Brand new pump locked up?!
Discussion in 'Chainsaws and Power Equipment' started by isaaccarlson, Dec 22, 2023.
  1. brenndatomu
    Lightweight...:p :rofl: :lol:
    Understand...have a good :sleeping:
    metalcuttr and Joful like this.
  2. Joful
    Joful
    Actually, just did two runs up to my barn in my PJ's, colder than a witch's... But splitter is down in the woods right now, means trudging thru snow and carrying a work light to see.
    If I were planning ahead, I'd have towed it back up to the barn with me, when I finished cleaning up today, as it's going to be warm, rainy, and muddy this week.
    metalcuttr and brenndatomu like this.
  3. Joful
    Joful
    I had a chance to check things out yesterday, and there is definitely wear on the push plate between end of cylinder rod and the wedge. What I can't tell, until I get a new bolt in there, is if the wear in the bolt holes is the same as the push plate. Since the OEM bolt was grade 5, and the wedge assembly appears to be unhardened mild steel, I'm guessing most of the wear in the push plate was matched in the bolt holes. I'll know when I get the new bolt in there, push it all snug, and see if I can slip a feeler gauge into the gap. If I can, then I'll just shim it back out with some stainless shim steel as best I can, given the way it's worn as a round spot into a large flat surface.
    edit: In fact I'm thinking now that I should just shim it back out tight, even if the bolt holes are wallowed enough to prevent the loading from landing on the new bolt. I say this because things will continue to wear, and it'd be better to have new wear into disposable shims, than continuing into the wedge push plate.
    I'm guessing the cylinder rod itself is quite hard, maybe 2x or greater yield strength than the steel from which the wedge is made, so probably very minimal wear on that.
  4. brenndatomu
    I cut a thin "puck" to fit that same worn spot on mine...put a little gasket sealer on it and then ran the cylinder rod up tight against it to squish the sealer out, then let it sit until the next day to dry.
  5. isaaccarlson
    isaaccarlson
    Colfax, WI
    Just because atf runs at 180 or more in a car doesn't mean it's good or even ok. Atf should stay below 160. Car makers run it hotter to inflate mpg numbers. I was seeing 210+ on our toyota before adding the cooler and the fluid was burned/brown. The cooler dropped the temps to 130-140. A stacked plate cooler should flow plenty for you.
  6. isaaccarlson
    isaaccarlson
    Colfax, WI
  7. Joful
    Joful
    Chaz and brenndatomu like this.
  8. isaaccarlson
    isaaccarlson
    Colfax, WI
    Good thing we don't live in California then.
  9. Joful
    Joful
    I've been looking around for oil coolers with 3/4" NPT or -12 AN fittings, since my whole return path is all 3/4", and I had believed that was recommended for the return sizing at 19 GPM. However, I'm really not finding much in the way of a low cost oil filter in 3/4" or -12 AN fittings. Got a source?
    I did find some -10 AN's, which would probably do okay, if I can't find a -12.
  10. brenndatomu
    If you can't find one, I'd be temped to install a tee fitting(s) so you could split the flow, most through the cooler, some through a "bypass" line...adjust the balance with a valve.
    Chaz and isaaccarlson like this.
  11. Joful
    Joful
    Hah... I was thinking the same, but to split through two coolers. I like your idea even better, though.
  12. isaaccarlson
    isaaccarlson
    Colfax, WI
    You could use an orifice like I did on my filter.
    brenndatomu likes this.
  13. Joful
    Joful
    Not following you. Could you describe?
  14. isaaccarlson
    isaaccarlson
    Colfax, WI
    This is my hijacked thread after all...:thumbs:
    Go back to the first page and look at the pictures. There is an explanation
  15. The Wood Wolverine
    Pulled my old pump today so I'm very close now to buying a new one. Looking at the one in your link above and this:
    19 GPM Hydraulic Log Splitter 2 Stage Gear Pump, Faster replacement for 16 gpm | eBay
    which I was linked to on another thread somewhere. My original one did not have that 45 inlet bend and it did have a cast body, not aluminum. And concerns there? I've processed a LOT of wood w/ this old pump and don't want to sacrifice longevity.
    Chaz, isaaccarlson and brenndatomu like this.
  16. brenndatomu
    Nah, the aluminum bodied pumps will last a long time too...that's all you see on log splitters for years now.
    You can probably still buy a cast pump, but you are gonna pay for it! It would be cheaper to buy 2 aluminum pumps, which would certainly last as long, or probably longer than one cast pump, and still be less $ total.
    Just FYI on those elbows for the inlet...they have a locknut on them and can be turned whichever way you want it to be.
  17. The Wood Wolverine
    Next question, the 18.5 says 2.8gpm on the high side, the 19 is 3.6. Is that noticeable on the splitter?
  18. brenndatomu
    You mean between the 2.8 and 3.6? Nah, you'd never notice that lil bit...they often don't fully go into the high pressure stage anyways, unless you are crushing rocks :rofl: :lol: its usually a gradual shift when that internal bypass starts to open up...
    Chaz and The Wood Wolverine like this.
  19. isaaccarlson
    isaaccarlson
    Colfax, WI
    You'll see a little difference. Run the higher gpm if you have the hp available. There are two valves in the pump. A load pin and a check ball. One opens when the shift point is reached and the other closes to isolate the high pressure from the high gpm. It is a definite change in cylinder speed and motor load when it shifts. How much hp do you have on tap?
  20. isaaccarlson
    isaaccarlson
    Colfax, WI
    The high pressure should be isolated from the high flow side as soon as the load pin shifts and the check ball closes the passage.
