Bench grinder/chain sharpener recomendation?
Discussion in 'Chainsaws and Power Equipment' started by moresnow, May 1, 2017.
  1. moresnow
    moresnow
    I would prefer purchasing this once. In a nutshell I would like to get a high quality unit the first time. Guessing one of the Oregon sharpeners would fit the bill. Likely to maintain 20 of my own chains and who knows how many from buddies:rolleyes:. Anywho. Willing to listen. Fill me in on what seems to be working. Thanks..
    Screwloose and Chvymn99 like this.
  2. mirnldi
    mirnldi
    Ct
    I'm watching this as well. Been on the fence since last year about getting one of these
  3. Chvymn99
    Oregon one would fit the bill yes... they got a couple of really nice one, my neighbor has one of the decent Oregons.
    But I went and got two Northern tool ones. One set up for right and one setup for left. That way I don't have to reset the angles.
  4. bocefus78
    bocefus78
    Indiana
    Is it that much of a pain to switch it over? Real question...not giving you crap. I've never used one. Ok....used a HF one time...then trashed it.
  5. Chvymn99
    No, but consistency is where your eyeballing that line. I just find it easier this way...
  6. bocefus78
    bocefus78
    Indiana
    So there's no click and or stop on the degree marks is what I'm gathering? That makes sense to have two if not.
    Thx for the input. A grinder is on my list for this summer.
    TurboDiesel, Screwloose and Chvymn99 like this.
  7. moresnow
    moresnow
    Interesting. Wonder how many are using 2 grinders? Guessing very few. Nifty idea however. Thanks
    TurboDiesel likes this.
  8. bushpilot
    bushpilot
    Eastern Washington
    I'm using the HF one. Based on what you wrote, it is not the one for you, but it works. When it fails me, I will buy a better one.
    I hate filing chains ...
    Screwloose and gregbesia like this.
  9. Screwloose
    Screwloose
    Whatever you get I cannot make a stronger recommendation than the ABN cyclone wheel from Dynasaw.
    First time you use it you'll do the Snoopy dance !! Slicker than a snot on a dog's nose.
    I'm a machinist by trade and in my opinion all the chain grinders are built like a POS. I've had the Oregon 511a forever and I can do the same job on a buddy's northern tool unit. You have to treat them like a teenage daughter cause they are sensitive, don't bet your life on the graduation marks pull gently and consistently. Spend a afternoon tweeking, adjusting, filing and fitting until rights and lefts end up the same. Then don't let anyone else use it.
    gregbesia, bocefus78 and Chvymn99 like this.
  10. Screwloose
    Screwloose
    I've always wanted a second one to set up just for drags.
    clemsonfor likes this.
  11. Screwloose
    Screwloose
    If I was doing any quantity of chain grinding you can bet I'd have a separate right and left grinder.
  12. mirnldi
    mirnldi
    Ct
    anyone have a granberg? That looks like it would fit my needs.
  13. Screwloose
    Screwloose
    The lack of stops isn't the issue, it's the "flexibility and loose fits" that cause people headaches. It's not a "machine tool" it's a fixture mounted grinder. So you have to become one with the grinder Young Grasshopper. Pull constantly but gently to the right as you pull down (to remove play and flexibility and not fight the wheel trying to move away from the tooth. Move the head up and down only as much distance as required because you want to preserve the hinge fit.
    bocefus78, bushpilot and clemsonfor like this.
  14. clemsonfor
    Nope eyeball. I bet the more expensive ones may have little stops. But the plate tilts as well
    Chvymn99 and Screwloose like this.
  15. clemsonfor
    I had one and thought it was good too till I bought the NT on sale for $99.
    With the HF one make sure you buy the wheel for real 3/8 (.375) chain cause the one it comes with is for 3/8 lopro chain and won't sharpen right.
    Screwloose likes this.
