bought a EastonMade 12-22 firewood splitter
Discussion in 'Chainsaws and Power Equipment' started by Jim Barry, Jan 4, 2019.
  1. Jim Barry
    Jim Barry
    Loch Katrine, Nova Scotia
    Another video, up close and personal :) I was pulling chunks off the tail gate of the 1 ton parked nearby.
  2. Creekin
    Creekin
    Manitoba
    I like it! Looks quick, doesn't even struggle through
    metalcuttr and T.Jeff Veal like this.
  3. In the Pines
    In the Pines
    nice looking unit for being used, looks like it was taken care of, I like the gauge as well.
    metalcuttr, T.Jeff Veal and M2theB like this.
  4. Jim Barry
    Jim Barry
    It actually had a hard life formerly. I had it sent back to the manufacturer for a maintenance check and Andrew Easton fixed it up right nice. No charge too!
  5. Canadian border VT
    What is the height of the beam on that bad boy? Or about how tall are you Jim? Height of a horizontal splitter is a very important question that i do not always see posted!!
  6. Jim Barry
    Jim Barry
    I'm 6ft tall. Hands by my sides, its the same height at the beam and working area of the cradle. I put a tape measure to the beam the ground, about 25". Its a comfortable height. Any specific questions you might have you could always ask the builder, Andrew Easton. He's very helpful.
  7. Canadian border VT
  8. nsmaple
    nsmaple
    Nova Scotia Boonies
    That seems low. Is that to bottom of beam?
  9. Jim Barry
    Jim Barry
    Beam is 25". Cradle that holds the block f wood puts the working height to about 30-32"
  10. Jim Barry
    Jim Barry
  11. Jim Barry
    Jim Barry
    Using the 6way wedge here
  12. JCMC
    JCMC
    Just outside of Shushan, NY
    Bending over to tie shoes.:pain:
  13. Unclefish
    Unclefish
    Northeast
    How's your eastonmade 12 22 holding up. I order 1 to being built now. Anything you wish you did different.
    I have the 6way and boxwedge with pull back arm coming. Thanks for input
  14. Marvin
    Marvin
    Huntingdon, Pa
  15. Chaz
    Chaz
    Southwestern NY
    Welcome aboard Unclefish
    :handshake:
    And Merry Christmas
    :wreath:
    T.Jeff Veal, Chvymn99 and Marvin like this.
  16. Unclefish
    Unclefish
    Northeast
    Thanks. Merry Christmas to you also
  17. Jim Barry
    Jim Barry
    Its held up well. Split everything I've ever put on it. I find myself using the 4 way wedge mostly all the time. The box wedge is neat but it does produce a bit more waste for the type wood I split.
  18. Unclefish
    Unclefish
    Northeast
    I have noticed on the videos the 4 way will even split big pieces much easier. Just handle it more times. I have 1551e medium indoor wood furnace so if I can get it through the front door it goes in. I really like those big chunks so it will go all day while we are at work. My parents have a small stove and don't like the bark mess. So I figured I will load them up with the nice no bark squares from boxwedge and I Will burn all the rest. I don't mind getting a bunch of small pieces cause usually by the time I get home its down to a bed of hot coals. Through some in and some nice chunks on top and takes right back off again.
  19. Farmchuck
    Farmchuck
    Nepa
    Exciting times!!!!:yes:
  20. Unclefish
    Unclefish
    Northeast
    Machine came and giving it a work out. Not sold on this box wedge but really like the 6 way and I should have order the 4 way also. 20200414_153240.jpg 20200415_143527.jpg 20200415_143506.jpg 20200415_153717.jpg
