Brought home a Champion 27 Ton Splitter - Here's Why
Discussion in 'Chainsaws and Power Equipment' started by FreedomFamilyFarms, Jan 3, 2020.
  1. Kimberly
    Kimberly
    The Kangaroo State
    I want a place out of the drive; splitting and processing wood is messy and I have a gravel drive so it makes cleanup a bit harder.
  2. Kimberly
    Kimberly
    The Kangaroo State
    Yes, funny how cheap you can sell something when you take it out the back door in your lunch pail.
    mat60 and In the Pines like this.
  3. FreedomFamilyFarms
    FreedomFamilyFarms
    Auburn, IN
    This is a cold natured machine. Sunday I started it at about 40 degrees F and it took 8-ish pulls. This morning at 25 degrees I pulled it 16 times and it didn't start at all. I'm planning to return it to HD tonight.
    TSC has the 25 ton on display that can be started and demoed so I'm going to give it a "pull" some cold morning when they open.
    mat60, Loon, Dakota Hoarder and 5 others like this.
  4. Chvymn99
    That’s the one nice thing about my swisher. You can disengage the belt to the hydraulics. To start the engine..
    mat60, metalcuttr, Maina and 4 others like this.
  5. In the Pines
    In the Pines
    I've ran my kohler engine in cold weather and it took 3 pulls I guess.
    One thing I added to it was a heating pad to the hydraulic tank to help warm the fluid up and make starting easier. I plug it in a while before I start, seems to work as intended but..
    I haven't tried in the teens or colder yet. I just think it will take a tad longer for it to warm though honestly. I believe it's a 200 watt pad that adheres to the metal.
    I'll see about finding the link when I get home later.
    mat60, Loon, metalcuttr and 3 others like this.
  6. Kimberly
    Kimberly
    The Kangaroo State
    If you like the machine other than the refusal to start when cold you could look at getting a small engine heater. I don't know what is available for a small engine. Dad had a magnetic one he used that could stick on an oil pan but of course with aluminium that isn't an option.
    mat60 and metalcuttr like this.
  7. In the Pines
    In the Pines
    heater
    150w, thought it was 200w but still, if you're going to split below 32 degrees something like this or the magnetic one stuck on the hydraulic reservoir will help.
    mat60, metalcuttr and Hammy like this.
  8. FreedomFamilyFarms
    FreedomFamilyFarms
    Auburn, IN
    Thanks Pines, affordable and low enough wattage for an extension cord.
    mat60, metalcuttr and In the Pines like this.
  9. In the Pines
    In the Pines
    absolutely, I ran a 100 ft extension and it worked. I'm sure the basic orange extension would work, I used a mix over 100ft without an issue.
  10. FreedomFamilyFarms
    FreedomFamilyFarms
    Auburn, IN
    I returned the Champion to Home Depot tonight. I was hoping to edit the initial post but I don't see a way to do it. Hopefully folks will make it to this one before making a purchase decision based on this thread.
    I almost always split when its cold. My land is swampy and cutting wood any time other than mid winter or late summer is asking to make a mess. Between the sloppy assembly, the underwhelming "log table" and the inability to start cold I decided I'd better look around. HD has a 30 day return policy on power equipment and I know I don't have time between now and the 30 day mark for any additional shopping. I'm going to cold start a demo unit at TSC next time we have a good cold morning to see if there's a major difference between the two.
    I once had a single stage snowblower I could start with a power drill. Just removed the pull start and put a 1/2" socket on to turn it over. I wonder if something like that would work on a 200cc engine...
    Thanks for all the good replies on this thread. I'll keep an eye on it in case there are other questions and will post back if I pick up something else.
    mat60, metalcuttr, Hammy and 4 others like this.
  11. In the Pines
    In the Pines
    I understand that my back 40 is the same. It never dried up this year really, I was only able to bring in 2 pickup loads of wood, because of how wet it was, the rest of it is still at my other spot.
  12. FreedomFamilyFarms
    FreedomFamilyFarms
    Auburn, IN
    Whereabouts in OH are you? I'm only about 15 miles from the state line. Very wet year here. Water rose high enough and stayed long enough to kill a black walnut of mine. Hate to see that one go but it will burn nicely ;-)
  13. brenndatomu
    Pretty common log splitter problem...has as much to do with the cold hydraulic oil as anything...not saying that some engines might not fire up easier than others, but heating the hyd. oil up for a couple hours ahead of time, or changing to a lighter oil for the winter would be the best plan...I have heard of others using a gear reduction drill to start them too.
    That disconnect the pump trick works great on the few belt driven splitters that are out there.
    Dad had an old 16HP Kohler powered Bobcat years ago that had the ability to release the drive belt tension for cold weather starts...worked well...it was the only way it would fire up when it was good n cold out...
    mat60, metalcuttr, Hammy and 5 others like this.
  14. In the Pines
    In the Pines
    other side of the state, about 15 minutes from the PA line
    mat60, metalcuttr, Hammy and 3 others like this.
  15. Eric VW
    I’d be one of those in the drill assist starter camp, with my Champion splitter. Under 30°ish in F’s, recoil comes off, 1/2” drill comes out. No shame in it either.
    :yes:
  16. Horkn
    Interesting. Being a chonda, I’m shocked it doesn't start well in the cold. It's different, but a chonda nonetheless, but the predator on our old Didier starts very well in the cold.
    Did you full choke it, or half choke it? Sometimes you just need to find the sweet spot. Sometimes you just need to use the drill to start it.
  17. FreedomFamilyFarms
    FreedomFamilyFarms
    Auburn, IN
    Stopped at TSC this morning. Took 6 pulls to get it started but I did it one handed and wasn’t out of breath when I finished. The rope feels shorter and easier to pull on the Kohler (much less resistance). 23 degrees right now and the machine lives outside. They use the same ISO 46 hydraulic fluid as the Champion. I’m curious why they feel so different. Will likely take one home in a few weeks when I have a pile of rounds to split with it.
    mat60, Loon, metalcuttr and 9 others like this.
  18. FreedomFamilyFarms
    FreedomFamilyFarms
    Auburn, IN
    Bought a new tractor while I waited for them to fuel the splitter. Will update my sig soon ;-)
  19. farmer steve
    farmer steve
    top of the hill york co. PA.
    Been following this thread. Bummer on your original purchase. 20* here and just went out and started my TSC 25 T splitter up. Fired up on first pull. I don't usually start splitting til later in the day but had to see what it would do in the cold. It sits out most of the time with just a rubber top cover. Good luck.
    mat60, metalcuttr, Maina and 7 others like this.
  20. Canadian border VT
    I was going to ask Did it have a choke? Next to impossible to start any small engine up here without one.
