Best chain grinder
Discussion in 'Chainsaws and Power Equipment' started by T.Jeff Veal, Aug 8, 2019.
  1. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    I sharpen only Stihl 3/8 .50, full chisel chains at 60° 30° 0° as recommended by Stihl. They may cut a tad better at 10° angle but they seem to cut fine for me at the recommended settings.
  2. Screwloose
    Screwloose
    Some of the stihl sheets I've looked at do in fact call for 60° 30° 10° for 33rs but I don't personally notice a difference either way. Maybe with a stopwatch cutting cookies. I use the same angles for 33rm also.
  3. Ralphie Boy
    Ralphie Boy
    Now that I've said that, I may have gotten those numbers from the guide that comes with the grinder. Sometimes I'm so confused!
  4. Screwloose
    Screwloose
    I'm confused because everything I find in my mess here says zip.
  5. Screwloose
    Screwloose
    I filed the bottom dead flat getting rid of the 4 points it sat on before. It's a lot less sloppy now. 20200516_210309.jpg
    Then I filed off the powder coat from the bearing surface. It is much smoother operating now. 20200516_210820.jpg
    And lastly I added a little more spring force to the pawl.
  6. Ralphie Boy
    Ralphie Boy
    How'd ya do that? Most of my DIY projects, except felling trees, turn out like this!
  7. T.Jeff Veal
    Wow...ok, I need a shipping address to send mine for tune up...lol...good job, my friend.
    I showed your post about the run out and how close you had gotten it, to my brother, he used to do machine work. He worked in N GA in the70's and 80's for Wabco/Terex, running a big lathe. They built big pan scrapers, and other earth moving equipment. He was impressed, he even asked what the beginning run out was...
  8. Ralphie Boy
    Ralphie Boy
    Yeah, me too! Maybe a sideline for you? Then after you're finished you pack it and send it to huskihl to get the vice dialed in!
    Ahhh...the stuff dreams are made of!
  9. Screwloose
    Screwloose
    Not sure exactly how much out it was when I started because I just kept playing with it until admittedly I got lucky. The motor shaft was pretty good although the tapped hole in the end is off center, trying hard to forget that. The die cast inner hub can be indexed around on the shaft along with indexing the wheel on the hub. Sharpie marks and numbers and start playing with combinations and tapping with a piece of wood. An thin old feeler gauge against the wheel with the indicator against the feeler gauge is what I used.
    Woodsnwoods and T.Jeff Veal like this.
  10. Screwloose
    Screwloose
    I'm thinking that dialing in the vise has a hand in hand relationship with the slop in the sliding plate. I'm working my way to that.
  11. Ralphie Boy
    Ralphie Boy
    But how did you increase the spring tension, replace the spring?
  12. Screwloose
    Screwloose
    I added a sister spring.
  13. Screwloose
    Screwloose
    Well it's screwed now !!
    T.Jeff Veal, Woodsnwoods and TBONE like this.
  14. 94BULLITT
    94BULLITT
    Frederick County, VA
    It's all good. I just wanted to see why you did not use the vise tilt. On my old grinder, I first did chains(Stihl) without the vise tilt. RM cut fine, but RS would not self feed. Some guys on here suggested vise tilt and I tried it and the chains cut good. My chains cut good on my old grinder, but with this new grinder they cut even better. I'll have to try a chain with out vise tilt. I really need to take a chain and test some different angles, and do some time cuts to see what works the best. Which what is fastest, may not be the most durable. I want the balance between speed and durability. The angles I currently use are 55,25,10.
  15. 94BULLITT
    94BULLITT
    I think stihl says 30,60,0. The paperwork with the grinder says 30,55-60,10.
  16. Screwloose
    Screwloose
    I added 2 little pieces of rubber tubing to stop the outer vise jaw from moving up and down every time it clamped and released.
  17. Fifelaker
    Fifelaker
    Fife Lake Mi.
  18. Ralphie Boy
    Ralphie Boy
    Woodsnwoods, Screwloose and Fifelaker like this.
  19. Barcroftb
    Barcroftb
    The Mitten
    That's different enough to be a China clone.
  20. huskihl
    huskihl
    By the time you add $60 for good wheels, it’s a little less sweet. Totally depends on the quality though.
    I always thought the $80 ebay 511ax clone was a badass machine for the $
