Best get it done before it turns cold.
Discussion in 'Modern EPA Stoves and Fireplaces' started by Backwoods Savage, Sep 15, 2016.
  1. hman
    hman
    Chillicothe,Ohio
    I am going to be installing new door and glass gaskets on my stove in the next week or two also.I cleaned my stove and chimney in the spring,but I did not install my gaskets.It will probably be cold when I get them installed.Time gets by before a person realizes it.
    Hammy, Horkn, fox9988 and 1 other person like this.
  2. Todd
    Todd
    NW WIS
    What about your glass gasket Dennis? I changed mine out last year after 5 years and it looked like it was due.
  3. Backwoods Savage
    I haven't changed it but thinking about it. There is one small spot that is showing just a hint of ash but it is very small and not on the edge. It looks okay so think I'll wait. Besides, I remember going all around it when the fire was going and I could not detect any leaks nor smell. I do have the gasket though in case we do have to change it out.
    Hammy, Horkn, Well Seasoned and 3 others like this.
  4. fishingpol
    fishingpol
    Merrimack Valley, Ma.
    I cleaned the flue and cap today. About 2 cups of light fluffy brown ash.
    I will replace the two flat gaskets where the secondary assembly sits on the inner side burn plates.
    I need to work on the lead flashing around both chimeys. Squirrels were gnawing away at it. :mad:
  5. chance04
    chance04
    Denton Md
    Don't they know that consuming lead causes cancer in the state of California
    Sent from my SM-G900V using Tapatalk
  6. fishingpol
    fishingpol
    They need it in a different form.
  7. Well Seasoned
    Little pains! Good thing you were up there and saw that.
  8. NortheastAl
    NortheastAl
    Putnam County NY
    Yeah, but they live in MA. :rofl: :lol:
  9. fishingpol
    fishingpol
    I had a mason rebuild the two chimneys from the roof line up a few years ago. New flue tile, brick and reglet flashing. Not too happy about this.
    Oldhippie, HDRock, Hammy and 5 others like this.
  10. JustWood
    JustWood Guest
    Coupe caulk tubes of black joe ought fix that up for awhile. And some lead pills for the tree rats !
    HDRock, fishingpol, Hammy and 3 others like this.
  11. fishingpol
    fishingpol
    Sealed up the lead flashing yesterday. The top mortar cap on both chimneys had the beginning of hairline cracks. I do not want water penetrating down and freezing in it. I took care of both caps this afternoon.
  12. chris
    chris
    SE WI
    That being new brick and all, it would be in your best interest to treat with a water proof sealant, Not Thompson though as that stuff doesn't last. Most can be sprayed with a garden sprayer dosen't take long and that will help stop the hairline stuff. Needs too be done before it gets too cold though. I can tell stories about new brick and old and water wicking problems.
  13. fishingpol
    fishingpol
    Good idea. I've used Conproco in the past. I'll see what is available at the stone yard. Time is right to get it done.
    Both chimneys mortar caps were weathered. I don't know if it was from the elements or corrosion as one being the nat gas flue, the other the wood stove.
    Thanks for the advice.:yes: These little things can add up to a tear down and some cash out the door.
  14. Oldhippie
    Oldhippie
    Ashby Ma
    I'll plan on doing mine then in 2025. :)
    fishingpol and Well Seasoned like this.
  15. Well Seasoned
    Backwoods Savage and fishingpol like this.
  16. Oldhippie
    Oldhippie
    Ashby Ma
    I can see you are an over-achiever! LOL!
  17. fishingpol
    fishingpol
    Hah, no. If I went down the ladder for a damp sponge and smoothed it out I would be. :whistle:
  18. chris
    chris
    SE WI
    procrastination, :D me thinks
  19. fishingpol
    fishingpol
    Finished both chimneys with sealer 2 coats drying in the afternoon sun. I started with the brush and went right to the pump sprayer. Better coverage and a time saver.
  20. Oldhippie
    Oldhippie
    Ashby Ma
    Jon, how high up are you when doing this? You Da' Man!!
    Backwoods Savage and papadave like this.
