CaCl is costing me some $$$
Discussion in 'Chainsaws and Power Equipment' started by cnice_37, Jun 7, 2014.
  1. concretegrazer
    concretegrazer
    Southwest MO
    That's why you slime um.;) You should see the two I did, looks like a pin cushion.
    I don't know about the rims, I try to just drive this stuff.:emb:
  2. concretegrazer
    concretegrazer
    Southwest MO
    I wish that my tires cost a hundred.:mad:
    basod, Oliver1655 and MasterMech like this.
  3. lukem
    They do....just several times.
  4. MasterMech
    They used to make Slime specifically for tubes. Pretty sure they still do. You are correct in that regular slime in tubes is not recommended.
  5. lukem
    I'm gonna get the fronts on my ZTR foam filled. Rides a little rougher but no flats!!!
  6. MasterMech
    What are you riding? I thought Exmark had foamies on the front for all the LazerZ's and up?
  7. lukem
    Bad Boy. It was an option on mine but the original owner must have decided against it.
  8. clemsonfor
    But look how big they are!!! I have 5-15" tires on the front. Down time is the biggest killer. Its a 3 hr one way drive to my property. And i go for the weekend...giving me 1.5-2.5 days to do what i need . If i cant find the guy up the road at his shop or house or his dad im outta luck, plus tje time to dismount and mount which is not huge but still a pain. I dont have all my tools and stuff so always worki g with what i jave and everything takes 2x as long there.
  9. concretegrazer
    concretegrazer
    Southwest MO
    Size doesn't matter as much as popularly. My front wheel assist tires cost more than the rears.:loco: :crazy:
    Bummer that you have that much trouble. I guess I should be greatful of urban sprawl, my tire shop is now 3.5miles away.
    MasterMech likes this.
  10. clemsonfor
    My tire guy is 2 miles or so. But he works for himself on his own time not just waiting around for me on weekends. And then its 7-10 miles to the next towns but they hardly work saturdays and dont drip everything for me.
  11. clemsonfor
    Crazy your fronts are more than rears!!
  12. Oliver1655
    Oliver1655
    Central Missouri
    I haven't had much luck with "Slime". I have 15's on the front of the tractor & have used a half a gallon in each & still no luck.
    I would clean up the rims with a wire brush on a angle grinder to be able to better evaluate the rim. I like to use DuPont "Extend" instead of primer after cleaning the rim. It works like a gun metal bluing to stop the rust action & turn it into a primed metal.
    Ditto on using tubes when fluid filling tires. If you have a hole in the tube, turn it into a float toy & put a fresh tube in. Patches will not hold up to the fluid.
    As mentioned, the fluid level should be up over the top of the middle of the rim. However, you don't want to totally fill the tire with fluid. They need the pocket of air at the top for cushioning.
    The following PDF file is a handy reference for determining how much fluid you will need to fill your tires. Note the web link below will not take you to a web page. The PDF file will automatically download
    www.agf.gov.bc.ca/resmgmt/publist/200Series/210104-1.pdf
    If you decide to go with calcium water & want to do it your self, a local concrete plant is a good source for it.
  13. basod
    basod
    Mount Cheaha AL
    If you can't find anyone to foam the tires check out a Caterpillar dealer - they may do them for you.
    We just got a new set for the telehandler (Cat Lull) at work a year ago - they have to be foam filled as we move hydrogen with it - pretty sure they were over $8k...just powerplant money:rofl: :lol:
    Another good product for badly rusted surfaces in Rustoleum Rust Reformer - it's a milky white product that reacts with the rust and forms a hard black almost epoxy like surface
    Oliver1655 and concretegrazer like this.
  14. concretegrazer
    concretegrazer
    Southwest MO
    Do you remember which brand of slime you used? I have an experiment going on the gator with the name brand slime in one side and the multi-seal in the other. No flats in either so far.
    I haven't had any trouble with patches holding up on tubes with calcium or methanol. I'm planning on switching to the beat juice as needed in the future.
  15. Oliver1655
    Oliver1655
    Central Missouri
    The actual brand "Slime" - green in color
  16. MasterMech
    So you have tread punctures that still leak even with Slime in the tire?
  17. clemsonfor
    I can't fine slime for tubes could someone link me to it?
  18. MasterMech
  19. billb3
  20. Oliver1655
    Oliver1655
    Central Missouri
    Yes, the "Slime" doesn't work for me. I have tried it in the mower tires as well & still no luck. I have tried adding more than the suggested amount as well & it still didn't work. I am talking in the middle of the tread, not the side walls. So I have given up on it & just patch the tires or put in plugs as appropriate.
    clemsonfor likes this.
