Bluetti AC500 w/B300K battery for our home backup/supplement system install and review
Discussion in 'Everything Else (off topic)' started by jtakeman, Feb 21, 2025.
  1. Burnin Since 1991
    Burnin Since 1991
    Your shed panels look great. I'm thinking of doing something similar for charging my batteries for my cordless Dewalt tools. Three seasons anyway. They're isn't any heat in my shed.
  2. bogieb
    No heat in my shed either (or lights or anything but solar panel connectors). If sunny and in the 20's, the batteries will keep themselves warm enough while charging just sitting on a table. I haven't tried in the single digits yet.
    I recently got an HDX tote w/lid while HD had them on sale. Took some scraps of foam shipping inserts and rigid foam insulation boards to insulate it. I did a very sloppy job with just throwing a few pieces in there and it was by no means well insulated. It was successful in keeping a power station plenty warm (went from 70's to mid 60's) while charging it in the upper teems. The power station was out charging for probably 6-7 hours (goodness, I hate the winter sun angle).
    I also just received a couple of seedling heating mats. They draw 20w and "should" help keep a station warm in a tote during really cold weather. Not that I could make much solar power, but it is more about a project and less about satisfactory results.
  3. Burnin Since 1991
    Burnin Since 1991
    That's great information. I won't be able to do anything with mine till it gets warmer. I've got other projects I'm working on inside where it's warm. What are you thinking about running off the power station, in the future?
    T.Jeff Veal likes this.
  4. bogieb
    Spring thru fall I run all my kitchen appliances, except the refrigerator from power stations. Additionally my clothes washer and computer/router/wifi are run from power stations. Once it starts getting warmer, I also run window fans in the morning from stations.
    I've been able to start "spring" early this year, since the I have the shed panels. The last couple of "springs" haven't started until mid-march or April in previous years as I've used portable panels so I had to wait until I wasn't wading thru hip deep snow. When I get better/stronger sun, I also charge my Ryobi tool batteries.
  5. jtakeman
    Just before the last sn*wstorm I swapped out the Ac500 with the AC200L power station. Only because it has another 2048wh battery build in. I noticed that I hardly ever draw more than 1600w So I figured it would handle all I have backup on the transfer switch. So far so good and I can run everything over 10 hours with the bit of extra watts.
    Pretty sure I'm going to go to a hybrid solar inverter out in the garage with the income tax return. So the Ac200L will stay in the house and sister it with the AC500 and I can expand the critical circuits we are backing up and supplementing with solar. Try to double or 3x the savings once we expand the panels.
    Currently gathering approx 800Kwh with the 2 panels be nice to get over 2400Kwh with 6 panels. And I would still have roof space to add 4 panels just for the garage solar.
  6. bogieb
    I'm sure you accidentally included the "k" or forgot a decimal point- otherwise those are monster panels. I'm only getting 8.5 kwh all day with the house solar, with 6 x 400w panels clear of snow plus 4 panels partially covered with snow.
    I can confuse myself enough, don't need help in that area :rofl: :lol:
  7. jtakeman
    Oops! Yes, I gather 800w ish an hour and 2.4kwh per day with the 2 panels on a good day. I sorry!! Sunday was a great day here for solar I gathered 2.95Kwh. If I could double that I would be happy.
  8. jtakeman
    Sn*wmagedian round 2 coming thru. I've got the power station set up as backup in case the grid goes down with the winds they are predicting. I'll never notice if we even get a blip with the grid power! :D
    No way to get the gas gen connected with the current mess thats out behind the house. I'll need to create a path that will take a good while. Or get creative with a power cord to the power station?? I'll cross that when needed! I guess I'm ready??
  9. Burnin Since 1991
    Burnin Since 1991
    I started working on my shed solar project a few weeks back. Having the Aferiy P280 in the family room didn't work out. When it was charging with solar, the fans got a bit loud for my wife's liking so I moved it out. I actually have a childs playhouse that was built by the previous owner. It is 8'x8' and my shed is right next to it. The shed is 8'x12'. They are right next to each other. The previous owner also ran a 20amp circuit from the breaker panel to the shed and playhouse so they both have electricity.
    I cleaned up the playhouse a few years ago and it is primarily used for storage. The shed. Well it's a mess inside. It got commandeered by a red squirrel about 10 years ago and it got pretty tore up. The squirrel broke the only window and tore a hole in the roof when I sealed up it's egress. I boarded up the window and replaced the roof about 5 years ago, but the inside was such a mess that I didn't know where to start. So I didn't. Until now.
