Big freebie stack, help a newb ID and tell me what to get!
Discussion in 'The Wood Pile' started by chunez, Apr 25, 2023.
  1. Eric Wanderweg
    It's worse than that... Do those long green shoots look familiar to you? They hang down on a living tree that is still upright. As spring progresses they turn an almost neon green color. It's a tree that loves water and grows fast as evidenced by the large growth rings. Stick one of those logs in the muck and it just might grow a brand new tree ;)
  2. chunez
    chunez
    WI
  3. Eric Wanderweg
    Winner winner chicken dinner
  4. John D
    John D
    Syracuse ny
  5. Eric Wanderweg
    The OP called it right, I just did my best to help him figure it out for himself. I had faith that he'd get it eventually :) I'm a huge believer in the "teach a man to fish" approach.
  6. chunez
    chunez
    WI
    Came back from the eclipse to a beautiful bounty of walnut!
    D7A5509C-4ED0-4536-A616-0EE0A501E74A.jpeg 90A88785-5C45-4A56-A45D-89D47BE3E55D.jpeg 55FCABA4-FC39-4908-98E9-24B317327AE6.jpeg BCDBE186-CF60-42B1-9B19-897FC0A87CF5.jpeg A024C0EE-7ED0-42EF-8516-B8EEC1C0DD7B.jpeg 9E15F6CD-3E8B-43EB-B905-7E5974412D6E.jpeg 7274F72E-CAB4-401B-9D98-8C3D69CB3DB7.jpeg DA4D0D7A-CBB3-47B1-862F-EDAC87D2D40C.jpeg
  7. sms4life
    sms4life
    Gorgeous looking slabs there...and good $$$
  8. The Wood Wolverine
    John D, metalcuttr, sms4life and 2 others like this.
  9. T.Jeff Veal
    X2
  10. chunez
    chunez
    WI
    Learned some valuable lessons on raker height and dirty bark yesterday. Turns out you actually have to gauge each raker individually and you can’t just take the same amount of swipes from each one. You don’t want all your rakers to be the same absolute height (counting swipes), but rather the same height in relation to its tooth (using the gauge for each). As you sharpen your chain inevitably some teeth will be taller than others so it follows that rakers will rarely all be the same absolute height as the chain is worn.
    Doing that helped quite a bit but then it just totally quit cutting after the first slab. I thought it felt like a dull chain but that can’t be the case because I just sharpened it, haven’t hit anything and I usually get 8+ slabs between sharpening so I shimmied and pushed my way through. As soon as I started the next cut I knew it was somehow dull and stopped to sharpen. Turns out the bark can dull a chain real quick depending on what’s in there! After the raker tuneup and an additional sharpening, the black walnut production hit full swing. I even debarked one of the logs and it cut amazing!
    515F73CB-0046-4345-96BF-EBD8E16810B7.jpeg 00FFD244-96DE-4FD1-A550-5A840DC64174.jpeg 21448E7D-7C27-433C-8F5A-A441FCB80555.jpeg E6554118-48D8-4381-ADF6-FD9B84C6B3AE.jpeg
    John D, sms4life, T.Jeff Veal and 5 others like this.
  11. The Wood Wolverine
    I found the progressive raker filing guides after hitting metal multiple times while milling. Each time it damaged one side of the chain only and as I filed damage away the chain began to cut very crooked (using those sit on top of the chain raker guides). So much so that it bound up the mill and I couldn't push anymore. A little research led me to the Husky branded ones.
    [​IMG] [​IMG]
    One tune up with those and it was back to cutting perfectly straight. I not so long ago bought the WCS plate and it works great. The options of aggressiveness allows me to fine tune the bite to my ported saws. Check it out if you haven't.
    [​IMG][​IMG]
  12. T.Jeff Veal
    Those are great. We have one for 3/8, .325 & 3/8LP
  13. chunez
    chunez
    WI
    Is this the illusive pignut hickory? Almost thought maple but the leaves have got me stumped
  14. John D
    John D
    Syracuse ny
    Nice find just sitting at the street for the taking
    Sand hickory
    T.Jeff Veal likes this.
  15. buZZsaw BRAD
    Look like elusive shagbark to me, but there are a couple other varieties that look similar that aren't common around here.
    John D and T.Jeff Veal like this.
  16. The Wood Wolverine
    Agreed. That’s shagbark. Take every last piece. Way high on the btu chart.
    buZZsaw BRAD, John D and T.Jeff Veal like this.
  17. chunez
    chunez
    WI
    Thought this was a giant black locust tree at first but now I’m thinking poplar or Siberian elm?
  18. chunez
    chunez
    WI
    Found some storm damage black locust to remind me what it looked like. Should be able to get some 8ft 4x4s out of these for raised beds
    F504888B-D5F0-4D03-9008-AF5279FE55E0.jpeg D10C43E1-B58F-4BBA-8658-B35EF250A93B.jpeg
  19. John D
    John D
    Syracuse ny
    I don’t know if my app is right but if it is
  20. buZZsaw BRAD
    Looks like cottonwood
    T.Jeff Veal and Eric Wanderweg like this.
