Bought a wood hauler
Discussion in 'The DIY Room' started by JoshC, Oct 6, 2014.
  1. eatonpcat
    Love the truck!!!
    JoshC likes this.
  2. Certified106
    Certified106
    In The Hills
    The truck turned out great! Love it !
    JoshC likes this.
  3. JoshC
    JoshC
    Culloden, WV
    Thought I'd report back in and share an update. I've used the truck and handful of times. Since I got the timing fixed and flow masters installed, it's fun to drive!
    A couple of weeks ago I thought I'd troubleshoot my cooling issue. I pulled the water pump off expecting to see it rusted away. But, it was actually perfect looking. So, I put it back together and poured some radiator flush in the system. I ran it for a while and it developed a leak. Where from? The weep hole on the pump of course. So today I bought a new pump and radiator cap and installed them. Since I was going all in, I figured I'd hookup the lines to my heater core and also reinstall my thermostat. Wild, i know right?! Topped off with fluid and started her up. I half expected to see coolant spray inside of the cab but it didn't. Ran it till it got warm and by gollie if I don't have heat in the cab now! I watched my gauge to see what it would do when I hit 180 degree and sure enough the thermostat did it's job and I'm a happy camper!
    Stinny, wildwest, HDRock and 6 others like this.
  4. Woodwidow
    Glad everything is working well. Extras like heat in the cab is a bonus especially with winter nearly upon us.
  5. JoshC
    JoshC
    Culloden, WV
    Yeah no kiddin! My brother and I ran out real quick in a rain storm on sunday to grab a load I had cut Saturday morning because I was afraid someone would steal it. Although I was just down the road from the house, having no heat makes it difficult to see!
    I do have a question, maybe you all will know. I don't have any reverse lights (they don't come on). I haven't started to troubleshoot the issue yet, but do you know where the reverse light switch is?
  6. basod
    basod
    Mount Cheaha AL
    You have two different years of body/chassis there is a neutral start switch located on the driver side of the transmission in later models, and older ones had it located in the steering column
    JoshC and wildwest like this.
  7. Razo
    Razo
    Pennsylvania
    This really came out nice!
    JoshC likes this.
  8. firecracker_77
    firecracker_77
    IL
    Man is that pretty. I love that dump bed. Real jealous! :D:drool:
    JoshC likes this.
  9. JoshC
    JoshC
    Culloden, WV
    Things are going well used the truck to haul some brush I cleared Sunday. And of course the heater core is leaking in the cab! I figured this would happen. This isn't going to be an easy job.
  10. HDRock
    that sucks your heater core is leaking, good luck, heater cores aren't easy to work on for sure big PITA
  11. basod
    basod
    Mount Cheaha AL
    heater cores in an old truck like that aren't too bad to swap out, most the work should be from the firewall side in the engine compartment.
    And as you've already figured out - no defrost is kind of scary;)
    Don't know if you chased down the backup lights(if they are needed for inspection disregard) but a simple toggle switch with some halogens mounted off the frame will light things up pretty easy
    HDRock, JoshC and Stinny like this.
  12. bearverine
    bearverine
    Winchester, Indiana
    Now that is a West by God Virginia truck! Like the others, I'm so jealous of the dump bed!
    Stinny and JoshC like this.
  13. Freakingstang
    Freakingstang
    that's quite the wood hauler you have there josh. I'm jealous.. sure beats my rickety trailer that I have to unload by hand..... awesome job.
    eatonpcat and JoshC like this.
  14. JoshC
    JoshC
    Culloden, WV
    Thank you. It finally quit raining long enough to get back on the heater core. I pulled it out a couple of week ago. So now i have working heat, cooling the way it should and no leaks. Reverse lights are next. Had to take a break for deer hunting season :D
  15. Stinny
    Wow. Quite a project Josh. Nice job on all of it. Hydraulics rock!
    JoshC likes this.
