Carb limiters??
Discussion in 'Chainsaws and Power Equipment' started by HDRock, Sep 16, 2014.
  1. HDRock
    Ok back on subject here saw pros :)
    DexterDay likes this.
  2. MasterMech
    Some type of limiter make turning the screws easier once they are trimmed. Others do not as HDRock found out.
    Do what you gotta in order to get to twistin' on those screws.
    HDRock likes this.
  3. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I like the caps after the wings are off simply because they work well to hold the screw driver tips. They make it easier to find with the screwdriver in otherwords...
    Chvymn99, HoneyFuzz, HDRock and 3 others like this.
  4. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    If this was a new out of the box carb, the caps are not fully seated on the adjustment screws, so that you have full movement of the screws to get the carb to work with the saw, then you press the limiters home on the screws. A particular model of carburetor may have many applications across many manufacturers and products, so the limiters are not functional 'pressed home' when the carburetor leaves the factory to provide for multiple applications.
  5. mdavlee
    mdavlee
    I like the limiters on to help hold and guide the screwdriver.
  6. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    X2 !
    Chvymn99, Pallet Pete and HDRock like this.
  7. HDRock
    Now I get it
    That's what I was kind of thinking because if you were to press down on them they would engage into the spline part of the screw
    KilliansRedLeo likes this.
  8. KilliansRedLeo
    KilliansRedLeo
    Rochester, New York
    Correct!
    HDRock likes this.
  9. HDRock
    Thanks
    Live n learn :)
    Chvymn99 likes this.
  10. clemsonfor
    I think cutting the wings off refers to a stihl carb. And if that is a stihl carb those things dont look like the ones I messed with or my memory is super fuzzy?
  11. mdavlee
    mdavlee
    Most stihls are inside a little shield to make it harder to pull those tabs. That's a husky carb that he was asking about.
    concretegrazer likes this.
  12. clemsonfor
    Thats what I was thinking. But I could not place what carb he had.
    Like slim pointed out the few stihl I have done gave me no trouble. I yanked them right out. One was on the saw the other I had the carb in hand. Pulled them right out.
  13. HDRock
    yeah that carb goes on my 55
  14. prell 73
    prell 73
    ia
    Cut the tabs off and put them back on they hold the screws from moving when the saws runnin
    clemsonfor likes this.
  15. clemsonfor
    Man prell your going through the list and digging up all kinds of posts:)
    I am seeing things pop up we havent seen in months half a year or more in some cases.