    Right now I'm getting some of the electrical squared away.
    Good fun. I hope everyone has recovered from the winter.
    Have you decided what inverter you will be using? EG4 has really dropped their price on the 12000xp. It's only a few hundred more that the 6000xp
    They are both the off grid models, but they allow a grid connection to charge the batteries and supply power to the house if you don't get enough solar. You can't sell your excess power back but it has merit. The prices on the hybrid models haven't dropped.
    IHATEPROPANE, bogieb and eatonpcat like this.
  10. jtakeman
    No not yet, :(
    But the EG4's are on the list to check out. That and the SRNE 8K are tempting. I don't really need grid tie as I don't have a feed going to the garage. But would like to have the genny able to charge on the low sun times if possible to keep the batteries topped off. I want something with split phase for sure!! I don't want to settle for any of the cheap ones that are just single phase. So If need be I will hold off on the invertor this year and make it a #1 priority for next! I can still bring the power station out there for now if need be.
    Priority right now is getting the inground oil tank out as the house insurance just went nuts. Once the tank is out we can shop around for other policies. This was the only policy we could get with the inground tank when we bought this place. Then the front windows need to get replaced(I'm sick of freezing in the office). I think solar is 3rd on the priority list of todo's!! And adding more panels is before the garage invertor. Need to get the house capture up from 4Kwh to 12Kwh to speed up the ROI.
  11. Burnin Since 1991
    Burnin Since 1991
    I take it you're no longer heating with oil?
    Depending on how much power you need out there the eg4's sound like a good fit. They're interesting and very easy to setup. New windows and when you're putting them good seal them up good to stop even more draft. Save money on the heating bill too.
    The heart of my project is the P280. It has 2048wh and I ordered a 2048wh expansion battery for it so I will have 4k in battery out there. I have 650w currently of panels and I'm looking to add at least that much more this year. Right now I'm running the two sheds with 20amps from the P280 and no issues with not having enough power. The 650w of solar is keeping up so far but it's not optimal.
    eatonpcat and IHATEPROPANE like this.
  12. jtakeman
    No we will still burn oil, Mainly on the coldest days to assist the stove or when price is affordable. Got to keep that option. We installed a new above ground tank last year and were waiting on that to get the old tank removed.
  13. Eckie
    Eckie
    Amy updates on this thread? I've been looking at threads and videos of backup power stations/ solar etc, not to convert house but as emergency power in case. It's a bit daunting trying to figure it all out....
  14. bogieb
    Not the OP, but a couple of months ago I got an Ecoflow Titan 5000 Plus installed as a backup to critical circuits (full disclosure, I was picked to be a beta tester, so the inverter/battery, SHP10, and installation was free). The Titan itself can be run off either the SHP10 (smart home panel with 10 circuits - two of those are 2 phase), or an MTS and also handles 240v. Also can take in huge amounts of solar. The Titan 5000 (not plus) is slightly different than the Plus, but is also 240v capable. The Titan Classic is the 120v version and has its own SHP10 that is for 120v only.
    The system is expandable at 5kwh at a time, to up to 30kwh with Extra Batteries (which I just bought and installed 1 EB).
    Look around at the Anker offerings too - it seems they have some new stuff out.
    Really, there is no right or wrong answer for the manufacturer as long as you stick to well known companies. There is something out there for nearly any circumstance. And any of those 3 will have people online complaining about the product and/or the customer service - that is the nature of social media and I wouldn't let any of it scare you away from these 3 manufacturers (there may be other too, I just don't follow them).
  15. Eckie
    Eckie
    How do you get on that list??!!??
    I would like to get something that is 240 to handle the well pump. I could run the same generator for that I have now for that, but would be nice to have the capability system wise.... I'm going to get a smaller 3000ish W inverter generator to run stuff when I don’t need the bigger one, to help maximize fuel, and it can help recharge the batteries when I get to that route....
    Right now my thoughts are that this would be an emergency backup system, not tied into the house. Have ready, pull.out when needed.
    Do you use the same brand extra battery as the unit? Do you have any experience with the server or golf cart batteries?
    For the power station, the pecron f5000 looks like it has good features and can do 240. But like many of these devices, it's backorder for a while. I have also seen quite a few vids about sourcing components and building your own. Plus to that is you can swap out parts if one fails. Downside is size / arrangement and ease of portability.....
