BK Princess for sale
Discussion in 'Modern EPA Stoves and Fireplaces' started by papadave, Dec 9, 2015.
  1. HarvestMan
    HarvestMan
    Southeastern Michigan
    My Fireview is even more boring than your BK in "black screen" mode; the glowing cat is not visible unless you are on the floor looking up above the glass; I suppose I could lay a mirror on the floor to make it easier to see. o_O
    Can you share a bit about how you burn your BK? What setting would you need to achieve some lazy flames?
    Eric VW likes this.
  2. HarvestMan
    HarvestMan
    A cat stove will surely help that. While my old stove was a cat stove, it was rear draft and not designed air tight so I too had rather short burn times. If one day I get a BK, I would likely run it as I am running my Fireview; flames when I want something to look at, dark screen when I have other things to do or am sleeping. Good luck with the BK search.
    Eric VW and papadave like this.
  3. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    It cycles from da r k screen to lazy flames as the thermostatic damper does its thing. As far as a setting, can't tell ya. It all depends on OAT and barometer. As it gets colder the set number actually gets lower too (less air opening). Hope that helps. I still want to do my time lapse burn but it's been so warm that I don't want to load it up to the gills or I'll cook us out, even on a long low burn....
  4. HarvestMan
    HarvestMan
    I would love to see that. :popcorn:
    papadave likes this.
  5. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    Just waiting for the weather to turn, it might happen this year.
    Eric VW, HarvestMan and papadave like this.
  6. Highbeam
    Highbeam
    It would be cool to see the flare up cycles. This year, for some reason, my bk has been more boring than usual. No flame, no glow, blackened glass top to bottom, but steady glowing cat and no smoke.
