Best baragin chainsaw?
Discussion in 'Chainsaws and Power Equipment' started by sirbuildalot, Dec 18, 2022.
  1. 203coffeeman
    203coffeeman
    Connecticut
    Buzz could u send me that link for that 251 was interested in buying either that or the echo 4910/590. What do u think is the better saw. For just around the yard/ firewood.
    Screwloose and buZZsaw BRAD like this.
  2. buZZsaw BRAD
    41cc on all 011's. 009L is 40.8cc's, but .3kilograms (2/3lb) lighter
  3. buZZsaw BRAD
    which Buzz? Just by coincidence we live two minutes apart
    Screwloose and Eggshooterist like this.
  4. Eggshooterist
    Eggshooterist
    Erff
    Acres site says one 09 is 36.6cc, one is 37 and the other 41cc. I've found more than one mistake on that site so who knows whats what there.
  5. buZZsaw BRAD
    the 009 is 37, the 009L is 41. Two different saws
  6. Czed
    Czed
    Wv
    Best bargain I ever got personally in a saw is a 1986
    266se it's still has it's original seals
    I threw a ring in it rebuilt the carb
    4 year's on it now
    It's my truck saw.
    As far as modern bargain saws I had a couple of echo 590s that were excellent
    I bought two thinking I'd wear one out and use the second
    Never happened I traded the nib one for a port job
    And my friend needed the other.
    I had a 490 for 4 year's it's a good little saw
    But a ms250 is more powerful
    I run professional Husqvarna xp saws but would gladly buy a ms250 0r 251 whatever
    Instead of the homeowner so called Husqvarna's they sell now.
    Screwloose, SimonHS and Eggshooterist like this.
  7. buZZsaw BRAD
    009 EQZ Woodboss, from 82 electr., from 05.84 in gray, from 85 CEPA. No longer available in the EU 36:6-1:6 4.1 10/15/1980 - 12/15/1997
    009 LEQZ Woodboss, from 82 electr., from 05.84 in gray, from 85 CEPA. No longer available in the EU 40.8-2.0 4.1 10/15/1980 - 12/15/1997
    011 AVEQZ from 82 electr. , from 84 in grey 41.0-2.0 4.4 12/15/1980 - 12/15/1996
    011 AVTEQZ 41.0-2.0 4.4 06/15/1984 - 12/15/1990
    011 T 41.0-2.0 4.4 04/15/1984 - 12/15/2004
    010 AVEQT 36:6-1:6 4.4 06/01/1967 - 10/01/1991
    012 AVEQZT 45:2-2:3 4.6 08/01/1978 - 09/01/1991
    Copy & pasted directly from the Stihl chain saw spec page. The 1120 series
  8. Eggshooterist
    Eggshooterist
    Erff
    Ah. I see. I figured an 09 was an 09. Just like the 011
  9. Lehman
    Lehman
    Minnesota
    They’re a turd kinda, reed induction but not very powerful.
  10. buZZsaw BRAD
    I believe there are top and read handle versions of the 011. The 012 has both. The top handle version is about the ugliest chain saw ive ever seen.
  11. Eggshooterist
    Eggshooterist
    Erff
    You might be on to something there bud.
  12. Eggshooterist
    Eggshooterist
    Erff
    Kinda is an understatement.
  13. KSPlainsman
    KSPlainsman
    Kansas
    That would be plenty for a top handle I reckon. Lol
  14. buZZsaw BRAD
    Ive read so many conflicting stories on this. It was on another site i read about the 45cc 012 top end being put into an 009 and really got me thinking. I can probably get a blown up 009 for cheap, so itd be just the 012 parts if i can find them.
  15. buZZsaw BRAD
    and im not thinking a 16" bar either. 12 or 14"
  16. KSPlainsman
    KSPlainsman
    Kansas
    That would definitely rip. My 355t has a 16" and that's plenty bar for that thing. Shorter bar and more cc's would be better.
  17. buZZsaw BRAD
    My Husky 335 has a 14", Stihl MS201 a 12", Stihl MS194 a 14"
  18. jo191145
    jo191145
    Ct
    Nope. My biggest complaint is the easy start feature. Just can’t get used to the motor turning over six days after I pull the rope. It’s too short and underpowered for my taste. Thing only wants to run when it feels like it.
    See no reason to use a saw smaller than my 550’s. My spine doesn’t like bending over that much. I noticed a huge sigh of relief moving from the little 250 to the 550.
    Now that 510 Dolmar I couldn’t convince you to take home for free,,,,,, still sitting out there ;)
  19. Lehman
    Lehman
    Minnesota
    Have at it but I’m betting you’ll be disappointed in the end. I had an 009l that I gave away also had one o10 and ran an 012 and none were very impressive. They ran two different style reeds that aren’t interchangeable because of the case differences. Also ran loose rollers for rod bearings in the couple I had apart. Yes you’d think a 45 cc top handle would have power but I bet the ms 194t I have with a timing advance and muffler mod will outrun one. Another one on paper that should have had some power was the horrible ms 191t. 47cc top handle that had reeds and one of the worst air intake designs I’ve seen.
  20. Lehman
    Lehman
    Minnesota
    I’m pretty sure I have an 012 cylinder and piston but I think but I think I was going to give it to eggshooter if i remember correctly after I dig it out for his 011 but not sure it will make a noticeable difference or not.
