingpol
    fishingpol
    Wow, I am quite impressed. That is a awesome looking pan WeldrDave.
    Unbelievable curbside find. Thanks for the update!
    metalcuttr, WeldrDave and JackHammer like this.
  20. WeldrDave
    Thank you, just lucky. I got that flat #8 Wagner skillet in the tub now.
