Bucking Saws
Discussion in 'Chainsaws and Power Equipment' started by thebierguy, Nov 29, 2020.
  1. EODMSgt
    EODMSgt
    White Mountain Region, NH
    I've had a 362 C-M since late 2017. I wanted something with a bit more oomph than my 290 after a severe storm rolled through and brought down a lot of timber. I haven't needed to get anything done to it and haven't modified it either and it works well enough for me. My 11-year old 290 is still my go-to saw for a lot of bucking however the 362 sees enough action as well. I'm not in the firewood business so can't comment on the 362's durability for that amount of work however mine isn't a garage queen (for example this year between the 362 and the 290 I've cut and processed around 14+ cords). I'm a full-time scrounger (no truck loads or delivered log length stuff) so all my timber is dead and down in the forest and the 362 gets humped around the woods a lot. The largest diameter I've used it on has been around 26".
  2. Creekin
    Creekin
    Manitoba
    Also have a 362, and i love the m tronic carb, it starts great whether its -35 or +35 outside
    Only issue I had was a problem with the oiler not putting out enough, fixed up under warranty and no issues in 3 years
    It wears a 20" bar, kinda thinking of switching to an 18", but have quite a few chains already for the 20
    Would love to send it out for some port work but nobody around here does it, trying to talk the tech at the dealer to get into it
    Might hog out the muffler this winter if i can find the time
  3. amateur cutter
    Or you could go buy one & be the crash test dummy for us. :rofl: :lol:
  4. Sandhillbilly
    Sandhillbilly
    North central Nebraska
    Buy the 362 so the wife will be happy. Then every time you use it grumble just a bit about it being not quite enough saw for what you’re doing with it, and that you should have got the 462. Keep it up long enough and she’ll get tired of hearing about it and tell you to go get one. Heck, maybe she might even surprise you with one on your birthday just to shut you up!
    its worth a shot anyway :emb:
  5. mike bayerl
    mike bayerl
    Can I change my vote??? I was out noodling some big oak rounds the other day. It reminded me how nice my MS461 is. Yes, it's heavier, but yes it cuts faster so maybe a wash in the fatigue at the end of the day? Sorry to add confusion. Ultimately, you can't go wrong with a 60 or a 70-80 cc class saw from a quality brand.
  6. thebierguy
    thebierguy
    Hazelhurst, WI
    Haha..I'm sure the 70 cc class saws would be awesome. I'd love to jump to that. Just so hard to bite the $$ bullet at this point, even with a used saw.
  7. The Wood Wolverine
    Fixed.
  8. Husky Man
    Husky Man
    Mt Hood Oregon
    Hey Jason, if you look at my Sig Line, I’m doing my Best to Prove you Right
    Hi I’m Doug, and I have a Problem
    Well, actually Two Problems,
    My Budget isn’t BIG Enough, and
    My Garage isn’t BIG Enough
    Doug :cheers:
  9. The Wood Wolverine
    Yep, I have both of those issues too! Lol.
  10. thebierguy
    thebierguy
    Hazelhurst, WI
    I came across a used MS462C that looks mostly new and the owner saying maybe 10 tanks of gas have been burned in it. Asking $975. Comes with a 20" and a 25" bar with two chains for each. Does that seem like a reasonable price or should I try for a bit more off?
    Sent from my SM-N960U using Tapatalk
  11. Lastmohecken
    Lastmohecken
    Arkansas
    That might not be a bad deal, if the bars are in good shape, and good chains, especially since you shouldn't have to pay sales tax, buying off of an individual.
    I think I was somewhere in the neighborhood of $1200 including sales tax on my 462C with one 28" solid steel bar, (wanted a lightweight bar, but they didn't have it), and one semi-chisel chain full house, and a second skip tooth full-chisel chain. Oh! And I bought the oil mix to get the 2 year warranty. The sales tax nails you on the new purchase.
  12. Chud
    Chud
    NC
    I think it’s worth trying to get it for less. I got mine for 1,095.21 otd with the 24” light bar
    Why is he selling? If he won’t budge, I don’t think it’s a bad deal with the extra bar and chains.
  13. thebierguy
    thebierguy
    Hazelhurst, WI
    "Thinning the heard"
  14. The Wood Wolverine
    Screwloose and amateur cutter like this.
  15. JimBear
    JimBear
    I would recommend pulling the muffler & getting a look @ the piston & cylinder if you are serious about buying it. It appears to be a good price with 2 bars & 4 chains if everything else is in order.
    Screwloose, amateur cutter and Ron T like this.
  16. thebierguy
    thebierguy
    Hazelhurst, WI
    Look for scoring? Or do you only see the top of the piston?
  17. JimBear
    JimBear
    You should be able to see the entire exhaust side of the piston, pull the rope slowly & the piston will cycle by, you should be able to see the intake cylinder wall as well. Just use a small flashlight. Most pistons score on the exhaust side first. huskihl can probably give you a better description or better advice.
  18. huskihl
    huskihl
    Yep just what you said
  19. thebierguy
    thebierguy
    Hazelhurst, WI
    Thank you for the guidance. It looks like it only takes four T27 or T30 screws to remove it. Simple enough.
  20. huskihl
    huskihl
    T27
