Cap washers unite!
Discussion in 'The Wood Pile' started by Suburban wood snob, Nov 25, 2018.
  1. Suburban wood snob
    Suburban wood snob
    Milwaukee
    If it makes you feel better... I was off the roof at 6:57...wife pizzed at me. But chimney stove and cap all cleaned. Xmas lights hung, and I even repaired a split Ridge shingle before calling it a night.
  2. bear 1998
    bear 1998
    S.C.Pa
    I have a little tooth brush sized wire brush....i take that across it n thats it...if you like cleanin it up real good....i dont blame ya.
    I hear it all the time about how clean i keep my splittin area n the stone around my wood stacks....:D
  3. bear 1998
    bear 1998
    S.C.Pa
    Where the red door?
  4. papadave
    With the rest of the real lyrics. :whistle:
  5. Backwoods Savage
    Cap won't be removed here until it has to be replaced.
  6. woody5506
    woody5506
    Upstate NY
    I clean mine at the end of the season usually just a scrub down with a wire brush. Never tried oven cleaner though
  7. yooperdave
    That's an easy answer....."behind the green door" of course!
  8. yooperdave
    I tell ya.......this kids now-a-days just don't get it! :D
  9. Ctwoodtick
    Ctwoodtick
    Southeast ct
    You mentioned”broken tiles” in your original post? Where?
  10. bear 1998
    bear 1998
    S.C.Pa
    Its no wonder why ur up there where the men are men n the sheep are scared....:rofl: :lol:
  11. Suburban wood snob
    Suburban wood snob
    Milwaukee
    Amen Brother!
    amateur cutter and bear 1998 like this.
  12. Suburban wood snob
    Suburban wood snob
    Milwaukee
    We used to say that about going to whitewater for college ... where the men are men(and half the women) and the sheep are scarred.
  13. Mwalsh9152
    Mwalsh9152
    Pelham NH
    As I suspected at the beginning of this thread.....
    bear 1998, amateur cutter and Marvin like this.
  14. ReelFaster
    ReelFaster
    S.Jersey
    Sorry for the noob question as I never cleaned my liner just yet but just recently picked up soot eater! Out of curiosity can you clean the liner from the inside/stove side if you remove the baffle and secondary air tubes? Vice versa if you clean from top down, soot being removed I assume has to fall down into the stove or on top of the baffle which would need to be removed anyways correct? I was up on the roof doing lights last week took a peek down the liner and at the chimney cap not much doing but I haven't burned a lot neither.
    brenndatomu and bear 1998 like this.
  15. bear 1998
    bear 1998
    S.C.Pa
    Yes you can...either way
    brenndatomu, papadave and ReelFaster like this.
  16. ReelFaster
    ReelFaster
    S.Jersey
    Gotcha bear 1998 thanks for your help as always :thumbs:
  17. JWinIndiana
    JWinIndiana
    NorthWest Indiana
    Acid rain will do that don'tcha know!!! (we don't hear much about acid rain anymore do we??)
    brenndatomu, bear 1998 and yooperdave like this.
  18. yooperdave
    No, we don't hear much about acid rain is right. I think the problem ended right after the total depletion of the rain forests back in the 90's!
    bear 1998, brenndatomu and ReelFaster like this.
  19. bear 1998
    bear 1998
    S.C.Pa
    If like mine...ull find a piece of insulation on top of ur baffle board....its held there with a round piece of roughly 1/4" thick metal. Those stainless steel cotter pins can be a bear gettin back in for the tubes...i just got new ones. Make sure when u put the baffle board back in...u slide it the whole way to the rear. Theres an angle piece that holds the board up in the front....just push up n turn it to get it out..pay attention to what position it is in when u pull it out....easy peasy..
  20. ReelFaster
    ReelFaster
    S.Jersey
    Thanks bear 1998 will do!! I'd like to try and give it a cleaning maybe a few weeks or Xmas week while am off just to see what I get. Most of what I burned is properly seasoned but a little of it hasn't.
