'bout bit the big one today...
Discussion in 'Everything Else (off topic)' started by brenndatomu, Jan 22, 2016.
  1. JC@ATL
    JC@ATL
    North of the ATL
    God has a plan for you...
    wildwest and brenndatomu like this.
  2. wildwest
    x2!
    brenndatomu likes this.
  3. mattjm1017
    mattjm1017
    Wow sounds like you dodged a bullet there glad to hear you weren't hurt. I'm guessing that you were able to loosen the terminals and not get shocked because you didn't touch anything else and also there was no load (you said you had turned the pumps off) but no matter what the good Lord was looking out for you today.
    brokenwing, Chvymn99, Stinny and 2 others like this.
  4. Stinny
    Very glad you're still with us brenndatomu ... it tried to getcha and it just couldn't do it... :dex:
    brenndatomu, bobdog2o02 and wildwest like this.
  5. lukem
    I would assume new underwear is in order...it would be for me. Nothing evacuates the bowels like a 480 arc flash.
    Chvymn99, Stinny, brenndatomu and 3 others like this.
  6. Horkn
    Wow! Glad you are OK. Electricity is nothing to be careless around.
    Chvymn99 and wildwest like this.
  7. brenndatomu
    Normally, yeah, you would have peeled me off the ceiling, I barely jumped today...dunno why, I am usually very cautious and kinda jumpy when working in electrical panels, especially if it is not completely dead (and when are they ever completely dead :confused:)
    I think my caution meter got a hard reset today.
    Sounds like a few of you work with electric too...I just ask that the next time you are getting ready to do something stoopid in a panel that you just remember this thread and think "Don't be like brenn d" :emb:
    basod, Gark, rottiman and 4 others like this.
  8. Redfin
    Redfin
    central Pa
    I'm glad to be reading your post Sir. Wow.
  9. Redfin
    Redfin
    central Pa
    Thought about that, maybe I should have said I'm glad your here to write your post. Many years ago I had 65 Amps of -60vdc go to ground while I was swapping to a new bus bar. I had 10kv gloves on and was on a 15kv mat. It welded my Kline's to the rack. Scared the everloving crap out of me. I'm glad your OK.
    basod, rottiman, wildwest and 3 others like this.
  10. XXL
    XXL
    Ontario, Canada
    A wise man will learn from his mistakes. Glad to hear you're unhurt.
    wildwest, brenndatomu and bobdog2o02 like this.
  11. brenndatomu
    Yep...for us all...for us all!
    wildwest and Scotty Overkill like this.
  12. Scotty Overkill
    We did an arc-flash class several years back when I worked in the maintenance department at work....it was INSANE watching some of the demonstration videos.....it's unreal just how fast, powerful, amd devestating that arc blast can be.....
    basod, brenndatomu, rottiman and 3 others like this.
  13. lukem
    We had a maintenance tech try to hang an safety sign and drilled into a panel on the other side of the wall. It was only 240 but mushroomed the drill bit so bad you wouldn't believe it. 480 is scary stuff.
  14. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    If you think 480 is scary look at the voltage before the transformers
    brenndatomu and wildwest like this.
  15. lukem
    Primary is a whole nother animal. There are plenty of things that CAN kill you. That WILL kill you.
  16. Oldman47
    Oldman47
    Illinois
    Glad to hear that you survived unscathed. I saw a guy I worked with get bit just turning off a MCC breaker on 480. He had 3rd degree burns to his hand because the fire ball came out of the small gap on the closed breaker door to get him.
  17. wildwest
    We all knew what you meant. AND I agree.
  18. jetjr
    jetjr
    Pa/Md line
    With the concrete issue I have seen primary lay on the ground and burn on more than 1 occasion. Somewhere at the house I have a piece of "glass" that was concrete at one time. Glad to hear your ok, 480 and pretty much any three phase is a nasty animal.
  19. Chvymn99
    Glad to hear that it turned out good... That's a scary situation...
  20. Locust Post
    Glad you are still hangin around Brenn, as you said and we agree....God's grace.
