Briggs, Huskee Splitter problem
Discussion in 'Chainsaws and Power Equipment' started by Certified106, Jul 23, 2016.
  1. jeff_t
    jeff_t
    SE MI
    It's an oddball length.
    I don't see why a longer shaft couldn't be shortened. It doesn't have to be perfect, since it goes into a lovejoy. Plenty of room to play with, from machinist's point of view.
    Certified106 and MasterMech like this.
  2. Horkn
    Yes, the cast iron Briggs are much better.
    If you go with a vertical shaft that is longer than original, then it may stick out further. That further out, on a splitter like that means it has less ground clearance, and may not line up with the pump. You can always cut the shaft down if it's too long.
    clemsonfor and Certified106 like this.
