Brought a load in
Discussion in 'The Wood Pile' started by Sam, Feb 22, 2015.
  1. Sam
    Sam
    Southern Minnesota
    The load this morning was the last of the Answer splits I had inside and they measured < 17". These are all at least 20" and a couple I had to make sure to position to the right or left of the secondary air feed tube in the back or they wouldn't have fit so maybe as long as 22"?
    Horkn, wildwest and HDRock like this.
  2. Sam
    Sam
    Southern Minnesota
    So right around an hour later and the air control has been completely closed for the past 20 minutes and we're up to 80 in here. Stove top and sides (above the firebrick) are at right around 600 and the pipe just above the damper (which is full open) is right at 300, all IR gun readings. Dancing secondaries on and off in the firebox otherwise just mostly charred and glowing wood.
  3. cribbed ends
    cribbed ends
    East Tennessee
    Hey Sam, Sounds like you got a good burn, and heat, on the morning load. Plenty of coals to restart. You don't need the newspapers. I would strongly suggest that you move them away from those 600 deg. sides of the new stove. Really got to liking you a bunch in the past few days.
  4. Sam
    Sam
    Southern Minnesota
    Thanks Cribbed. I'll go ahead and move them out of harms way. No sense in taking any chances.
  5. redneckdan
    redneckdan
    Northern Minnesota
    I am really tempted to go get one from menards. I have been fighting trying to get air movement to the other side of the house. About ready to say the hell with it and go get another stove.
    Horkn, wildwest and Sam like this.
  6. splitoak
    splitoak
    jefferson co wv
    Yes..the lodge look..mus be popular..my living room is done in pine also..if i get time ill put a pic up:thumbs:
  7. cribbed ends
    cribbed ends
    East Tennessee
    Thanks Sam. I t would make me feel better. Sorry.
    Backwoods Savage, wildwest and Sam like this.
  8. wildwest
    also me.
  9. wildwest
    what are you burning now?
    Horkn likes this.
  10. redneckdan
    redneckdan
    Northern Minnesota
    An ancient smoke dragon with a malfunctioning draft control. Gets the stove room up over 100f, the far side of the house stays 50-60f.
    Tried some creative use of fans and forced air ducting. Doesn't work too well. Single story dwelling approx 900 Sq ft.
    Horkn, Sam and wildwest like this.
  11. HDRock
    Have you tried small fans on the floor to move cold air towards the stove room ?
    Hay if you have the money , that stove is a good price right now .
    When I went from my dragon to the EPA Lopi my wood use went down a lot, with your stove running that hot you would probably cut your wood use in half
  12. wildwest
    My smoke dragons did not have blowers, would that help him? (assuming the drolet has one).
    Horkn likes this.
  13. wildwest
    two of the three smoke dragons we burned were pipe, no problem, but the last one was a slammer in a chimney, how is yours vented?
    Horkn likes this.
  14. Sam
    Sam
    Southern Minnesota
    I think you'd be pleasantly surprised with this stove then Dan. Like HD said, some fans on the floor trying to move the cool air toward the stove room could be the ticket. That and the wood usage factor as you move into the newer stoves is pretty huge.
    wildwest likes this.
  15. HDRock
    It is better and works like a charm ,I have 2 small fans strategically place on the floor ,running on low, pushing cold air to the stove room and temps at the other end of house (1200 sq ft) are only 3-4 degrees different
    papadave, Chvymn99 and wildwest like this.
  16. wildwest
    I will be doing that once our lil one is old enough to be safe around fans on the floor for our back rooms :)
    HDRock and Horkn like this.
  17. HDRock
    I use these ,I don't know if a kid could even get fingers in one , the sell em at amazon too
    Honeywell HT-900 Turbo Force® air circulator
    Honeywell Table Air Circulator Fan
    Horkn and wildwest like this.
  18. wildwest
    I like the price range too!
    Horkn and HDRock like this.
  19. HDRock
    Yeah , the price is right too
  20. Sam
    Sam
    Southern Minnesota
    How's the noise factor?
