Bumper Crane Build
Discussion in 'The DIY Room' started by ~smokey~, Jul 22, 2020.
  1. eatonpcat
    Thanks, Found it... ~smokey~
  2. eatonpcat
    Thanks Eric
    Eric VW, brenndatomu and Chaz like this.
  3. Chaz
    Chaz
    Southwestern NY
    Eric VW got the mod powers goin on
    :cool:
    Edit.. guess he found your tilde´
    :bug:
    Eric VW, brenndatomu and eatonpcat like this.
  4. ~smokey~
    ~smokey~
    British Columbia
    Thanks bud !
    Chaz and Eric VW like this.
  5. ~smokey~
    ~smokey~
    British Columbia
    Time to start farting about with the crane, vertical post welded to the receiver hitch
    Boogeyman, eatonpcat, Chaz and 3 others like this.
  6. ~smokey~
    ~smokey~
    British Columbia
    About an inch of clearance next to the tailgate
    Boogeyman, eatonpcat, Chaz and 4 others like this.
  7. ~smokey~
    ~smokey~
    British Columbia
    Mocking up some of the vertical post parts
  8. ~smokey~
    ~smokey~
    British Columbia
    Winch is mounted to a receiver hitch and slips into a piece of Telespar bolted to the vertical post, held by a pin
  9. ~smokey~
    ~smokey~
    British Columbia
    From my junk pile a beefy lifting arm from an old hydraulic floor jack, should work good as a pivot
  10. ~smokey~
    ~smokey~
    British Columbia
    The lifting arm is wedged between those two plates, I'm using the 2¼" O.D Telespar for the main boom with short sections of 2" Telespar slipped inside wherever it's bolted along with ½" I.D water pipe spacers to prevent the Telespar from crushing when tightened, the plates are 1/8" thick 5" x 8"
  11. ~smokey~
    ~smokey~
    British Columbia
    After 27 days working on the new bumper/crane build it's pretty much done, working on the pins to have two positions for boom height
    Drilling the ends of the pins to accept these pull handles using thin rod makes installing/removing the pins a lot easier
    Boom in the low and high position
    The whole crane is a take down design for easier storage and makes for lighter pieces, the heaviest piece is the swivel at a reasonable 28 lbs, the whole crane including the winch weighs 80 lbs
  12. Stinny
    Looks good... welcome to the gravity fighters club... ;)
  13. Woodwidow
    Thanks for sharing the project with us. It looks great.
  14. brenndatomu
    Nice job! :handshake:
    So does the upright post get pinned to the bumper mount, or do you let it float so that when the truck squats with a load, you can still get the crane post out?
    Lets see a log hanging on that suckah now! :yes:
  15. cnice_37
    cnice_37
    Here I thought another guy was mounting the HF crane thing to a receiver. Nope, very well thought out!!
    :salute:
  16. eatonpcat
    Nice!!!
    ~smokey~ likes this.
  17. ~smokey~
    ~smokey~
    British Columbia
    Thanks Stinny, I just wish I had some rounds to pick up with this thing I guess I'll have to settle for a drum full of steel :smoke:
    Stinny, brenndatomu and T.Jeff Veal like this.
  18. ~smokey~
    ~smokey~
    British Columbia
    You're welcome, glad you enjoyed it !
  19. ~smokey~
    ~smokey~
    British Columbia
    Thanks brenndatomu, the post sits on the ground and takes all the weight so the receiver hitch part works as a stabilizer, not sure if it makes much difference in the end but it's a much simpler build, I wish I had some rounds to play with but I'm looking forward to dragging wood out of the bush with this thing ! Drag Lift Chop Burn...
  20. ~smokey~
    ~smokey~
    British Columbia
    Thanks cnice_37, why buy something from HF when you take things the hard way !
