Breaking in a Stihl 500i, any tips?
Discussion in 'Chainsaws and Power Equipment' started by Casper, Dec 11, 2022.
  1. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
  2. brenndatomu
    Do they have a "roll bar" option for those? :whistle: ;)
    Looks good, congrats! :yes:
  3. Casper
    Casper
    I shot video (not on my phone)but forgot to take some pics. Uhgggg.. Will post a YouTube video once it's edited and uploaded. I'm going from a 500i to using loppers cutting pine boughs for the Bissell Maple Christmas party.
    Didn't have anything easy to get to that is huge, but hey, you gotta cut something.
  4. KSPlainsman
    KSPlainsman
    Kansas
    I'm a function over form sorta guy, but good Lord 500i's look good! Congratulations on the new saw!
  5. Yawner
    Yawner
    Louisiana
    About as good looking a saw there is. But the big guy's condom is too short, he needs a magnum.
  6. Eggshooterist
    Eggshooterist
    Erff
    I concur. The look racey.
  7. The Wood Wolverine
    This is what it must be like to stand around the Stihl koolaid cooler. :tears:
    KSPlainsman, Woodsnwoods and huskihl like this.
  8. Rickyblazin
    Rickyblazin
    Pottstown PA
    I was told when breaking in a new chainsaw to never run it wide open when not in the wood…was told it can mess up bearings
  9. Chud
    Chud
    NC
    Lol, maybe some day Husqvarna will replace the guy designing orange belugas. :rofl: :lol:
  10. buZZsaw BRAD
    Awesome! Just be very mindfull where you put it down when wooding. ;) What other goodies in the Stihl bag?
    Whats to become of the crushed one?
    brenndatomu and SimonHS like this.
  11. Casper
    Casper
  12. MasterMech
    That's what is good about these systems vs automotive EFI. They make few assumptions about fuel quality and supporting equipment. They simply tune for best performance under load. Which is exactly how us humans would do it in most circumstances.
    If something was off in the fuel that made it run worse, the computer fiddles with the fuel delivery to improve performance. So adding oil to the mix, would likely cause it to add fuel to the incoming charge, which in turn actually delivers even more oil. An automotive system assumes the fuel is of a certain octane rating or better, and will perform at a fairly narrow range of air:fuel ratio. Some don't even measure the incoming air charge and assume the engine is moving a set volume of air for any given RPM. Get outside of that curve more than what the narrow band O2 sensors can read, and it's game over.
    JD Guy, Chvymn99 and brenndatomu like this.
  13. MasterMech
    But is that actually necessary on an engine that has a plated cylinder bore? The surface finish of a new nikasil plated cylinder for a saw, bike, atv, cycle, etc. is a very different thing than a honed cast-iron sleeve like you'd find in most automotive engines. We are starting to see plated bores in high-end automotive though. BMW, Alpina - I'm not as familiar with others, but I'm sure BMW isn't the only one doing it now. It's a big reason why you don't see oversize pistons available for theses engines, as boring/honing would ruin the cylinders as designed.
    The legacy way of breaking in engines was to put them under full load for several short intervals, as soon as the cam break-in was complete, be that in-chassis or on a dyno. But "breaking in" something that has plated cylinders and roller/ball bearings has to be quite a bit different (if it's even necessary) than cast sleeves and journal bearings. Just like it's not really necessary to break in a roller cam valvetrain like we would for flat-tappet setups.
    For saw engine break-in, I say use good mix, nothing special. I like 40:1 with my stuff, I wouldn't go 32:1 or anything like that just for break in. Keep the Rip Em's reasonable, like the manual says, and always run it at full throttle in the cut. Babying the throttle probably isn't the best for it, and I'm cynical on if idling it for a tank or seven is of real benefit to the engine. (On board with the Beer and BS though!) I've seen timber cutters pin the throttle and limb a straight trunk, maybe we hold off on that for a few tanks. :dex: But I doubt anyone is running a firewood saw in that manner.
  14. buZZsaw BRAD
    Did you get comprehensive/collision for it? ;)
  15. Rope
    Rope
    Alaska
    Put it in the box and send it to huskihl me thinks the porting breaks them in the best.
