SOLD Breckwell Big E Wood Pellet Stove Large Glass Fire View - 55,000 BTUs Large 100 lb Hopper. This stove is in great shape, very clean inside and out with many new parts. It has the Breckwell Digital control panel with T-Stat hookup. Professionally cleaned and serviced, this is ready to go. Call Don - 603-553-7402 $1295.00 See pics below: Brand new this stove is $2645.00 -- see link below. BRECKWELL BIG E PELLET STOVE Manufacturer's Description and specs It is one of the Largest Wood Pellet Stove. It has 55,000 BTU/Hr with 13 heat exchanger tubes and will heat up to 2500 Square Feet. It has Auto Ignition. It will burn at five Heat Range Settings controlled by a Digital Display readout. It will run either with or without thermostat. When running with a thermostat you can run high/low or on/off when calling/not for heat. Digital diagnostics is availble with and easy to follow digital display panel. It has 81% fuel efficiency is both EPA Exempt and EPA Certified Phase II compliant with only 2.19 grams per hour emissions. It has a standard 3 inch flue exhaust pipe and a 2 inch fresh air pipe with side rod baffle damper to control the fresh air intake. It is Mobile Home approved. Specifications: Part Number SP1000 BIG E Item Weight 350 pounds Product Dimensions 24 x 26 x 54 inches Item model number SP 1000 PWA BIG E w Large Glass Color SATIN BLACK Power Source ac Voltage 120 volts Amperage Capacity 7 A Item Package Quantity 1 Capacity Description 55,000BTU/Hr Large Glass BIG HEAT The Breckwell Big E Wood Pellet Stove has an optional Hopper Extension and will load 350 lbs of Wood Pellets.
