But which chainsaw....
Discussion in 'Chainsaws and Power Equipment' started by BDF, Oct 12, 2015.
  1. rburg
    rburg
    TN
    Let us know how you like it.
    Eric VW likes this.
  2. WV Mountaineer
    WV Mountaineer
    Princeton, WV
    Well, if you ever need a big block chevy saw, you should have it all figured out now with the $4000 of personal investment you have in this purchase. God Bless.
    cgraham1 and Eric VW like this.
  3. cgraham1
    cgraham1
    Nor Cal
    As long as the OP is happy, that's all that matters... I personally would rather spend $400 on a used 372xp or 064, but to each his own, I guess. :)
  4. WVhunter
    WVhunter
    Mountains of WV
    Congrats on your new saw purchase!!!:yes:
    concretegrazer likes this.
  5. BDF
    BDF
    Well, received the saw and like it so far. Installed the bar and chain, turned the bar oil up all the way and cross- cut and noodled some silver maple about 24" in dia. The saw runs well, the bar is over- oiled (which was the intention- now I can turn the oil flow down a bit) and it started OK. It started better after I read the instructions; the choke seems to have two positions but in reality it has three- choke on, choke off but still partially engaged, and choke off when the throttle is opened the first time. The decompression button seems to work well.
    The only disappointment is that the saw has an odd- ball 20" bar that takes a 70 link chain rather than the more standard 72 link chain. Other bars are available that fit this saw and do take standard chains so I will probably go that route after this bar and chain have some time on them. A more aggressive chain would be desirable but I have not yet found anything like a semi- chisel, aggressive chain with 70 links.
    Overall though, I am quite pleased with the saw and still believe it is the best bang for the buck for a new chainsaw of this size. I did look at quite a few used saws but given the price of used 'name brand' saws is still pretty high, and there is a huge unknown factor buying sight- unseen, at least from unknown people, the Echo seemed like more of a 'sure thing', especially with local dealers and a 5 year warranty.
    Brian
    CoreyB, Loon, Cut4fun and 1 other person like this.
  6. rburg
    rburg
    TN
    Some dealers will make you a 70dl chain off of a roll. There are also several places you can order 70dl chains.
    mike bayerl likes this.
  7. thistle
    thistle
    Polk/Guthrie Counties,IA
    Oregon 72LG70 is what you're looking for.A very aggressive full chisel chain,70 is the number of drive links.My local Northern Tool normally has 2-3 packaged loops on the shelf.Surprised me first time I seen them there,normally almost all their chain is that worthless Vanguard safety chain with the folded over rakers.
    My older Poulan's & several of the mid sized Mac's share the same bar mount pattern - 70 links for a 20"chain,66 for 18",60 for 16" etc.
  8. Cut4fun
    Cut4fun
    OHIO Redneck
  9. BDF
    BDF
    Excellent info. about the 70 link chain availability- thanks!
    Brian
  10. fordf150
    fordf150
    Newcomerstown ,Ohio
    another option for the Echo saws is a bar adapter and stihl mount bar on them. 72DL :dex:
    94BULLITT and DexterDay like this.
  11. Black Dog Chainsaw
    Black Dog Chainsaw
    Central Iowa
    Bailey's will spin and ship you a chain in any size you want. 70dl X price per DL and they will ship spun up. Easy peasy... Get Carlton/woodland pro. Cuts good and easier to file.
  12. mike bayerl
    mike bayerl
    devildog95 likes this.
  13. dgeesaman
    dgeesaman
    Elizabethtown, PA
    I was noodling with my 372XP today and wishing it had the extra-wide clutch cover. By chance, is the chip clearance in the clutch cover bigger in the 385? Do you have any of your 372XPs with the extra wide clutch cover?
  14. BDF
    BDF
  15. devildog95
    devildog95
    Heartbreak Ridge
    I also have the 590 among several other saws and I found a dealer online that sells 70DL Oregon chain at very good prices- and sells Oregon bars too. Pm me for the web address. Never mind- someone already mentioned the website . Loggerchain.com (frawley's)
  16. devildog95
    devildog95
    Heartbreak Ridge
    jon1212 likes this.
  17. CoreyB
    CoreyB
    South east iowa
    A lot of great 60 -70cc saws. I just bought a dolmar 6100. It is a super smooth, torquey noodling machine.
    It just rips through 20+ in oak and hickory
  18. BDF
    BDF
    Thanks.
    I have a 24" bar and <standard length> chain for it on the way. Went the Laser route; supposed to be decent equipment but is actually quite inexpensive, especially the chain. If the chain turns out to be garbage, I can still use the bar and go over to Stihl, or any other, chain.
    I cut firewood to 20" so the 20 inch bar on the original saw is a bit marginal. I believe the saw will drive a 24" chain OK if I am reasonable with it.
    Brian
  19. devildog95
    devildog95
    Heartbreak Ridge
    You may want to get semi skip or skip chain for your 24" bar. Depends on type of wood you mainly cut. IMO
  20. jon1212
    jon1212
    Utah........ugh!
    Meh? Semi maybe, but it has been my experience, and is solely my opinion that full skip isn't really necessary on anything under 28". I run 24" and full comp on my 372XP, because more horsepower is more better, and the full comp is faster in the cut.