    I might should start a dif thread to not hijack someone else's.
    bogieb, MikeInMa, brenndatomu and 3 others like this.
  16. jtakeman
    Thats how I started and have steered towards running it daily for savings on the electric bill. Might as well use what you have and get more ROI. I'm saving almost $20 a month on average with just 2 540w panels. Isn't much but helps!!
    Joining in here is fine, No worries.
    They are OK, But in my experience I wasn't very happy with their app and the unit itself failed rather quickly. I lost the ability to charge with grid power. Shortly after solar also quit. Personally I would stick to the top brands like bb said. Ecoflow Anker bluetti all get better reviews and have far less problems as noted in the forums.
    I do, I have a server rack battery and 4 12v Lipo4 added to my Bluetti. Check out Jasonoids or theres a trick for that's video's. Explained much better than I can.
    www.youtube.com/watch?v=k3-b13V4isg&t=44s
    www.youtube.com/watch?v=IDQ4rfxd_ng&t=534s
    My complaint about using the external batteries compared to oem expansion batteries is you can't turn the unit off unless you unplug them where oem is controlled by the power station. Also don't see the full expansion capacity like the oem on the display. But they do work and add capacity much cheaper then buying oem batteries.
    Congrats bb, Thats awesome!!
    Feed back and updates please!! :D me jealous!!
    bogieb, brenndatomu and IHATEPROPANE like this.
  17. Eckie
    Eckie
    One thing I've thought/wondered about but haven't seen mentioned on any sites or vids... does this kind of thing need to be run/exercised for it to function properly, or is limited/emergency use ok?
    Thank you!
    Good to know. Hard to tell online what the real deal is with products...if people are being honest vs getting paid somehow for whatever they're talking about. And you always have some people who complain about something with a product, no matter how good it is....
    I have watched quite a few of his vids, and that's the one I referred to about making one from pieces...
    I will say, I'm not fluent in this whole arena, trying to watch as much (good) info as I can and soak it up/process it...
  18. jtakeman
    I've run my Bluetti for over a year now and no issues with everyday use. I just need to remember to store up juice if storms are coming instead of running the batteries down. I don't normally run mine down bellow 50% reserve, But if a storm is brewing I do try to hold them closer to 100% to be ready for an outage.
    I didn't trust my Pecron for daily use once the charger went flakey. I can still charge it through the auxiliary battery port and just keep it for a reserve JIC. Worse case I can use the battery capacity like I do with the server rack battery.
    Many of the youtube reviewers are paid, So I don't trust them as far as that goes. I just use them to pick up tips and tricks. I joined Bluetti-Ecoflow-Anker and Pecron facebook groups where the users post their experience. Pretty sure thats where bogieb was selected as a tester.
    That's where the user go to post issues with their units and look for feedback on how to correct their problems. You can also pick up tips and tricks too.
    He's a real user like we are. I think he gets products donated??
    Jasonoid is the guy I like to use for new product reviews as he gives them a work out and tests all the features, Another is Hobotech. They both test and show the true limits of the units. There's a few other reviewers I do follow, but they aren't as thorough about them.
    You don't need to be fluent, You can learn as you go, That's how I picked things up. A tip for you is get a killawatt meter and get all the watt hours needed of each of the things you want to back up.
    Keep us posted!! :D
  19. Eckie
    Eckie
    Dang, I thought the pecron 5000 looked pretty good.
    Not sure if I've seen the Jason guy.... Have you ever watched "how to woth Doc"? If like his vids too.
    I ran my generator today. On videos people talk about putting X% load on them. Do they use one of those kilowatt meters to know how much they're putting on a generator? Mine doesn't have any kind of information screen, just an hourmeter....
    IHATEPROPANE likes this.
  20. jtakeman
    I haven't seen a killowatt meter rated for 240v, Just 120v. I've seen people use those fancy remote power monitors for 240v on their main panels. I suppose it would also monitor what the generator has for a load during running.
    Can't say I have. but will keep an eye out.
    I'd recommend joining the facebook group and do a bit of reading before purchase. I'd also do the same for any of the models/brands your interested in. That is the place that high lights all the know issue. Most of the groups have company techs that also monitor the threads. Pecron may have improved since my purchase.
    I'd also google the model your interested in and read the ratings and reviews.
    bogieb, IHATEPROPANE and Eckie like this.
