Breaking in a Stihl 500i, any tips?
Discussion in 'Chainsaws and Power Equipment' started by Casper, Dec 11, 2022.
  1. Eggshooterist
    Eggshooterist
    Erff
    I have one single experience with the M-Tronic and oils causing problems. Castrol GO mineral at 32:1 caused an off idle stumble in my ms201. In a manually adjusted carb saw, and my 1/5 scale buggy, I ran out of adjustment on the high needle and still couldn't get them to 4 stroke. All 32- 35cc engines. I switched them to my normal 25:1 Dominator and the hesitation was gone in the 201 and the other manual tuned engines acted like they should after switching. So certain oils / ratios definitely can throw a computer saw as well as a manual carb outside of the max adjustment capabilities. I've read belray is another that can cause this.
  2. Eggshooterist
    Eggshooterist
    Erff
    That sounds like it's a tad lean based on the description.
  3. Chud
    Chud
    NC
    It’s mtronic so I’m not sure. Pretty sure I’ve experienced it with the 261 too. Seems like there is a pause before the chip catches on/up that I let go of the trigger. Chains not spinning, but a sec before engine speed drops to idle.
  4. Eggshooterist
    Eggshooterist
    Erff
    I'll pay attention to my two M-Tronic saws to see if they do anything similar. I don't recall them doing it but I'll look for it.
  5. huskihl
    huskihl
    Venison and mashed potatoes
    Lol
  6. Mrxlh
    Mrxlh
    Dat Boot
    If you guys want to make your head hurt, search Mercury Verado making oil and Yamaha SHO making oil…. If you search deep and hard enough, you will find Mercury’s solution. Granted these are 4 strokes, but the bore material and rings are the same. Couple that with the fact that outboards don’t get hot complicates ring seating.
  7. Mrxlh
    Mrxlh
    Dat Boot
    Venison Andouille Cher!!!
    Screwloose, Eggshooterist and huskihl like this.
  8. huskihl
    huskihl
    They kinda do that. Older fuel makes it worse
  9. huskihl
    huskihl
    Never met her. But maybe :yes:
  10. Eggshooterist
    Eggshooterist
    Erff
    If we can get him to Michigan in September we might meet "her".
    Screwloose, huskihl and brenndatomu like this.
  11. Mrxlh
    Mrxlh
    Dat Boot
    Cajun, Cher, Google… Hint, it’s not a box….
  12. Eggshooterist
    Eggshooterist
    Erff
    So not a gaylord....
  13. Eggshooterist
    Eggshooterist
    Erff
    This is the most cordial oil thread ever....
  14. Mrxlh
    Mrxlh
    Dat Boot
    Cher is Dear……Gaylord is box. Andouille is Yehaw backwards Eye eeee!!! If there’s no grease or oil in your gumbo, it’s M tronic or Auto tune trying to satisfy the EPA and no one else….
  15. Mrxlh
    Mrxlh
    Dat Boot
    Don’t you going screwing it up Cher….
  16. Eggshooterist
    Eggshooterist
    Erff
    I've said about all I'm going to lol.
    brenndatomu and Mrxlh like this.
  17. Eggshooterist
    Eggshooterist
    Erff
    Errbody has their own way of breaking in from run it like ya stole it to my drawn out process. Whatever works for ya.
    brenndatomu, Mrxlh and Casper like this.
  18. Casper
    Casper
    Probably why Stihl gave up and omitted it from the manual. How to dispose of it is more important.
  19. Eggshooterist
    Eggshooterist
    Erff
    Odd that yours doesn't say anything and my 2021 model year saw does.
  20. Mrxlh
    Mrxlh
    Dat Boot
    She wears white shrimp boots, can drink you under the table, and beat just about everyone’s azz at the bar, so there’s that…
