Broken Laptop for parts/repair
Discussion in 'Everything Else (off topic)' started by wildwest, Aug 27, 2015.
  1. wildwest
    I just saw some interest from Kimberly about a broken laptop. I have an HP DV6 that is dead. I'd love if someone could use it. Pay shipping and tell me how to remove the hard drive and I will send it if anyone is interested.
  2. Grizzly Adam
    Grizzly Adam Guest
    Look on the bottom for a hard drive icon, remove the screw for that trap door, unscrew hard drive and unplug cable. Icon usually looks something like this (the one on the left is keyboard, the one on the right is harddrive. Often it is just the oil barrel looking thing with no box around it):
  3. papadave
    Lots of DV6 models WW. Which one in particular?
    Some Dells have a couple screws on the bottom to release the drive frame, and others (like the one I'm using now) are inside under the back/bottom cover.
    Should be fairly simple either way.
    If it's a SATA drive, no cable. It just slides out. You'll know when you see it....or take a pic, and we can help.
  4. papadave
    Forgot the next step......post said pic.:picard::D
    wildwest likes this.
  5. HDRock
    Old laptops are old laptops, not fun to work on, not upgradeable, I have some I would give away, but they are incapable of running much more than XP, not worth anything except for maybe a collector
    Stinny and wildwest like this.
  6. wildwest
    I'll get it out tomorrow..............unless
    It is a 2011 model. Even worth offering parts?
    Or should I just recycle?
    Stinny likes this.
  7. HDRock
    Worth a little money on eBay
  8. wildwest
    Awesome, thanks!! I will let it sit here on FHC for free for awhile, then offer it for $1 plus shipping on ebay after that. (after I remove the hard drive).
    Backwoods Savage, HDRock and Stinny like this.
  9. Stinny
    "not worth anything except for maybe a collector" ... or... therapy... :whistle:
  10. Grizzly Adam
    Grizzly Adam Guest
    It's worth a bit if someone has the same model and it's broken.
    Backwoods Savage, HDRock and wildwest like this.
  11. ironpony
    ironpony
    Mid Ohio
    What is this laptop thing, every one speaks of..........
    wildwest and unclefess like this.
  12. wildwest
    The model is
    dv6-6b26us
    if anybody can use it.
  13. wildwest
    Which side uplugs? Would you know papadave ?
    Stinny likes this.
  14. Grizzly Adam
    Grizzly Adam Guest
    Depending on the model, it might pop out without anything to unplug. Otherwise it will be the one with the cable hanging off of it once you get the drive loose.
  15. wildwest
    Got it, thanks!! Had to take off a second metal housing, done:)
    Stinny likes this.
  16. Kimberly
    Kimberly
    The Kangaroo State
    I wonder if it will fit in a flat rate shipper? What are the dimensions roughly of the laptop. Yes, I would be interested even without the hard drive. You might have to ship the power brick in a separate flat rate box.
  17. Kimberly
    Kimberly
    The Kangaroo State
    The other way would be a priority box and USPS has really gone up on their shipping rates and you won't know unless you put in one and get the PO to tell you the cost.
  18. wildwest
    10" x 15"
  19. wildwest
    Is that the battery or the cord?
  20. Kimberly
    Kimberly
    The Kangaroo State
    I could check at the PO on Monday
